    How to store BaseShader to HyperFile
    windowspython2024
    7 Posts 2 Posters 1.7k Views 2 Watching
    • gheyretG Offline
      gheyret
      I'm trying to store the Shaders created in my plugin into Hyperfile for next use.
      I can store the GetDataInstance() of the shader, but when I encounter layer shader, the internal shaders can't be stored.
      So I'm wondering if I can store the shader directly to the hyperfile.
      www.boghma.com
        ferdinand @gheyret
        Hey @gheyret,
        Thank you for reaching out to us. To store multiple nodes in a HyperFile, you can use HyperFile.WriteData as GeData can wrap a BaseList2D. The alternative would be to just use C4DAtom.Write or .WriteObject. What to use concretely depends a bit on what you are doing.
        In general I would also avoid serializing nodes myself, but in some cases it can be necessary, it again depends on the case.
        gheyretG 1 Reply Last reply Reply Quote 0
        • gheyretG Offline
          gheyret @ferdinand
          Hi @ferdinand
          Thank you for your reply.
          I try to use HyperFile.WriteData to store my shader and save it on my local path.
          And when I try to read the hyperfile to get that shader, that return None for me.
          This is my test code:
          key = 12345
          path = "..."
          def store_shader(data):
              hf = c4d.storage.HyperFile()
              if hf.Open(ident=key, filename=path, mode=c4d.FILEOPEN_WRITE, error_dialog=c4d.FILEDIALOG_NONE):
                  hf.WriteData(data)
                  hf.Close()
              return False
          def read_shader():
              if hf.Open(ident=key, filename=path, mode=c4d.FILEOPEN_READ, error_dialog=c4d.FILEDIALOG_NONE):
                  data = hf.ReadData()
                  hf.Close()
                  return data
              return None
              shader = doc.GetActiveMaterial()[c4d.MATERIAL_COLOR_SHADER]
              # this will print True
              print(store_shader(shader))
              # this will print None, the shader is missing?
              print(read_shader())
          www.boghma.com
            ferdinand @gheyret
            Hey @gheyret,
            sorry, today is a bank holiday in Germany, I just answered this on the side. This probably means nodes have not been implemented in the Python wrapper for HyerFile.WriteData. I would try my luck with the C4DAtom methods then.
            • gheyretG Offline
              gheyret @ferdinand
              it's okay, It's not a big rush for me.
              Hope you enjoy your holiday.
              Cheers~🍻
              www.boghma.com
                ferdinand @gheyret
                Hey @gheyret,
                okay, I had a brief look, and I could not get the shader deserialization to work either. Not sure why, I think I was passing the wrong disk level. This is too much of a complex problem as that I could answer this on the side, we will have a closer look after our company meeting.
                I would recommend to use c4d files in the mean time to store your shaders as materials in a file. Alternatively, you could also store them as assets if you want to get all fancy.
                • gheyretG Offline
                  gheyret @ferdinand
                  Hi @ferdinand ,
                  Yeah! I'm actually considering saving the shader to .c4d file as well.
                  But it would be great if posible to store BaseList2D in Hyperfile.
                  Thank you!
                  Cheers!
                  www.boghma.com
