    changing Renderpath problem
    22 Posts 0 Posters 14.7k Views
      On 14/03/2013 at 06:08, xxxxxxxx wrote:
      Also, i just noticed, that the images thet appear in the picture viewer have neither a name or a directory lited under Info
        On 14/03/2013 at 06:45, xxxxxxxx wrote:
        you could try a raw string, python might get confused with the path seperators
        renderData[c4d.RDATA_PATH] = r'{0}\_{1}'.format(renderData[c4d.RDATA_PATH], layerName)
          On 14/03/2013 at 07:40, xxxxxxxx wrote:
          I found the solution:
          I needed to move the .GetData() to .renderDocument(...), updated code:
            def renderDocument(self, layerName) :
                Taking the document and rendering it according to the normal rendersettings of the document.
                Ads '_LAYERNAME', LAYERNAME being the name of the layer, to the renderpath.
                renderData = doc.GetActiveRenderData()
                xResolution = int(round(renderData[c4d.RDATA_XRES]))
                yResolution = int(round(renderData[c4d.RDATA_YRES]))
                if renderData[c4d.RDATA_PATH] != "":
                    storedPath = renderData[c4d.RDATA_PATH]
                    print renderData[c4d.RDATA_PATH]
                    renderData[c4d.RDATA_PATH] =r'{0}_{1}'.format(renderData[c4d.RDATA_PATH], layerName)
                renderBmp = c4d.bitmaps.BaseBitmap()
                renderBmp.Init(x=xResolution, y=yResolution, depth=32, )
                result = documents.RenderDocument(doc, renderData.GetData(), renderBmp, c4d.RENDERFLAGS_EXTERNAL)
                renderData[c4d.RDATA_PATH] = storedPath
                if result==c4d.RENDERRESULT_OK:
                    c4d.bitmaps.ShowBitmap(renderBmp)     # show image in pictureViewer
          I kept littledevils notation for combining strings though 😉 find it very neat XD
          Thanks for your help both of you!
            On 14/03/2013 at 07:59, xxxxxxxx wrote:
            are you sure ? i don't think using the gelistnode as an interface instead of a bc
            does make so much difference, but who knows, c4d tends to be akward ;).  and
            just for clarification, my example is more than a different notation.
            this won't work as a path string in python
            'c:\somefolder\somefile.dat'
            but these will (the little prefix r is a raw string)
            'c:\\somefolder\\somefile.dat'
            r'c:\somefolder\somefile.dat'
            http://docs.python.org/2/reference/lexical_analysis.html#literals
              On 14/03/2013 at 08:06, xxxxxxxx wrote:
              @Ferdinand: No, this is applies to string-literals only. A string that does already exist will not be
              processed for backslash-escaping again. So the string doesn't care if there is a \n or \r or any
              escape sequence when concatenating, just when being parsed by the Python parser. It is an
              annotation to the coder, not a runtime thingy.
              ref = r'Hello \nobody'
              string_a = ref + ', how are you?'
              string_b = '%s%s' % (ref, ', how are you?')
              string_c = '{0}{1}'.format(ref, ', how are you?')
              assert string_a == string_b == string_c
              @Amadeo: I agree with Ferdinand, it doesn't look like there should be a semantical difference
              in the code. Are you sure you didn't change anything else?
              Best,
              Niklas
                On 14/03/2013 at 08:22, xxxxxxxx wrote:
                [OK] rd = doc.GetActiveRenderData()
                [OK] print rd[[c4d.RDATA_PATH]]
                c:\nline\nline
                [OK] rd[[c4d.RDATA_PATH]] + 'abc'
                'c:\\nline\\nlineabc'
                c4d won't accept this path. so you have to force your ouput into raw again not
                sure if string.format does this by default.
                  On 14/03/2013 at 08:26, xxxxxxxx wrote:
                  I don't see why it won't accept this path. Looks valid to me.
                  Btw, are the doubled brackets intended?
                  [OK] print rd **[[** c4d.RDATA_PATH **]]**
                    On 14/03/2013 at 08:35, xxxxxxxx wrote:
                    for brackets i don't know, haven't really seen them the console font is so tiny. the snippet is
                    directly from the console, c4d put them there. for accepting the path - does c4d accept double
                    backlashes instead of single ones ? after __add__ the raw string is transformed into the
                    escaped form and rdata[pathblah] actually contains the double backlashes.
                      On 14/03/2013 at 08:40, xxxxxxxx wrote:
                      There are no double backslashes in the string. There are double-backslashes in the output because
                      you didn't print the string. See Python's __repr__.
                      Python 2.7.2 (default, Jun 12 2011, 15:08:59) [MSC v.1500 32 bit (Intel)] on win32
                      Type "help", "copyright", "credits" or "license" for more information.
