    Xref object Make it Editable
    2024python
    3 Posts 2 Posters 1.0k Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      There are several XRF objects in the document, and I want to implement the Make it Editable like in the XRF manager or in Object manager.This is the method I used, but the result is incorrect
      res = c4d.utils.SendModelingCommand(
                      command=c4d.MCOMMAND_MAKEEDITABLE,
                      list=xref_objs,
                      mode=c4d.MODELINGCOMMANDMODE_ALL,
                      bc=c4d.BaseContainer(),
                      doc=backup_doc)
      for obj in res:
          backup_doc.InsertObject(obj)
      Thanks for any help!
      相信我,可以的!
        ferdinand @chuanzhen
        Hey @chuanzhen,
        Thank you for reaching out to us. These two, "Make Editable" the command as for example exposed by the context menu of the Object Manager, and "Make Editable" the Xref Manager menu entry, are entirely different things.
        Moreover, we do not expose GUIs and their functionalities (e.g., there are no "ObjectManager" or "MaterialManager" classes) but the APIs behind them. This usually means that some finer details of a niche-feature-manager remain unexposed. This is here the case, the XRef Manager functionalities are not exposed.
        To emulate this function, you would have to traverse the object tree yourself and then for each XRef read the Reference field, load the referenced document, grab its object content and place it in your scene, e.g., replace the Xref with it.
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @ferdinand
          @ferdinand Thanks for your reply!
          相信我,可以的!
