    Sampling color at vertexes
    53 Posts 0 Posters 45.2k Views
      On 08/08/2014 at 11:41, xxxxxxxx wrote:
      Hi
      This seems to be a problem in the constructor.
      Sampler::Sampler() { ... }
      But it is imposible to say exactly what causes this crash without knowing what was changed in the code.
      Have you changes something in this code section ?
      	AutoAlloc<VolumeData> vd; //Owning ptr
      AutoAlloc<TexData>	 tex; //Owning ptr
      Because this will auto alloc vd and tex.
        On 08/08/2014 at 12:03, xxxxxxxx wrote:
        This is what I have:
        class Sampler
             Sampler();
             ~Sampler();
             //init this sampler, always call one of this before everything else.
             INIT_SAMPLER_RESULT Init(BaseObject *obj,LONG chnr=CHANNEL_COLOR,Real time=0.0);
             INIT_SAMPLER_RESULT Init(BaseMaterial *mat ,LONG chnr,Real time,BaseDocument *doc,BaseObject *op=nullptr);
             INIT_SAMPLER_RESULT Init(TextureTag *textag,LONG chnr,Real time,BaseDocument *doc,BaseObject *op=nullptr);
             //return true if Init was called before.
             inline Bool IsInit(){ return TexInit; };
             //return color at UVW coordinates.
             Vector     SampleUV(const Vector &uv;, Real time=0.0);
             //return color at 3D coordinates p, if shader is not 3D then uv will be used.
             Vector     Sample3D(const Vector &pos3d;, const Vector &uv; = Vector(0.0), Real time=0.0);
             //return average color of the shader
             Vector AverageColor(LONG num_samples = 128);
             void Free();
        private:
             BaseShader                *texShader; //NON owning ptr
             RayObject                *rop; //Owning ptr
             InitRenderStruct     irs;
             ChannelData               cd;
             Matrix               omg;
             Real               offsetX;
             Real               offsetY;
             Real               lenX;
             Real               lenY;
             Bool               TexInit;
          On 08/08/2014 at 12:06, xxxxxxxx wrote:
          Well then it will be cause by some changes in the constructor.
          Sampler::Sampler()
            On 08/08/2014 at 12:15, xxxxxxxx wrote:
            Well, the listing is a bit long. Should I paste it here or should I send it over through e-mail? (if I can, of course... I don't want to be imposing).
              Of course you can send it over e-mail.
              Even better just place it on github.com
                On 08/08/2014 at 12:25, xxxxxxxx wrote:
                Mustn't I have an account in github.com to place something there?
                And, if I send you the listing over e-mail, can I use the mail I used when I bought some of your plugins? 🙂
                  On 08/08/2014 at 13:18, xxxxxxxx wrote:
                  Since you're having so many problems with this. I decided to create a DescriptionToolData plugin myself.
                  I used your Message() code for the getting the object in the linkbox gizmo.
                  And I used the same Sample class code I sent you in my CD plugin.
                  I also used a separate .h file to host that code. Using #include "sampler.h" to point to the code from the plugin's .cpp file
                  It all works fine for me and does not crash at all. I can't undestand why you're having so many problems with it.
                  Would you like me to send you my tool plugin?
                    I think yes.
                    Or just PM me here, whatever you want 🙂
                    Note: I do not ready my e-mails often. Some times for many days.
                      On 08/08/2014 at 13:38, xxxxxxxx wrote:
                      Thank you to both.
                      I will try take a look at Scott plugin and compare it with mine first.
                      I hope I find my mistake (I'm assuming I must be doing something wrong).
                      If I still don't manage to fix it, I will send you my code through PM, Remo.
                      Ok?
                      So, if you don't mind, Scott, I would gladly take a look at your plugin.
                      Same batchannel, same bat-mail 😉
                        On 08/08/2014 at 14:57, xxxxxxxx wrote:
                        I'm still cleaning up (it still hanged my code 😞 )
                        In the meanwhile, let me tell you guys one thing that may help pinpoit the problem.
                        Xcode is giving me a warning in the line:
                        GeDynamicArray<Colors> colors(pcnt);
                        The warning is: Template argument uses local type 'Colors'
                        What is this?!?
                          On 09/08/2014 at 12:43, xxxxxxxx wrote:
                          Remo, I have sent you an mail (and a movie through wetransfer) to your gmail account.
                          I don't know if it is still active, though.
