    GeListNode from ShaderData::Read function does not have a document?
    c++
    3 Posts 2 Posters 840 Views 1 Watching
    • E Offline
      ECHekman
      Im loading in c4d project and want to get the Document the GeListNode belongs to, but i am getting a nullptr back.
      Is it expected for certain ShaderDatas not to be associated with a document?
      Code looks something like this:
      Bool SomeShaderDataPlugin::Read(GeListNode* node, HyperFile* hf, Int32 level)
      	const BaseDocument* bd = node->GetDocument(); //bd is nullptr sometimes for some ShaderDatas
      	return SUPER::Read(node, hf, level);
      • E Offline
        ECHekman
        After some digging it seems only some ShaderDatas dont have their document set. Other do have it.
        However after the Read, c4d will set the document at some point, because in the ::Message() function GetDocument does return a basedocument.
        • M Offline
          m_adam
          yes, this is expected, and documented in NodeData::Read() / NodeData::Write() Manual. With that's said Read/Write is supposed to serialize data of your object (most of the time member variable) to the c4d file (the HyperFile), so accessing the BaseDocument is a sign of a bad design.
          May I ask why do you really want to access the BaseDocument in the Read function?
          Maxime
          edit (@ferdinand): Just to be clear here, as we briefly talked about this in our morning meeting, what the docs write there is in a certain sense legacy information. When a branch, e.g., the Xbase (shader) branch of a material is being deserialized, the to be deserialized node is inserted into the branch and with that will have access to a document.
          But what @m_adam wrote is of course true, the document in this context is the fruit from the forbidden tree, as the node is not yet fully deserialized and certain parts of the GeListHead::Read, GeListNode::Read, BaseList2D::Read, ..., YourPluginLayer::Read deserialization chain might pull all sorts of tricks to carry out the deserialization, including temporarily removing the node from the scene graph.
          The documentation is therefore effectively still correct, as deserializing a node should never rely on the document context and accessing the document is forbidden in that context.
