    customize ZBrush add-on
    Scheduled Pinned Locked Moved ZBrush SDK
    windows2024
    3 Posts 2 Posters 2.0k Views 1 Watching
    • L Offline
      LeonGao007
      I would like to implement an add-on that should launch a background thread when ZBrush starts, and can export current scene to a common 3D model format to a specified path. This exporting function will run in the background thread and be triggered by an external program, not ZBrush.
      I looked into GoZ and ZScript, it seems they do not meet my requirements.
      Does anyone have any ideas?
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        m_adam @LeonGao007
        @LeonGao007 Welcome to the Maxon developers forum and its community, it is great to have you with us!
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        I've reached Zbrush developers, however I doubt what you ask for is possible.
        First of all exporting Zbrush scene in a background thread, this would imply you copy the full scene in memory in order to avoid any issue if the user edits the scene while your edit it. I'm not an expert at it, but I do not think that Zbrush support that at all.
        Exporting current scene to a common 3D model format to a specific path, this is possible via Script however from what I understand if the export plugin, trigger a popup you are screwed as you can see here Zplugin:USD Format:Save set save location through zscript.
        Finally regarding GoZ, this is a custom file format, it work by saving everything into a given folder (in the temp folder), then call an executable that will load this custom GoZ file format.
        So from my perspective what you are asking for is not possible, but please wait until I confirm that with a Zbrush developers.
        L 1 Reply Last reply Reply Quote 0
        • L Offline
          LeonGao007 @m_adam
          @m_adam thanks for your prompt response. I'm looking forward to hearing from you.
