    use thicken generator inside a python generator
    Scheduled Pinned Locked Moved Bugs
    windows2024python
    4 Posts 2 Posters 1.4k Views 1 Watching
    • D Offline
      datamilch
      hi there,
      the thicken generator object is a super cool and powerful tool. i'd like to use it inside of a python generator object, to create some more complex geometry. for this i need some of the selection options of the thicken generator. but activating e.g. 'shell' selection from within the python generator will mess up the output geometry of the thicken object and not generate any polygon selection tag. see attached c4d file.
      after converting the python generator you have access to the built hierarchy and the generated thicken generator. when you select it and then try to activate some selection options ther will be no selection tags created. so it looks like something in the thicken generator is broken/uncomplete, when it is created within a python generator object.
      is there any way to make this work, or is this a special case/limitation?
      def main() -> c4d.BaseObject:
          source_obj = c4d.BaseObject( 5170 )
          source_obj[c4d.PRIM_CYLINDER_CAPS] = False
          thicken = c4d.BaseObject( 1060179 )
          source_obj.InsertUnder( thicken )
          thicken[c4d.SOLIDIFYGENERATOR_SELECTION_POLYGON_BOUNDARY] = 1 # does not create tag, will mess up (delete) geo of the selected polys
          return thicken
      thicken test 01.c4d
      • D Offline
        datamilch
        circumvented the problem by generating 3 thicken objects - one for each surface part (shell, start cap, end cap). then created selection tags and stitched everything together with a connector object.
        • i_mazlovI Offline
          i_mazlov @datamilch
          Hi @datamilch ,
          Thanks for reaching out to us and special thanks for sharing your workaround with the community!
          It looks like the code for the selections in the Thicken object is not optimized to be triggered from the python. I've created a dedicated bug report for this issue in our internal bug tracking system: ITEM#537292. Thanks for bringing this topic up to us!
          Ilia
          D 1 Reply Last reply Reply Quote 0
          • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
          • D Offline
            datamilch @i_mazlov
            hi @i_mazlov,
            ok, good to know.
            i also tried to insert the thicken generator into a temp_doc, activating the selections and executing passes. but that didn't work either.
