    difference between BaseObjects???
    15 Posts 0 Posters 1.3k Views
      On 14/03/2010 at 12:40, xxxxxxxx wrote:
      what do you have for "Error:"?    what is there?
      you say
      if (!cloneOfBase) goto Error;
      what comes after "Error"  ?
        On 14/03/2010 at 14:01, xxxxxxxx wrote:
        nothing special, just this to free neccessary stuff and return nothing:
        Error:
          blDelete(main);
          return NULL;
        i found that i exceeded the maximum entries, after fixing that it works.  only thing i still dont understand is why it worked for some objects and others not
          On 15/03/2010 at 14:59, xxxxxxxx wrote:
          Hi there,
          so, the issue is again fighting back in other dimensions. in the editor everything looks like it should (clones are placed properly), until i try to render it. than it crashes (sometimes with an general message, sometimes it hangs like i have to use the taskmanager to quit cinema)..
          any ideas where to search for the bug??
          ello
            On 15/03/2010 at 15:01, xxxxxxxx wrote:
            Have you tried placing some GePrint() 's in there to see where it makes it to.   This will help you figure out which code is causing the crash.
            ~Shawn
              On 15/03/2010 at 15:06, xxxxxxxx wrote:
              also,  be sure to check all of your pointers..   for example,   if you have.....
              BaseObject * op = BaseObject::Alloc(Osphere);
              make sure you have
              if (!op) return False;   or something like it.   🙂
              ~Shawn
                On 16/03/2010 at 00:40, xxxxxxxx wrote:
                ye, i'll try the thing with GePrint.. used it before. Sometimes i just dont see the wood because of the trees 🙂
                pointers are all checked. the strange thing is that it just happens when rendering. the object itself works and i can convert (using c) and this works too... only rendering crashes...
                ello
                btw, how can i know in an object plugin if the render has been called??
                  On 16/03/2010 at 00:53, xxxxxxxx wrote:
                  In GetVirtualObjects() check the HierarchyHelp's GetVFlags() method.
                    On 16/03/2010 at 02:12, xxxxxxxx wrote:
                    ok, i managed to find what is causing the crash now..
                    Here is the relevant code:
                    PolygonObject*  baseMesh = static_cast<PolygonObject*>(bc->GetLink(BASEMESH,doc));
                    if (!baseMesh) goto Error;
                    op->NewDependenceList();
                    op->AddDependence(hh,baseMesh); // <--- this is causing the crash
                      On 16/03/2010 at 02:35, xxxxxxxx wrote:
                      can someone point me on how exactly i can check if GetVFlags() contains VFLAG_INTERNALRENDERER or VFLAG_EXTERNALRENDERER ?? it returns 18(if rendered in editor) and 20 (if rendered in the image manager) but if i try this:
                      if((hh->GetVFlags()!=18)&&(hh->GetVFlags()!=20))op->AddDependence(hh,baseMesh);
                      it still crashes...
                      if i comment that line out, it doesnt crash anymore, but i need that line for performance reasons
                      thanks and cheers,
                      ello
                        On 16/03/2010 at 03:03, xxxxxxxx wrote:
                        GetVFlags() returns a bit mask. You have to mask the bits you want to check (single & and single | operator).
                        if (GetVFlags() & VFLAG_INTERNALRENDERER)
                         //editor rendering
                        else if (GetVFlags() & VFLAG_EXTERNALRENDERER)
                         //external rendering
                          On 16/03/2010 at 03:07, xxxxxxxx wrote:
                          thank you! than it must be something other.. if i use the following line and render in the editor, it crashes:
                          if (!(hh->GetVFlags() & VFLAG_INTERNALRENDERER))op->AddDependence(hh,baseMesh);
                          if i comment the whole thing out, it renders with no problem.
                          any ideas what could cause this strange behaviout? why does commenting works, but disabling when rendering doesnt??
                          Ello
                            On 16/03/2010 at 03:38, xxxxxxxx wrote:
                            and to make it even more strange, rendering in into the image manager works, but rendering in the editor doesnt work:
                            Bool editing = TRUE;
                            if (hh->GetVFlags() & VFLAG_INTERNALRENDERER) editing = FALSE;
                            if (hh->GetVFlags() & VFLAG_EXTERNALRENDERER) editing = FALSE;
                            if (editing) op->AddDependence(hh,baseMesh);
                            else GePrint("rendering...");
                            any ideas?
                              On 16/03/2010 at 03:56, xxxxxxxx wrote:
                              Can you post a simplified version of your GetVirtualObjects() method that shows the problem?
                                On 16/03/2010 at 04:27, xxxxxxxx wrote:
                                ok, here it is.. hope it makes sense.
                                BaseObject *cloneOnMesh::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                                  editing = TRUE;
                                      //GePrint ("rendering in editor");
                                      editing = FALSE;
                                      //GePrint ("rendering in manager");
                                      editing = FALSE;
                                  Bool facing = FALSE;
                                  BaseObject* child = NULL;
                                  Bool autoCalculate = FALSE;
                                  BaseObject* cloneOfBase = NULL;
                                  BaseObject* baseMesh = NULL;
                                  const Vector* padr;
                                  const CPolygon* pol;
                                  LONG numberofclones;
                                  LONG maxcount;
                                  BaseDocument* doc = op->GetDocument();
                                  BaseContainer *bc=op->GetDataInstance();
                                  BaseObject* targetHelper = NULL;
                                  Bool dirty;
                                  BaseObject *main = BaseObject::Alloc(Onull);
                                  main->SetName(pluginName);
                                  if (!main) goto Error;
                                  //object which should be faced by clones
                                  targetHelper = static_cast<PolygonObject*>(bc->GetLink(FACING,doc));
                                  if (targetHelper) facing = TRUE;
                                  //find object to be cloned
                                  child = op->GetDown();
                                  if(!child) goto Error;
                                  //objects to place clones along
                                  if (editing)
                                      // start new list
                                      op->AddDependence(hh, child);
                                      if (facing) op->AddDependence(hh, targetHelper);
                                      dirty = op->CheckCache(hh) || op->IsDirty((autoCalculate*DIRTY_MATRIX)|DIRTY_DATA|DIRTY_CHILDREN);
                                      dirty = dirty || !op->CompareDependenceList();
                                      //return cache
                                      if (!dirty)
                                          blDelete(main);
                                          op->TouchDependenceList();
                                          return op->GetCache(hh);
                                  cloneOfBase = op->GetAndCheckHierarchyClone(hh,baseMesh,HCLONE_ASPOLY,&dirty,NULL,FALSE);
                                  padr = ToPoint(cloneOfBase)->GetPointR();
                                  pol = ToPoly(cloneOfBase)->GetPolygonR();
                                  numberofclones = maxcount = ToPoly(cloneOfBase)->GetPolygonCount();
                                  for (int i=0;i<numberofclones;i++)
                                      // ... create clones and modify them
                                  if (cloneOfBase) blDelete(cloneOfBase);
                                  if (editing)
                                      //if i dont do the following things the caching doesnt work
                                      //actually i dont understand why i need to do this again
                                  return main;
                                Error:
                                  blDelete(main);
                                  return NULL;
                                ello
                                edit: i updated the code and with using the GetVFlags, it works now, so i guess it must be something other in my code where i am creating the clones (i'll double check the whole stuff again)...  nevertheless if there is something generally wrong with how i use the dependeceList, it'd be great if someone can point me to it.
                                ello
