    MAXON Unveils CINEMA 4D Release 11.5
    23 Posts 0 Posters 13.8k Views
      On 02/09/2009 at 23:42, xxxxxxxx wrote:
      That was seen but while I'm updating (necessarily) these new methods should be employed. Hey, 'Slow()' infers that the new methods are faster and I can't pass that up! 😉
        On 02/09/2009 at 23:44, xxxxxxxx wrote:
        yeah, true. i made me a bookmark in VS and will wait for the docs ^_^
        (or Matthias answer)
          On 02/09/2009 at 23:53, xxxxxxxx wrote:
          I'm coming to the conclusion that this might involve you using the previously nonrecommended VariableTag::GetDataAddressR/W() and sending it with these methods for the UVWTag. Why that makes a difference in speed is beyond me (if my assumption is correct).
            On 03/09/2009 at 03:30, xxxxxxxx wrote:
            Coming back to your questions tomorrow.
              On 03/09/2009 at 23:24, xxxxxxxx wrote:
              About GetDEnabling() and GetEnabling(), the t_data parameter is constant since CINEMA 4D R11.5.
              virtual Bool GetDEnabling(GeListNode *node, const DescID &id;,const GeData &t;_data,LONG flags,const BaseContainer *itemdesc)
                On 03/09/2009 at 23:26, xxxxxxxx wrote:
                Quote: Originally posted by kuroyume0161 on 02 September 2009
                > Does this 'RayHitID' affect GeRayColResult?
                No.
                  On 03/09/2009 at 23:33, xxxxxxxx wrote:
                  Quote: _AnimateDocument()?
                  _
                  This is now:
                  Bool ExecutePasses(BaseThread* bt, Bool animation, Bool expressions, Bool caches)
                  > Quote: _UVWTag.Set(),Get(),Cpy() : What is the void* dataptr?
                  _
                  It works now like this:
                  > \> const void \*dataptr = uvwtag- >GetDataAddressR(); \> \> for (LONG i=0; i<cnt; i++) \> { \>      UVWStruct res \>      UVWTag::Get(dataptr, i, res); \>       \>      //do something with res \> } \>
                  > Quote: _I see that a bunch of TreeViewFunctions have been made OBSOLETE and return error
                  _
                  DrawCell() is the only new OBSOLETE function for tree views.
                    > No.
                    Good. 😄
                      >> Quote: AnimateDocument()?
                      > _
                      > This is now:
                      Strange, but okay.
                      > Quote: _
                      >> Quote: UVWTag.Set(),Get(),Cpy() : What is the void* dataptr?
                      >> const void \*dataptr = uvwtag->GetDataAddressR(); \> \> for (LONG i=0; i <cnt; i++) \> { \>      UVWStruct res \>      UVWTag::Get(dataptr, i, res); \>       \>      //do something with res \> }
                      Exactly as I surmised.
                      > Quote: _
                      >> Quote: I see that a bunch of TreeViewFunctions have been made OBSOLETE and return error
                      Yes, you are correct. I hadn't noticed having not used the others.
                        On 09/09/2009 at 17:57, xxxxxxxx wrote:
                        What happened to VIDEOPOST_REFRESH?
                        Here's a code snippet that no longer compiles:
                        > \> class spBakerVP : public VideoPostData \> { \> public: \>      virtual LONG GetRenderInfo(PluginVideoPost \*node) { return VIDEOPOST_REFRESH|VIDEOPOST_STOREFRAGMENTS; } \>
                        Is there something that replaces VIDEOPOST_REFRESH? Or do I just omit it now?
                        Thanks!
                          On 10/09/2009 at 01:25, xxxxxxxx wrote:
                          Quote: _Is there something that replaces VIDEOPOST_REFRESH? Or do I just omit it now?
                          _
                          You just omit it.
                            On 22/09/2009 at 02:26, xxxxxxxx wrote:
                            The SDK docu is up:
                            CINEMA 4D R11.514 SDKdocumentation[URL-REMOVED]
