    Still can't get a 64bit version compiled
    42 Posts 0 Posters 41.3k Views
      On 16/05/2007 at 07:09, xxxxxxxx wrote:
      hmm, when I reinstall, I don´t get an option for 64-Bit in my express installation. Was it the Visual C++ express installation where this happened or is it the platform SDK that you mean?
        On 16/05/2007 at 07:12, xxxxxxxx wrote:
        Howdy,
        AH! The "Express" version doesn't have the 64bit option. You need at least the "Standard" version. 😞
        Adios,
        Cactus Dan
          On 16/05/2007 at 07:37, xxxxxxxx wrote:
          As Cactus Dan says. :E
            On 16/05/2007 at 07:42, xxxxxxxx wrote:
            no problem robert, I was too lazy in the past to buy the standard version. Now that´s a good reason to finally do so. 😄 thx!
              On 16/05/2007 at 07:47, xxxxxxxx wrote:
              Howdy,
              There was an upgrade from MSVC++.net 2003 to MSVC++ 2005 Standard that saved me some money on it. 😉
              You may also have some sort of upgrade option.
              Adios,
              Cactus Dan
                On 16/05/2007 at 07:54, xxxxxxxx wrote:
                thanks for the hint. I´ll be checking on this. 🙂
                  On 12/06/2007 at 10:53, xxxxxxxx wrote:
                  Ok, now got my Standard installed (woosh, 5 fu*** CDs and a Service Pack update of 500 MB. Sigh, I miss the good ol C64 days. 🙂
                  Anyway, it now works to get that compiler to do what it needs. But I get a C4311 error in the TreeView Function GetId()
                  The migration docs say:
                  "Watch out for type cast warnings. E.g. the line LONG converted_ptr = (LONG)&data; will result in a warning warning C4311: 'type cast' : pointer truncation from 'BaseContainer *' to 'LONG'.. You need to change this code to VLONG converted_ptr = (VLONG)&data;."
                  And I am sure that I changed the function in my code correctly. Here it is:
                  virtual VLONG GetId(void *root, void *userdata, void *obj)
                       return (VLONG)obj;
                  But I still get the error? The activeobject sdk example uses it in the same way.
                  Anybody a clue why it´s not working?
                  Thanks!
                    On 12/06/2007 at 10:59, xxxxxxxx wrote:
                    That's odd. Here's how I do it - note no typecasting to VLONG though:
                    #ifdef WIN64
                    VLONG GetId(void* root, void* userdata, void* obj)
                         return ((RuntimeItem* )obj)->GetID();
                    #else
                      On 12/06/2007 at 11:12, xxxxxxxx wrote:
                      Howdy,
                      Hmmmm, that is odd because that is exactly the same as the SDK example.
                      Did the SDK project compile fine?
                      Adios,
                      Cactus Dan
                        On 12/06/2007 at 11:15, xxxxxxxx wrote:
                        Hmm, maybe your LONG value will be casted automatically to VLONG at occurance. As my object has no ID value (cannot simply add it due to stability reasons unfortunately) so I cannot use it.
                        But as I said, the activeobject example also uses a direct cast of the pointer and it works for me in a R10 32-bit compile. 😕
                        @Cactus: Will try a sdk compile.
                          On 12/06/2007 at 11:22, xxxxxxxx wrote:
                          yep, compiles just fine. Hmm, strange. Then it must be something in my code, but what could that be in such a small and straight function? It´s an old implementation, did anything change over time in the treeview handling?
                            On 12/06/2007 at 11:27, xxxxxxxx wrote:
                            ok, I simply got rid of the plugin and tried a compile, but now I also get 2001 and 2019 errors. I checked the installation but there was no 64-bit option. Darn, don´t tell me I missed it, I specifically kept an eye on this option during installation and wondered why it didn´t come up, but thought it may come later.
                            At which point does the installer ask for it?
                              On 12/06/2007 at 11:34, xxxxxxxx wrote:
                              Howdy,
                              Yes, I missed the insallation of the 64 bit, too, and had to go back and reinstall it. :o(
                              If I remember correctly, it was an option that you had to select on one of the pages in the installer window.
                              Adios,
                              Cactus Dan
                                On 13/06/2007 at 04:51, xxxxxxxx wrote:
                                Argh, what do I need to deinstall to get to that selection window? When I only deinstall the standard edition, then at reinstalling I don´t get any chance to select anything. It simply reinstalls Visual C++ (well, I can choose if I want to also install Visual C# etc. but not the selection pages with that nice icons that I had in the first installation process.
                                thx
                                  On 13/06/2007 at 05:04, xxxxxxxx wrote:
                                  In vs 2005 pro you don't need to uninstall. Just put the installation dvd and select something like "add components". You will then come to an explorer-like selection tree where you have to check the appr. c++ language option (s.th. with "64bit"). don't know, if this behaviour is different in standard version.
                                    On 13/06/2007 at 05:11, xxxxxxxx wrote:
                                    hmm, I only have the standard edition here and here it doesn´t work that way. 😕 And yes, that selection tree is exactly what I am looking for! I got it in my first installation routine but now I don´t get it on my screen, neither with adding components nor with a complete reinstallation.
                                    I have 6 CDs here, first 2 CDs for installing Visual Studio, 3 CDs for the MSDN Lib and 1 CD for NET Framework SDK (x64).
                                    Is it the same in the pro version?
                                      On 13/06/2007 at 05:25, xxxxxxxx wrote:
                                      here is a screen of what I get when I have it installed and put the CD in.
                                      - Adding/removing Features
                                      - Repair/reinstall
                                      - Deinstall
                                        On 13/06/2007 at 05:38, xxxxxxxx wrote:
                                        Ah and none of these options will bring me to a selection tree. 😕
                                          On 13/06/2007 at 05:48, xxxxxxxx wrote:
                                          The "Features hinzufügen oder entfernen" doesn't work? Don't know, whether the standard version will bring up a selection tree, but something should happen, where you can switch on/off the features!?
                                            On 13/06/2007 at 06:02, xxxxxxxx wrote:
                                            yep, I see another screen with some options. But all checkboxes. See the image. But nothing that allows me to choose specific features.
