    Sampling color at vertexes
    53 Posts 0 Posters 46.3k Views
      On 07/08/2014 at 11:40, xxxxxxxx wrote:
      I tried searching for it and indeed I found it.
      But it lacks a lot of the stuff that is on the latest version and I can't even start to figure out a way to make it return the average color of vertexes 😞
        On 07/08/2014 at 11:54, xxxxxxxx wrote:
        Tried to re-use the latest version again. Cleaned out all the errors but I still get the crash 😞
          On 07/08/2014 at 12:12, xxxxxxxx wrote:
          It kind of sounds like the problem of trying to grab an object that isn't ready to be grabbed yet.
          What kind of plugin are you making Rui?
          So far I've only used the code like a script in a CommanData() plugin, on the active object. And it works fine (except for the ProjectPoint() method stuff).
            On 07/08/2014 at 13:15, xxxxxxxx wrote:
            It is a ToolPlugin.
            It shows a Link field in the Attribute Manager and it would sample all the colors of the vertexes of the object to store them inside a database.
            The Message method, as I have it right now is this one:
            Bool polypaintfrommaterial::Message(BaseDocument* doc, BaseContainer& data, LONG type, void* t_data)
                 if (type==MSG_DESCRIPTION_COMMAND)
                      DescriptionCommand *dc = static_cast<DescriptionCommand*>(t_data);
                      LONG button = dc->id[0].id;
                      if (button == PPT_TRANSFER)
                           BaseObject* b_source = (BaseObject* ) data.GetObjectLink(PPT_SOURCE,doc,Obase);
                           if (b_source==NULL) return TRUE;     // no source
                           SampleColorAtVertices(b_source);
            The Link field only accepts polygonal objects. And the object I drag into it, has a material tag.
            But, as soon as I press the button, it crashes.
              On 07/08/2014 at 14:42, xxxxxxxx wrote:
              I could be completely off base here. But humor me anyway.😉
              You might not be grabbing the object.
              The tool AM is really a subdialog. Which is different from the AM in Tag or Object plugins.
              So it might be that you're using the Linkfield code for Node plugins instead of the Linkfield code for GeDialog and subdialogs.
              Here's some code I ripped out of a tool plugin
              //The subdialog class for the tool plugin
              class ToolDialog: public SubDialog
                private:
                    LinkBoxGui *myLink;
                    BaseContainer    *toolData;  //A container we'll save the dialog values in so they don't constantly re-set
                    virtual          Bool CreateLayout(void);
                    virtual          Bool InitValues(void);
                    virtual          LONG Message(const BaseContainer& msg, BaseContainer& result);
                    virtual          Bool Command(LONG id,const BaseContainer &msg);
              // ....the other subdialog methods here .....
              LONG ToolDialog::Message(const BaseContainer &msg, BaseContainer &result)
                LONG mid = msg.GetId();
                //Use one of the BFM messages to get the link
                //Because BFM messages are intended to be used with dialogs
                if(mid == BFM_SYNC_MESSAGE)
                    BaseObject *lop = (BaseObject* )myLink->GetLink(GetActiveDocument());
                    if(!lop) GePrint("empty");
                    else GePrint(lop->GetName());
                return GeDialog::Message(msg, result);
              //The actual Tool plugin class where the tool does it's thing based on the subdialog settings above
              class MyTool : public ToolData
                    ToolDialog *dlg;
                    virtual SubDialog           *AllocSubDialog(BaseContainer *bc);
                    MyTool() :ToolData(), dlg(nullptr){ }
                    virtual LONG                GetToolPluginId() { return PLUGIN_ID; }
                    virtual Bool                InitTool(BaseDocument* doc, BaseContainer& data, BaseThread* bt);
                    virtual const String        GetResourceSymbol() { return String("mytool"); }  //The name of the .res file
                    virtual Bool                GetCursorInfo(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, Real x, Real y, BaseContainer &bc);
                    virtual Bool                MouseInput(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg);
                    virtual void                FreeTool(BaseDocument *doc, BaseContainer &data);
              //etc....
              What I'm saying is...Are you 100% sure you're really grabbing the linked object correctly?
              Have you tested it by asking for the object's name, or something like that before trying to run Remo's code on it?
                On 07/08/2014 at 14:46, xxxxxxxx wrote:
                Well, the code I'm using is from another plugin that I coded and it is working perfectly. The other plugin even includes two fields to link to two different objects (it is a transfer function) and it all works perfectly.
                The basic functionality of this new plugin is, mainly the same (in the way that it works, not in what it does), so I'm re-using the code.
                  On 07/08/2014 at 14:50, xxxxxxxx wrote:
                  I tried replacing the call to SampleColorAtVertices with GePrint(b_source->GetName()); and it printed out the name perfectly.
                    On 07/08/2014 at 15:14, xxxxxxxx wrote:
                    OK. Then I'm out of ideas.
