    changing Renderpath problem
    22 Posts 0 Posters 14.7k Views
      On 14/03/2013 at 08:26, xxxxxxxx wrote:
      I don't see why it won't accept this path. Looks valid to me.
      Btw, are the doubled brackets intended?
      [OK] print rd **[[** c4d.RDATA_PATH **]]**
        On 14/03/2013 at 08:35, xxxxxxxx wrote:
        for brackets i don't know, haven't really seen them the console font is so tiny. the snippet is
        directly from the console, c4d put them there. for accepting the path - does c4d accept double
        backlashes instead of single ones ? after __add__ the raw string is transformed into the
        escaped form and rdata[pathblah] actually contains the double backlashes.
          On 14/03/2013 at 08:40, xxxxxxxx wrote:
          There are no double backslashes in the string. There are double-backslashes in the output because
          you didn't print the string. See Python's __repr__.
          Python 2.7.2 (default, Jun 12 2011, 15:08:59) [MSC v.1500 32 bit (Intel)] on win32
          Type "help", "copyright", "credits" or "license" for more information.
          \>>> str = 'C:\\nobody\\noway'
          \>>> str
          'C:\\nobody\\noway'
          \>>> print str
          C:\nobody\noway
          \>>> str + '\\notime'
          'C:\\nobody\\noway\\notime'
          \>>> print str + '\\notime'
          C:\nobody\noway\notime
            On 14/03/2013 at 09:55, xxxxxxxx wrote:
            ah ok, i didn't think of that, i stand corrected 😉
              On 14/03/2013 at 09:56, xxxxxxxx wrote:
              Hey Guys,
              I checked again:
              if i change
              doc.GetActiveRenderData()
              back to
              doc.GetActiveRenderData().GetData()
              and
              documents.RenderDocument(doc, renderData.GetData(), renderBmp, c4d.RENDERFLAGS_EXTERNAL)
              to
              documents.RenderDocument(doc, renderData, renderBmp, c4d.RENDERFLAGS_EXTERNAL)
              Thers no file output to disk anymore, just pictureviewer
              Is that weird?
                On 14/03/2013 at 10:00, xxxxxxxx wrote:
                It is indeed. Could you provide an SSCCE?
                -Nik
                  On 14/03/2013 at 10:12, xxxxxxxx wrote:
                  I read your link, but i'm not too sure what that's supposed to be ^^sorry
                  would it not be an option to simply send you the code? or the plugin? because i don't think it can be trimmed to far and i don't know how to make it work without all the parts. Does that even make sense?^^
                    On 14/03/2013 at 10:17, xxxxxxxx wrote:
                    SSCCE = Short Self Contained Correct Example
                    => Just paste some code that shows the problem and can be run right in the script
                    manager or in a Python plugin-file. 😉
                    You can also send it via PM if you don't want to make it public.
                    Best,
                    -Niklas
                      On 14/03/2013 at 10:28, xxxxxxxx wrote:
                      I'll get back to you tomorrow, is that ok?
                      Thanks a lot,
                      Aurel
                        On 15/03/2013 at 01:15, xxxxxxxx wrote:
                        Hey NiklasR,
                        Here is what i belive to be a SSCCE:
                        from c4d import gui, plugins, documents
                        import os
                              renderData = doc.GetActiveRenderData()
                              xResolution = int(round(renderData[c4d.RDATA_XRES]))
                              yResolution = int(round(renderData[c4d.RDATA_YRES]))
                              pathChange = False
                              if renderData[c4d.RDATA_PATH] != "":
                                  storedPath = renderData[c4d.RDATA_PATH]
                                  renderData[c4d.RDATA_PATH] =r'{0}_{1}'.format(renderData[c4d.RDATA_PATH], "extension")
                                  pathChange = True
                              renderBmp = c4d.bitmaps.BaseBitmap()
                              renderBmp.Init(x=xResolution, y=yResolution, depth=32, )
                              result = documents.RenderDocument(doc, renderData.GetData(), renderBmp, c4d.RENDERFLAGS_EXTERNAL)
                              if pathChange == True:
                                  renderData[c4d.RDATA_PATH] = storedPath
                              if result==c4d.RENDERRESULT_OK:
                                  c4d.bitmaps.ShowBitmap(renderBmp)     # show image in pictureViewer
                        Just create a new scene, save the renderoutput in some folder. If you run this script, the rendered file will actually be output to the folder. If you move the .GetData() to doc.GetActiveRenderData().GetData() and remove it from renderData.GetData(), theres no more file output.
                        Aurel
                          On 15/03/2013 at 06:21, xxxxxxxx wrote:
                          Hi Amadeo,
                          yes that is perfect, thanks.
                          I'm also very confused, I can reproduce the behavior you describe. I don't see what is wrong
                          in your code, mine works (see below). Anyway, you could still just save the image by hand. The
                          script below is doing this as well so you will end up with two images when the Save parameter
                          is checked in the render-data.
                          import os
                              rdata = doc.GetActiveRenderData().GetData()
                           **    # rdata[c4d.RDATA_SAVEIMAGE] = False**
                              xres = int(round(rdata[c4d.RDATA_XRES]))
                              yres = int(round(rdata[c4d.RDATA_YRES]))
                              path = rdata[c4d.RDATA_PATH]
                              if not path:
                                  c4d.gui.MessageDialog("no save-path specified")
                              dirname = os.path.dirname(path)
                              if not os.path.exists(dirname) :
                                  os.makedirs(dirname)
                              elif not os.path.isdir(dirname) :
                                  c4d.gui.MessageDialog("destination directory can not be created.")
                              path = '%s_extension' % path
                           **    # rdata[c4d.RDATA_PATH] = path**
                              fileformat = rdata[c4d.RDATA_FORMAT]
                              if bmp.Init(xres, yres, 32) != c4d.IMAGERESULT_OK:
                                  c4d.gui.MessageDialog("could not allocated bitmap for render.")
                              result = c4d.documents.RenderDocument(doc, rdata, bmp, c4d.RENDERFLAGS_EXTERNAL)
                              if result != c4d.RENDERRESULT_OK:
                                  c4d.gui.MessageDialog("rendering was not successful, see console.")
                                  print "rendering failed with error-code", result
                              result = bmp.Save(path, fileformat)
                              if result != c4d.IMAGERESULT_OK:
                                  c4d.gui.MessageDialog("rendered bitmap could not be saved, see console.")
                                  print "saving bitmap failed with error-code", result
                          It seems to be the setting of the RDATA_PATH, because when you uncomment the red line,
                          the RenderDocument() function does not save automatically anymore.
                          Best,
                          -Niklas
