    difference between BaseObjects???
    15 Posts 0 Posters 1.8k Views
      On 15/03/2010 at 15:06, xxxxxxxx wrote:
      also,  be sure to check all of your pointers..   for example,   if you have.....
      BaseObject * op = BaseObject::Alloc(Osphere);
      make sure you have
      if (!op) return False;   or something like it.   🙂
      ~Shawn
        On 16/03/2010 at 00:40, xxxxxxxx wrote:
        ye, i'll try the thing with GePrint.. used it before. Sometimes i just dont see the wood because of the trees 🙂
        pointers are all checked. the strange thing is that it just happens when rendering. the object itself works and i can convert (using c) and this works too... only rendering crashes...
        ello
        btw, how can i know in an object plugin if the render has been called??
          On 16/03/2010 at 00:53, xxxxxxxx wrote:
          In GetVirtualObjects() check the HierarchyHelp's GetVFlags() method.
            On 16/03/2010 at 02:12, xxxxxxxx wrote:
            ok, i managed to find what is causing the crash now..
            Here is the relevant code:
            PolygonObject*  baseMesh = static_cast<PolygonObject*>(bc->GetLink(BASEMESH,doc));
            if (!baseMesh) goto Error;
            op->NewDependenceList();
            op->AddDependence(hh,baseMesh); // <--- this is causing the crash
              On 16/03/2010 at 02:35, xxxxxxxx wrote:
              can someone point me on how exactly i can check if GetVFlags() contains VFLAG_INTERNALRENDERER or VFLAG_EXTERNALRENDERER ?? it returns 18(if rendered in editor) and 20 (if rendered in the image manager) but if i try this:
              if((hh->GetVFlags()!=18)&&(hh->GetVFlags()!=20))op->AddDependence(hh,baseMesh);
              it still crashes...
              if i comment that line out, it doesnt crash anymore, but i need that line for performance reasons
              thanks and cheers,
              ello
                On 16/03/2010 at 03:03, xxxxxxxx wrote:
                GetVFlags() returns a bit mask. You have to mask the bits you want to check (single & and single | operator).
                if (GetVFlags() & VFLAG_INTERNALRENDERER)
                 //editor rendering
                else if (GetVFlags() & VFLAG_EXTERNALRENDERER)
                 //external rendering
                  On 16/03/2010 at 03:07, xxxxxxxx wrote:
                  thank you! than it must be something other.. if i use the following line and render in the editor, it crashes:
                  if (!(hh->GetVFlags() & VFLAG_INTERNALRENDERER))op->AddDependence(hh,baseMesh);
                  if i comment the whole thing out, it renders with no problem.
                  any ideas what could cause this strange behaviout? why does commenting works, but disabling when rendering doesnt??
                  Ello
                    On 16/03/2010 at 03:38, xxxxxxxx wrote:
                    and to make it even more strange, rendering in into the image manager works, but rendering in the editor doesnt work:
                    Bool editing = TRUE;
                    if (hh->GetVFlags() & VFLAG_INTERNALRENDERER) editing = FALSE;
                    if (hh->GetVFlags() & VFLAG_EXTERNALRENDERER) editing = FALSE;
                    if (editing) op->AddDependence(hh,baseMesh);
                    else GePrint("rendering...");
                    any ideas?
                      On 16/03/2010 at 03:56, xxxxxxxx wrote:
                      Can you post a simplified version of your GetVirtualObjects() method that shows the problem?
                        On 16/03/2010 at 04:27, xxxxxxxx wrote:
                        ok, here it is.. hope it makes sense.
                        BaseObject *cloneOnMesh::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                          editing = TRUE;
                              //GePrint ("rendering in editor");
                              editing = FALSE;
                              //GePrint ("rendering in manager");
                              editing = FALSE;
                          Bool facing = FALSE;
                          BaseObject* child = NULL;
                          Bool autoCalculate = FALSE;
                          BaseObject* cloneOfBase = NULL;
                          BaseObject* baseMesh = NULL;
                          const Vector* padr;
                          const CPolygon* pol;
                          LONG numberofclones;
                          LONG maxcount;
                          BaseDocument* doc = op->GetDocument();
                          BaseContainer *bc=op->GetDataInstance();
                          BaseObject* targetHelper = NULL;
                          Bool dirty;
                          BaseObject *main = BaseObject::Alloc(Onull);
                          main->SetName(pluginName);
                          if (!main) goto Error;
                          //object which should be faced by clones
                          targetHelper = static_cast<PolygonObject*>(bc->GetLink(FACING,doc));
                          if (targetHelper) facing = TRUE;
                          //find object to be cloned
                          child = op->GetDown();
                          if(!child) goto Error;
                          //objects to place clones along
                          if (editing)
                              // start new list
                              op->AddDependence(hh, child);
                              if (facing) op->AddDependence(hh, targetHelper);
                              dirty = op->CheckCache(hh) || op->IsDirty((autoCalculate*DIRTY_MATRIX)|DIRTY_DATA|DIRTY_CHILDREN);
                              dirty = dirty || !op->CompareDependenceList();
                              //return cache
                              if (!dirty)
                                  blDelete(main);
                                  op->TouchDependenceList();
                                  return op->GetCache(hh);
                          cloneOfBase = op->GetAndCheckHierarchyClone(hh,baseMesh,HCLONE_ASPOLY,&dirty,NULL,FALSE);
                          if (!cloneOfBase) goto Error;
                          padr = ToPoint(cloneOfBase)->GetPointR();
                          pol = ToPoly(cloneOfBase)->GetPolygonR();
                          numberofclones = maxcount = ToPoly(cloneOfBase)->GetPolygonCount();
                          for (int i=0;i<numberofclones;i++)
                              // ... create clones and modify them
                          if (cloneOfBase) blDelete(cloneOfBase);
                          if (editing)
                              //if i dont do the following things the caching doesnt work
                              //actually i dont understand why i need to do this again
                          return main;
                        Error:
                          blDelete(main);
                          return NULL;
                        ello
                        edit: i updated the code and with using the GetVFlags, it works now, so i guess it must be something other in my code where i am creating the clones (i'll double check the whole stuff again)...  nevertheless if there is something generally wrong with how i use the dependeceList, it'd be great if someone can point me to it.
                        ello
