    changing Renderpath problem
    22 Posts 0 Posters 14.7k Views
      On 14/03/2013 at 07:59, xxxxxxxx wrote:
      are you sure ? i don't think using the gelistnode as an interface instead of a bc
      does make so much difference, but who knows, c4d tends to be akward ;).  and
      just for clarification, my example is more than a different notation.
      this won't work as a path string in python
      'c:\somefolder\somefile.dat'
      but these will (the little prefix r is a raw string)
      'c:\\somefolder\\somefile.dat'
      r'c:\somefolder\somefile.dat'
      http://docs.python.org/2/reference/lexical_analysis.html#literals
        On 14/03/2013 at 08:06, xxxxxxxx wrote:
        @Ferdinand: No, this is applies to string-literals only. A string that does already exist will not be
        processed for backslash-escaping again. So the string doesn't care if there is a \n or \r or any
        escape sequence when concatenating, just when being parsed by the Python parser. It is an
        annotation to the coder, not a runtime thingy.
        ref = r'Hello \nobody'
        string_a = ref + ', how are you?'
        string_b = '%s%s' % (ref, ', how are you?')
        string_c = '{0}{1}'.format(ref, ', how are you?')
        assert string_a == string_b == string_c
        @Amadeo: I agree with Ferdinand, it doesn't look like there should be a semantical difference
        in the code. Are you sure you didn't change anything else?
        Best,
        Niklas
          On 14/03/2013 at 08:22, xxxxxxxx wrote:
          [OK] rd = doc.GetActiveRenderData()
          [OK] print rd[[c4d.RDATA_PATH]]
          c:\nline\nline
          [OK] rd[[c4d.RDATA_PATH]] + 'abc'
          'c:\\nline\\nlineabc'
          c4d won't accept this path. so you have to force your ouput into raw again not
          sure if string.format does this by default.
            On 14/03/2013 at 08:26, xxxxxxxx wrote:
            I don't see why it won't accept this path. Looks valid to me.
            Btw, are the doubled brackets intended?
            [OK] print rd **[[** c4d.RDATA_PATH **]]**
              On 14/03/2013 at 08:35, xxxxxxxx wrote:
              for brackets i don't know, haven't really seen them the console font is so tiny. the snippet is
              directly from the console, c4d put them there. for accepting the path - does c4d accept double
              backlashes instead of single ones ? after __add__ the raw string is transformed into the
              escaped form and rdata[pathblah] actually contains the double backlashes.
                On 14/03/2013 at 08:40, xxxxxxxx wrote:
                There are no double backslashes in the string. There are double-backslashes in the output because
                you didn't print the string. See Python's __repr__.
                Python 2.7.2 (default, Jun 12 2011, 15:08:59) [MSC v.1500 32 bit (Intel)] on win32
                Type "help", "copyright", "credits" or "license" for more information.
                \>>> str = 'C:\\nobody\\noway'
                \>>> str
                'C:\\nobody\\noway'
                \>>> print str
                C:\nobody\noway
                \>>> str + '\\notime'
                'C:\\nobody\\noway\\notime'
                \>>> print str + '\\notime'
                C:\nobody\noway\notime
                  On 14/03/2013 at 09:55, xxxxxxxx wrote:
                  ah ok, i didn't think of that, i stand corrected 😉
                    On 14/03/2013 at 09:56, xxxxxxxx wrote:
                    Hey Guys,
                    I checked again:
                    if i change
                    back to
                    doc.GetActiveRenderData().GetData()
                    and
                    documents.RenderDocument(doc, renderData.GetData(), renderBmp, c4d.RENDERFLAGS_EXTERNAL)
                    to
                    documents.RenderDocument(doc, renderData, renderBmp, c4d.RENDERFLAGS_EXTERNAL)
                    Thers no file output to disk anymore, just pictureviewer
                    Is that weird?
                      On 14/03/2013 at 10:00, xxxxxxxx wrote:
                      It is indeed. Could you provide an SSCCE?