                    I usually run code that I'm new to in a CommandData() plugin first as a sort of script. Before implementing it in an actual plugin.
                    That way I know that the code is working before I attempt to add it to some other plugin.
                    I haven't used his code in anything else yet.
                      On 07/08/2014 at 15:33, xxxxxxxx wrote:
                      Well, I may have not adjusted the code from Remo correctly.
                      Would it be possible to see your adjustments to compare them with mine?
                        On 07/08/2014 at 15:51, xxxxxxxx wrote:
                        Sure. I can send you my CD plugin if you want.
                        What's your e-mail again?
                          On 07/08/2014 at 15:58, xxxxxxxx wrote:
                          Thank you very much in advance, Scott.
                          My mail is [email protected]
                            On 08/08/2014 at 04:39, xxxxxxxx wrote:
                            I had to fire it up on Parallels to check it out (I'm on a Mac 😉 )
                            It works.
                            But as I used your code in my plugin, it crashes the same way 😞
                              On 08/08/2014 at 07:11, xxxxxxxx wrote:
                              Then the problem has to be in your plugin.
                              Do you know how to use the debugger?
                              The error you get from it might help you figure it out.
                              Edit-- FYI
                              I have to correct myself a bit.
                              That stuff I was saying about the subdialog is for the older type of ToolData plugins.
                              I think you're using the newer DescriptionToolData plugin. Which uses the .res file. And is a bit different from the older ToolData plugin.
                              I forgot that there was two different versions of the tool plugin.
                                On 08/08/2014 at 07:35, xxxxxxxx wrote:
                                No, unfortunately I don't know how to use the debugger 😞
                                  On 08/08/2014 at 09:06, xxxxxxxx wrote:
                                  I don't have the Remo code in my plugin, like you have.
                                  It is in a separate file that I include at the start of my source code, like this:
                                  #include "c4d.h"
                                  #include "c4d_symbols.h"
                                  #include "tpolypaintfrommaterial.h"
                                  #include "c4d_helpers.h"
                                  #include "remo_sampler.h"
                                  Could it be because of this?
                                    On 08/08/2014 at 09:18, xxxxxxxx wrote:
                                    Doing some simple detective work I found out that what is causing the crash in SampleColorAtVertices is the line:
                                    Sampler smpl;
                                    If I place a return INIT_SAMPLER_RESULT_OK; before this line, no crash occurs.
                                    If I place a return INIT_SAMPLER_RESULT_OK; after this line, the crash occurs.
                                      On 08/08/2014 at 11:41, xxxxxxxx wrote:
                                      Hi
                                      This seems to be a problem in the constructor.
                                      Sampler::Sampler() { ... }
                                      But it is imposible to say exactly what causes this crash without knowing what was changed in the code.
                                      Have you changes something in this code section ?
                                      	AutoAlloc<VolumeData> vd; //Owning ptr
                                      AutoAlloc<TexData>	 tex; //Owning ptr
                                      Because this will auto alloc vd and tex.
                                        On 08/08/2014 at 12:03, xxxxxxxx wrote:
                                        This is what I have:
                                        class Sampler
                                             Sampler();
                                             ~Sampler();
                                             //init this sampler, always call one of this before everything else.
                                             INIT_SAMPLER_RESULT Init(BaseObject *obj,LONG chnr=CHANNEL_COLOR,Real time=0.0);
                                             INIT_SAMPLER_RESULT Init(BaseMaterial *mat ,LONG chnr,Real time,BaseDocument *doc,BaseObject *op=nullptr);
                                             INIT_SAMPLER_RESULT Init(TextureTag *textag,LONG chnr,Real time,BaseDocument *doc,BaseObject *op=nullptr);
                                             //return true if Init was called before.
                                             inline Bool IsInit(){ return TexInit; };
                                             //return color at UVW coordinates.
                                             Vector     SampleUV(const Vector &uv;, Real time=0.0);
                                             //return color at 3D coordinates p, if shader is not 3D then uv will be used.
                                             Vector     Sample3D(const Vector &pos3d;, const Vector &uv; = Vector(0.0), Real time=0.0);
                                             //return average color of the shader
                                             Vector AverageColor(LONG num_samples = 128);
                                             void Free();
                                        private:
                                             BaseShader                *texShader; //NON owning ptr
                                             RayObject                *rop; //Owning ptr
                                             InitRenderStruct     irs;
                                             ChannelData               cd;
                                             Matrix               omg;
                                             Real               offsetX;
                                             Real               offsetY;
                                             Real               lenX;
                                             Real               lenY;
                                             Bool               TexInit;
                                          On 08/08/2014 at 12:06, xxxxxxxx wrote:
                                          Well then it will be cause by some changes in the constructor.
                                          Sampler::Sampler()
                                            On 08/08/2014 at 12:15, xxxxxxxx wrote:
                                            Well, the listing is a bit long. Should I paste it here or should I send it over through e-mail? (if I can, of course... I don't want to be imposing).
