    Still can't get a 64bit version compiled
    42 Posts 0 Posters 41.3k Views
      On 12/06/2007 at 10:53, xxxxxxxx wrote:
      Ok, now got my Standard installed (woosh, 5 fu*** CDs and a Service Pack update of 500 MB. Sigh, I miss the good ol C64 days. 🙂
      Anyway, it now works to get that compiler to do what it needs. But I get a C4311 error in the TreeView Function GetId()
      The migration docs say:
      "Watch out for type cast warnings. E.g. the line LONG converted_ptr = (LONG)&data; will result in a warning warning C4311: 'type cast' : pointer truncation from 'BaseContainer *' to 'LONG'.. You need to change this code to VLONG converted_ptr = (VLONG)&data;."
      And I am sure that I changed the function in my code correctly. Here it is:
      virtual VLONG GetId(void *root, void *userdata, void *obj)
           return (VLONG)obj;
      But I still get the error? The activeobject sdk example uses it in the same way.
      Anybody a clue why it´s not working?
      Thanks!
        On 12/06/2007 at 10:59, xxxxxxxx wrote:
        That's odd. Here's how I do it - note no typecasting to VLONG though:
        #ifdef WIN64
        VLONG GetId(void* root, void* userdata, void* obj)
             return ((RuntimeItem* )obj)->GetID();
        #else
          On 12/06/2007 at 11:12, xxxxxxxx wrote:
          Howdy,
          Hmmmm, that is odd because that is exactly the same as the SDK example.
          Did the SDK project compile fine?
          Adios,
          Cactus Dan
            On 12/06/2007 at 11:15, xxxxxxxx wrote:
            Hmm, maybe your LONG value will be casted automatically to VLONG at occurance. As my object has no ID value (cannot simply add it due to stability reasons unfortunately) so I cannot use it.
            But as I said, the activeobject example also uses a direct cast of the pointer and it works for me in a R10 32-bit compile. 😕
            @Cactus: Will try a sdk compile.
              On 12/06/2007 at 11:22, xxxxxxxx wrote:
              yep, compiles just fine. Hmm, strange. Then it must be something in my code, but what could that be in such a small and straight function? It´s an old implementation, did anything change over time in the treeview handling?
                On 12/06/2007 at 11:27, xxxxxxxx wrote:
                ok, I simply got rid of the plugin and tried a compile, but now I also get 2001 and 2019 errors. I checked the installation but there was no 64-bit option. Darn, don´t tell me I missed it, I specifically kept an eye on this option during installation and wondered why it didn´t come up, but thought it may come later.
                At which point does the installer ask for it?
                  On 12/06/2007 at 11:34, xxxxxxxx wrote:
                  Howdy,
                  Yes, I missed the insallation of the 64 bit, too, and had to go back and reinstall it. :o(
                  If I remember correctly, it was an option that you had to select on one of the pages in the installer window.
                  Adios,
                  Cactus Dan
                    On 13/06/2007 at 04:51, xxxxxxxx wrote:
                    Argh, what do I need to deinstall to get to that selection window? When I only deinstall the standard edition, then at reinstalling I don´t get any chance to select anything. It simply reinstalls Visual C++ (well, I can choose if I want to also install Visual C# etc. but not the selection pages with that nice icons that I had in the first installation process.
                    thx
                      On 13/06/2007 at 05:04, xxxxxxxx wrote:
                      In vs 2005 pro you don't need to uninstall. Just put the installation dvd and select something like "add components". You will then come to an explorer-like selection tree where you have to check the appr. c++ language option (s.th. with "64bit"). don't know, if this behaviour is different in standard version.
                        On 13/06/2007 at 05:11, xxxxxxxx wrote:
                        hmm, I only have the standard edition here and here it doesn´t work that way. 😕 And yes, that selection tree is exactly what I am looking for! I got it in my first installation routine but now I don´t get it on my screen, neither with adding components nor with a complete reinstallation.
                        I have 6 CDs here, first 2 CDs for installing Visual Studio, 3 CDs for the MSDN Lib and 1 CD for NET Framework SDK (x64).
                        Is it the same in the pro version?
                          On 13/06/2007 at 05:25, xxxxxxxx wrote:
                          here is a screen of what I get when I have it installed and put the CD in.
                          - Adding/removing Features
                          - Repair/reinstall
                          - Deinstall
                            On 13/06/2007 at 05:38, xxxxxxxx wrote:
                            Ah and none of these options will bring me to a selection tree. 😕
                              On 13/06/2007 at 05:48, xxxxxxxx wrote:
                              The "Features hinzufügen oder entfernen" doesn't work? Don't know, whether the standard version will bring up a selection tree, but something should happen, where you can switch on/off the features!?
                                On 13/06/2007 at 06:02, xxxxxxxx wrote:
                                yep, I see another screen with some options. But all checkboxes. See the image. But nothing that allows me to choose specific features.
                                  On 13/06/2007 at 06:32, xxxxxxxx wrote:
                                  Anybody from MAXON? What makes me crazy is, that I can successfully compile a 64-Bit version of the Cinema 4D SDK! So it should also be possible to compile my version without problems I assume.
                                    On 13/06/2007 at 06:34, xxxxxxxx wrote:
                                    I have to check this for myself but we are kinda busy here.
                                      On 13/06/2007 at 07:09, xxxxxxxx wrote:
                                      Howdy,
                                      Hmmmmm, When I load the CD now, I get the same thing as in your attached images, but I'm afraid to try anything because it works now, and I don't want to screw anything up. :o(
                                      I had the 2005 beta version on there, so that had to be uninstalled first. But seems to me, I remember totally deleting everything and then starting fresh, just to get the option.
                                      I have another machine with windows on it, let me see what happens when I install it fresh on there. I'll have to install 2003 first, because the 2005 is an upgrade and it searches for qualifying products. :o(
                                      Adios,
                                      Cactus Dan
                                        On 13/06/2007 at 07:21, xxxxxxxx wrote:
                                        argh, that would be bad if I had to reinstall everything! 😞 Would be great if you could try on that other machine you have what it´s supposed to look like. Thank you!
                                          On 13/06/2007 at 07:54, xxxxxxxx wrote:
                                          Howdy,
                                          Crap! I can't find my 2003 product key. The original box is probably in storage somewhere. I'll have to try it later. :o(
                                          Adios,
                                          Cactus Dan
                                            On 13/06/2007 at 08:33, xxxxxxxx wrote:
                                            No problem, I just tried it on a clean windows system and I don´t get a selection tree. I only get the product key window and then the screen of the last image with the checkboxes before it installs!
                                            There is nothing to select. When I input the MSDN Library CD then I do get a selection tree, but these are all documentations only or am I missing something?
                                            I kind of really think that it´s automatically installed with VC++. hmm..
