    Still can't get a 64bit version compiled
    42 Posts 0 Posters 40.7k Views
      On 13/06/2007 at 05:11, xxxxxxxx wrote:
      hmm, I only have the standard edition here and here it doesn´t work that way. 😕 And yes, that selection tree is exactly what I am looking for! I got it in my first installation routine but now I don´t get it on my screen, neither with adding components nor with a complete reinstallation.
      I have 6 CDs here, first 2 CDs for installing Visual Studio, 3 CDs for the MSDN Lib and 1 CD for NET Framework SDK (x64).
      Is it the same in the pro version?
        On 13/06/2007 at 05:25, xxxxxxxx wrote:
        here is a screen of what I get when I have it installed and put the CD in.
        - Adding/removing Features
        - Repair/reinstall
        - Deinstall
          On 13/06/2007 at 05:38, xxxxxxxx wrote:
          Ah and none of these options will bring me to a selection tree. 😕
            On 13/06/2007 at 05:48, xxxxxxxx wrote:
            The "Features hinzufügen oder entfernen" doesn't work? Don't know, whether the standard version will bring up a selection tree, but something should happen, where you can switch on/off the features!?
              On 13/06/2007 at 06:02, xxxxxxxx wrote:
              yep, I see another screen with some options. But all checkboxes. See the image. But nothing that allows me to choose specific features.
                On 13/06/2007 at 06:32, xxxxxxxx wrote:
                Anybody from MAXON? What makes me crazy is, that I can successfully compile a 64-Bit version of the Cinema 4D SDK! So it should also be possible to compile my version without problems I assume.
                  On 13/06/2007 at 06:34, xxxxxxxx wrote:
                  I have to check this for myself but we are kinda busy here.
                    On 13/06/2007 at 07:09, xxxxxxxx wrote:
                    Howdy,
                    Hmmmmm, When I load the CD now, I get the same thing as in your attached images, but I'm afraid to try anything because it works now, and I don't want to screw anything up. :o(
                    I had the 2005 beta version on there, so that had to be uninstalled first. But seems to me, I remember totally deleting everything and then starting fresh, just to get the option.
                    I have another machine with windows on it, let me see what happens when I install it fresh on there. I'll have to install 2003 first, because the 2005 is an upgrade and it searches for qualifying products. :o(
                    Adios,
                    Cactus Dan
                      On 13/06/2007 at 07:21, xxxxxxxx wrote:
                      argh, that would be bad if I had to reinstall everything! 😞 Would be great if you could try on that other machine you have what it´s supposed to look like. Thank you!
                        On 13/06/2007 at 07:54, xxxxxxxx wrote:
                        Howdy,
                        Crap! I can't find my 2003 product key. The original box is probably in storage somewhere. I'll have to try it later. :o(
                        Adios,
                        Cactus Dan
                          On 13/06/2007 at 08:33, xxxxxxxx wrote:
                          No problem, I just tried it on a clean windows system and I don´t get a selection tree. I only get the product key window and then the screen of the last image with the checkboxes before it installs!
                          There is nothing to select. When I input the MSDN Library CD then I do get a selection tree, but these are all documentations only or am I missing something?
                          I kind of really think that it´s automatically installed with VC++. hmm..
                            On 13/06/2007 at 09:37, xxxxxxxx wrote:
                            Howdy,
                            Well, I do remember a checkbox somewhere for 64bit when installing, but that could be from back when I downloaded and installed the 2005 beta. My memory isn't what it used to be (alzheimer's you know). :oD
                            But if the SDK project compiles fine, then your code should also. Seems I had that same problem with the tree view function, and to remedy that, I just opened the SDK project, copied all the code inside that tree view function and pasted it over the code inside my tree view function, and then it compiled. ;o)
                            I only compile 64bit in 2005. I'm still using 2003 for the 32bit, so I always have two different projects in two separate C4D folders. But none of my plugins are using anything in the api that has changed in R10, so I'm still compiling them in R9 and just testing them in R10.
                            Adios,
                            Cactus Dan
                              On 13/06/2007 at 10:19, xxxxxxxx wrote:
                              ok, I´ve added some command line options and now it is working as expected. It was the problems that Remo quoted plus some other that were in the sdk but not in my project. God bless MS! 😄
                              Thank you all for your help! Highly appreciated.
                                On 13/06/2007 at 11:51, xxxxxxxx wrote:
                                Nice. Maybe you now have a little time to look at my CW problem thread? 🙂