                      -Nik
                        On 14/03/2013 at 10:12, xxxxxxxx wrote:
                        I read your link, but i'm not too sure what that's supposed to be ^^sorry
                        would it not be an option to simply send you the code? or the plugin? because i don't think it can be trimmed to far and i don't know how to make it work without all the parts. Does that even make sense?^^
                          On 14/03/2013 at 10:17, xxxxxxxx wrote:
                          SSCCE = Short Self Contained Correct Example
                          => Just paste some code that shows the problem and can be run right in the script
                          manager or in a Python plugin-file. 😉
                          You can also send it via PM if you don't want to make it public.
                          Best,
                          -Niklas
                            On 14/03/2013 at 10:28, xxxxxxxx wrote:
                            I'll get back to you tomorrow, is that ok?
                            Thanks a lot,
                            Aurel
                              On 15/03/2013 at 01:15, xxxxxxxx wrote:
                              Hey NiklasR,
                              Here is what i belive to be a SSCCE:
                              from c4d import gui, plugins, documents
                              import os
                                    renderData = doc.GetActiveRenderData()
                                    xResolution = int(round(renderData[c4d.RDATA_XRES]))
                                    yResolution = int(round(renderData[c4d.RDATA_YRES]))
                                    pathChange = False
                                    if renderData[c4d.RDATA_PATH] != "":
                                        storedPath = renderData[c4d.RDATA_PATH]
                                        renderData[c4d.RDATA_PATH] =r'{0}_{1}'.format(renderData[c4d.RDATA_PATH], "extension")
                                        pathChange = True
                                    renderBmp = c4d.bitmaps.BaseBitmap()
                                    renderBmp.Init(x=xResolution, y=yResolution, depth=32, )
                                    result = documents.RenderDocument(doc, renderData.GetData(), renderBmp, c4d.RENDERFLAGS_EXTERNAL)
                                    if pathChange == True:
                                        renderData[c4d.RDATA_PATH] = storedPath
                                    if result==c4d.RENDERRESULT_OK:
                                        c4d.bitmaps.ShowBitmap(renderBmp)     # show image in pictureViewer
                              Just create a new scene, save the renderoutput in some folder. If you run this script, the rendered file will actually be output to the folder. If you move the .GetData() to doc.GetActiveRenderData().GetData() and remove it from renderData.GetData(), theres no more file output.
                              Aurel
                                On 15/03/2013 at 06:21, xxxxxxxx wrote:
                                Hi Amadeo,
                                yes that is perfect, thanks.
                                I'm also very confused, I can reproduce the behavior you describe. I don't see what is wrong
                                in your code, mine works (see below). Anyway, you could still just save the image by hand. The
                                script below is doing this as well so you will end up with two images when the Save parameter
                                is checked in the render-data.
                                import os
                                    rdata = doc.GetActiveRenderData().GetData()
                                 **    # rdata[c4d.RDATA_SAVEIMAGE] = False**
                                    xres = int(round(rdata[c4d.RDATA_XRES]))
                                    yres = int(round(rdata[c4d.RDATA_YRES]))
                                    path = rdata[c4d.RDATA_PATH]
                                    if not path:
                                        c4d.gui.MessageDialog("no save-path specified")
                                    dirname = os.path.dirname(path)
                                    if not os.path.exists(dirname) :
                                        os.makedirs(dirname)
                                    elif not os.path.isdir(dirname) :
                                        c4d.gui.MessageDialog("destination directory can not be created.")
                                    path = '%s_extension' % path
                                 **    # rdata[c4d.RDATA_PATH] = path**
                                    fileformat = rdata[c4d.RDATA_FORMAT]
                                    if bmp.Init(xres, yres, 32) != c4d.IMAGERESULT_OK:
                                        c4d.gui.MessageDialog("could not allocated bitmap for render.")
                                    result = c4d.documents.RenderDocument(doc, rdata, bmp, c4d.RENDERFLAGS_EXTERNAL)
                                    if result != c4d.RENDERRESULT_OK:
                                        c4d.gui.MessageDialog("rendering was not successful, see console.")
                                        print "rendering failed with error-code", result
                                    result = bmp.Save(path, fileformat)
                                    if result != c4d.IMAGERESULT_OK:
                                        c4d.gui.MessageDialog("rendered bitmap could not be saved, see console.")
                                        print "saving bitmap failed with error-code", result
                                It seems to be the setting of the RDATA_PATH, because when you uncomment the red line,
                                the RenderDocument() function does not save automatically anymore.
                                Best,
                                -Niklas