                      \>>> str = 'C:\\nobody\\noway'
                      \>>> str
                      'C:\\nobody\\noway'
                      \>>> print str
                      C:\nobody\noway
                      \>>> str + '\\notime'
                      'C:\\nobody\\noway\\notime'
                      \>>> print str + '\\notime'
                      C:\nobody\noway\notime
                        On 14/03/2013 at 09:55, xxxxxxxx wrote:
                        ah ok, i didn't think of that, i stand corrected 😉
                          On 14/03/2013 at 09:56, xxxxxxxx wrote:
                          Hey Guys,
                          I checked again:
                          if i change
                          back to
                          doc.GetActiveRenderData().GetData()
                          and
                          to
                          documents.RenderDocument(doc, renderData, renderBmp, c4d.RENDERFLAGS_EXTERNAL)
                          Thers no file output to disk anymore, just pictureviewer
                          Is that weird?
                            On 14/03/2013 at 10:00, xxxxxxxx wrote:
                            It is indeed. Could you provide an SSCCE?
                            -Nik
                              On 14/03/2013 at 10:12, xxxxxxxx wrote:
                              I read your link, but i'm not too sure what that's supposed to be ^^sorry
                              would it not be an option to simply send you the code? or the plugin? because i don't think it can be trimmed to far and i don't know how to make it work without all the parts. Does that even make sense?^^
                                On 14/03/2013 at 10:17, xxxxxxxx wrote:
                                SSCCE = Short Self Contained Correct Example
                                => Just paste some code that shows the problem and can be run right in the script
                                manager or in a Python plugin-file. 😉
                                You can also send it via PM if you don't want to make it public.
                                Best,
                                -Niklas
                                  On 14/03/2013 at 10:28, xxxxxxxx wrote:
                                  I'll get back to you tomorrow, is that ok?
                                  Thanks a lot,
                                  Aurel
                                    On 15/03/2013 at 01:15, xxxxxxxx wrote:
                                    Hey NiklasR,
                                    Here is what i belive to be a SSCCE:
                                    from c4d import gui, plugins, documents
                                    import os
                                          pathChange = False
                                              renderData[c4d.RDATA_PATH] =r'{0}_{1}'.format(renderData[c4d.RDATA_PATH], "extension")
                                              pathChange = True
                                          if pathChange == True:
                                    Just create a new scene, save the renderoutput in some folder. If you run this script, the rendered file will actually be output to the folder. If you move the .GetData() to doc.GetActiveRenderData().GetData() and remove it from renderData.GetData(), theres no more file output.
                                    Aurel
                                      On 15/03/2013 at 06:21, xxxxxxxx wrote:
                                      Hi Amadeo,
                                      yes that is perfect, thanks.
                                      I'm also very confused, I can reproduce the behavior you describe. I don't see what is wrong
                                      in your code, mine works (see below). Anyway, you could still just save the image by hand. The
                                      script below is doing this as well so you will end up with two images when the Save parameter
                                      is checked in the render-data.
                                      import os
                                          rdata = doc.GetActiveRenderData().GetData()
                                       **    # rdata[c4d.RDATA_SAVEIMAGE] = False**
                                          xres = int(round(rdata[c4d.RDATA_XRES]))
                                          yres = int(round(rdata[c4d.RDATA_YRES]))
                                          path = rdata[c4d.RDATA_PATH]
                                          if not path:
                                              c4d.gui.MessageDialog("no save-path specified")
                                          dirname = os.path.dirname(path)
                                          if not os.path.exists(dirname) :
                                              os.makedirs(dirname)
                                          elif not os.path.isdir(dirname) :
                                              c4d.gui.MessageDialog("destination directory can not be created.")
                                          path = '%s_extension' % path
                                       **    # rdata[c4d.RDATA_PATH] = path**
                                          fileformat = rdata[c4d.RDATA_FORMAT]
                                          if bmp.Init(xres, yres, 32) != c4d.IMAGERESULT_OK:
                                              c4d.gui.MessageDialog("could not allocated bitmap for render.")
                                          result = c4d.documents.RenderDocument(doc, rdata, bmp, c4d.RENDERFLAGS_EXTERNAL)
                                          if result != c4d.RENDERRESULT_OK:
                                              c4d.gui.MessageDialog("rendering was not successful, see console.")
                                              print "rendering failed with error-code", result
                                          result = bmp.Save(path, fileformat)
                                          if result != c4d.IMAGERESULT_OK:
                                              c4d.gui.MessageDialog("rendered bitmap could not be saved, see console.")
                                              print "saving bitmap failed with error-code", result
                                      It seems to be the setting of the RDATA_PATH, because when you uncomment the red line,
                                      the RenderDocument() function does not save automatically anymore.
                                      Best,
                                      -Niklas
