    Nothing happen when runing generate_solution_win.bat
    windowsc++2024
    9 Posts 2 Posters 1.7k Views 2 Watching
    • gheyretG Offline
      gheyret
      Hi Community,
      I am trying to take the first step with the C++ plugin, Then I tried to create the plugins.sln file by holding down the steps of the C++ SDK on Windows.
      And I run the generate_solution_win.bat file but nothing happen, just a window popup and close qucikly.
      is that i'm missing something or do something wrong?
      www.boghma.com
        ferdinand @gheyret
        Hey @gheyret,
        Thank your for reaching out to us. That is a bit odd but I have hunch to what could be the issue. Try to replace the content of the file with this:
        @echo off
        setlocal
        :: Check if the project tool exists.
        set "ptool=%~dp0tools\projecttool\kernel_app_64bit.exe"
        if not exist "%ptool%" (
            echo "Project tool not found at '%ptool%'."
            exit /b 1
        :: Run the project tool on the project and create a symbolic link to the solution.
        echo Running project tool on project at '%~dp0'.
        %ptool% g_updateproject=%~dp0
        endlocal
        I.e., I removed the bit where it creates a symbolic link to the solution file for you. When even this does not work, I would have to ask you to try to run the project tool manually. This could also be something %~dp0 related. Do you have any non-unicode or whitespace characters in your paths? The windows terminal does not like them, and you cannot properly escape them in batch files.
        d:\projects\cinema\2024_SDK                   #OK  - Just ASCII, no whitespaces
        d:\projects\cinema and stuff\2024_SDK         #NOK - white spaces in path
        d:\projects\cínemüß\2024_SDK                  #NOK - Non-ASCII characters, can lead to troubles too
        gheyretG 1 Reply Last reply Reply Quote 0
        • gheyretG Offline
          gheyret @ferdinand
          Hi @ferdinand,
          I replace the content, but it's same as the video on top.
          www.boghma.com
            Hm,
            hard to trouble shoot, have you check the paths?
            gheyretG 3 Replies Last reply Reply Quote 0
            • gheyretG Offline
              gheyret @ferdinand
              Yes, And I'm sure I don't have any non-unicode character in my path
              www.boghma.com
              • gheyretG Offline
                gheyret @ferdinand
                Oh! sorry for that, it's white space!
                www.boghma.com
                • gheyretG Offline
                  gheyret @ferdinand
                  It works correctly!
                  Thank you so much for your help!
                  www.boghma.com
                    Yeah, no worries, and I am glad that it works for you. The windows terminal also drives me nuts every time (I in fact hate ALL terminals equally 😄 ).
                    Maybe I'll add a little warning to the getting started guides about this ...
                    • gheyretG Offline
                      gheyret @ferdinand
                      Yeah, it's a little bit anoying, but the problem's solve!
                      Ready for rocking with C++! wohoo~ 😀
                      www.boghma.com
