    Sampling color at vertexes
    53 Posts 0 Posters 46.3k Views
      On 07/08/2014 at 14:50, xxxxxxxx wrote:
      I tried replacing the call to SampleColorAtVertices with GePrint(b_source->GetName()); and it printed out the name perfectly.
        On 07/08/2014 at 15:14, xxxxxxxx wrote:
        OK. Then I'm out of ideas.
        I usually run code that I'm new to in a CommandData() plugin first as a sort of script. Before implementing it in an actual plugin.
        That way I know that the code is working before I attempt to add it to some other plugin.
        I haven't used his code in anything else yet.
          On 07/08/2014 at 15:33, xxxxxxxx wrote:
          Well, I may have not adjusted the code from Remo correctly.
          Would it be possible to see your adjustments to compare them with mine?
            On 07/08/2014 at 15:51, xxxxxxxx wrote:
            Sure. I can send you my CD plugin if you want.
            What's your e-mail again?
              On 07/08/2014 at 15:58, xxxxxxxx wrote:
              Thank you very much in advance, Scott.
              My mail is [email protected]
                On 08/08/2014 at 04:39, xxxxxxxx wrote:
                I had to fire it up on Parallels to check it out (I'm on a Mac 😉 )
                It works.
                But as I used your code in my plugin, it crashes the same way 😞
                  On 08/08/2014 at 07:11, xxxxxxxx wrote:
                  Then the problem has to be in your plugin.
                  Do you know how to use the debugger?
                  The error you get from it might help you figure it out.
                  Edit-- FYI
                  I have to correct myself a bit.
                  That stuff I was saying about the subdialog is for the older type of ToolData plugins.
                  I think you're using the newer DescriptionToolData plugin. Which uses the .res file. And is a bit different from the older ToolData plugin.
                  I forgot that there was two different versions of the tool plugin.
                    On 08/08/2014 at 07:35, xxxxxxxx wrote:
                    No, unfortunately I don't know how to use the debugger 😞
                      On 08/08/2014 at 09:06, xxxxxxxx wrote:
                      I don't have the Remo code in my plugin, like you have.
                      It is in a separate file that I include at the start of my source code, like this:
                      #include "c4d.h"
                      #include "c4d_symbols.h"
                      #include "tpolypaintfrommaterial.h"
                      #include "c4d_helpers.h"
                      #include "remo_sampler.h"
                      Could it be because of this?
                        On 08/08/2014 at 09:18, xxxxxxxx wrote:
                        Doing some simple detective work I found out that what is causing the crash in SampleColorAtVertices is the line:
                        Sampler smpl;
                        If I place a return INIT_SAMPLER_RESULT_OK; before this line, no crash occurs.
                        If I place a return INIT_SAMPLER_RESULT_OK; after this line, the crash occurs.
                          On 08/08/2014 at 11:41, xxxxxxxx wrote:
                          Hi
                          This seems to be a problem in the constructor.
                          Sampler::Sampler() { ... }
                          But it is imposible to say exactly what causes this crash without knowing what was changed in the code.
                          Have you changes something in this code section ?
                          	AutoAlloc<VolumeData> vd; //Owning ptr
                          AutoAlloc<TexData>	 tex; //Owning ptr
                          Because this will auto alloc vd and tex.
                            On 08/08/2014 at 12:03, xxxxxxxx wrote:
                            This is what I have:
                            class Sampler
                                 Sampler();
                                 ~Sampler();
                                 //init this sampler, always call one of this before everything else.
                                 INIT_SAMPLER_RESULT Init(BaseObject *obj,LONG chnr=CHANNEL_COLOR,Real time=0.0);
                                 INIT_SAMPLER_RESULT Init(BaseMaterial *mat ,LONG chnr,Real time,BaseDocument *doc,BaseObject *op=nullptr);
                                 INIT_SAMPLER_RESULT Init(TextureTag *textag,LONG chnr,Real time,BaseDocument *doc,BaseObject *op=nullptr);
                                 //return true if Init was called before.
                                 inline Bool IsInit(){ return TexInit; };
                                 //return color at UVW coordinates.
                                 Vector     SampleUV(const Vector &uv;, Real time=0.0);
                                 //return color at 3D coordinates p, if shader is not 3D then uv will be used.
                                 Vector     Sample3D(const Vector &pos3d;, const Vector &uv; = Vector(0.0), Real time=0.0);
                                 //return average color of the shader
                                 Vector AverageColor(LONG num_samples = 128);
                                 void Free();
                            private:
                                 BaseShader                *texShader; //NON owning ptr
                                 RayObject                *rop; //Owning ptr
                                 InitRenderStruct     irs;
                                 ChannelData               cd;
                                 Matrix               omg;
                                 Real               offsetX;
                                 Real               offsetY;
                                 Real               lenX;
                                 Real               lenY;
                                 Bool               TexInit;
                              On 08/08/2014 at 12:06, xxxxxxxx wrote:
                              Well then it will be cause by some changes in the constructor.
                              Sampler::Sampler()
                                On 08/08/2014 at 12:15, xxxxxxxx wrote:
                                Well, the listing is a bit long. Should I paste it here or should I send it over through e-mail? (if I can, of course... I don't want to be imposing).
                                  Of course you can send it over e-mail.
                                  Even better just place it on github.com
                                    On 08/08/2014 at 12:25, xxxxxxxx wrote:
                                    Mustn't I have an account in github.com to place something there?
                                    And, if I send you the listing over e-mail, can I use the mail I used when I bought some of your plugins? 🙂
                                      On 08/08/2014 at 13:18, xxxxxxxx wrote:
                                      Since you're having so many problems with this. I decided to create a DescriptionToolData plugin myself.
                                      I used your Message() code for the getting the object in the linkbox gizmo.
                                      And I used the same Sample class code I sent you in my CD plugin.
                                      I also used a separate .h file to host that code. Using #include "sampler.h" to point to the code from the plugin's .cpp file
                                      It all works fine for me and does not crash at all. I can't undestand why you're having so many problems with it.
                                      Would you like me to send you my tool plugin?
                                        I think yes.
                                        Or just PM me here, whatever you want 🙂
                                        Note: I do not ready my e-mails often. Some times for many days.
                                          On 08/08/2014 at 13:38, xxxxxxxx wrote:
                                          Thank you to both.
                                          I will try take a look at Scott plugin and compare it with mine first.
                                          I hope I find my mistake (I'm assuming I must be doing something wrong).
                                          If I still don't manage to fix it, I will send you my code through PM, Remo.
                                          Ok?
                                          So, if you don't mind, Scott, I would gladly take a look at your plugin.
                                          Same batchannel, same bat-mail 😉
                                            On 08/08/2014 at 14:57, xxxxxxxx wrote:
                                            I'm still cleaning up (it still hanged my code 😞 )
                                            In the meanwhile, let me tell you guys one thing that may help pinpoit the problem.
                                            Xcode is giving me a warning in the line:
                                            GeDynamicArray<Colors> colors(pcnt);
                                            The warning is: Template argument uses local type 'Colors'
                                            What is this?!?
