    Which are tool plugin flags for Brush Selection tool, even Move tool?
    2024python
    5 Posts 2 Posters 1.6k Views
    • L Offline
      LingZA
      Which are tool plugin flags abount Brush Selection tool, even Move tool?
      I simulate the selection actions about Selection tool, even Move tool in my tool plugins. I want to get clear tool plugin flags about them.
      • L Offline
        LingZA
        • i_mazlovI Offline
          i_mazlov
          Hi @LingZA ,
          Unfortunately I'm struggling to understand what you mean. Could you please elaborate on your use case and what the actual question is?
          If you're trying to make a tool that would actually behave as a selection tool, you should consider using the PLUGINFLAG_TOOL_IS_SELECTION flag.
          Note that flags can be combined together as follows:
          c4d.PLUGINFLAG_TOOL_IS_SELECTION | c4d.PLUGINFLAG_TOOL_EDITSTATES
          Ilia
          L 1 Reply Last reply Reply Quote 0
          • L Offline
            LingZA @i_mazlov
            Thanks, @i_mazlov.
            I know what you say. But that is not my question.
            I don't make the selection tool but the tools maybe like modeling tools.
            PLUGINFLAG_TOOL_EVALUATEHANDLES means that I can see and drag the handles of the coordinate system.
            PLUGINFLAG_TOOL_SINGLECLICK means that I can select the components (points, edges or polygons) of the object or the object itself.
            PLUGINFLAG_TOOL_HIGHLIGHT means that I can highlight the components before I select them to perform a pre-select operation.
            PLUGINFLAG_TOOL_SNAPSETTINGS means that I can run the tool with snapping operations.
            But I don't know the performance of PLUGINFLAG_TOOL_DRAW_MULTIPLANE, PLUGINFLAG_TOOL_EDITSTATES, PLUGINFLAG_TOOL_SWITCHACTION and PLUGINFLAG_TOOL_NO_TOPOLOGY_EDIT.
            But I also want to know the difference between PLUGINFLAG_TOOL_TWEAK and PLUGINFLAG_TOOL_TWEAK_NO_HIGHLIGHT.
            You know,
            before we use move tool to move sometings, we select them first by using the move tool itself.
            before we use modeling tool to make a modeling operation, we select the components by using the modeling tool itself.
            That are selection operations of them.
            I want to simulate the selection operations like them.
            • L LingZA deleted this topic on
            • ferdinandF ferdinand restored this topic on
            • i_mazlovI Offline
              i_mazlov
              Hi @LingZA ,
              Sorry for the delayed answer.
              Could you please explain the result that you're trying to achieve?
              It looks now that you would like to implement a modeling tool similar to Bevel, when you would like to firstly select points/edges/polys and secondly apply some changes to them. If that's the case, then you need to implement the part of your tool that selects objects. Please have a look at BaseSelect. You can also explore Flatten Polygons example.
              You can find a sample code snippet below that simply selects all of the edges of the polygon. You need to be in "Edges" mode for that. Additionally you can emulate the polygon highlighting yourself.
              Regarding the flags:
              PLUGINFLAG_TOOL_EDITSTATES - designates that the tool supports deformed editing
              PLUGINFLAG_TOOL_SWITCHACTION - allows to adjust the active tool. This works in tandem with the MSG_TOOL_SWITCHACTION message type. Namely, when the modifier (aka qualifier) key is pressed, the plugin receives this message such that it can react on this key press.
              PLUGINFLAG_TOOL_NO_TOPOLOGY_EDIT - flag that informs cinema that the tool doesn't perform any topology modifications (i.e. doesn't add/remove/reassign of the polygons)
              PLUGINFLAG_TOOL_TWEAK - if you click on the element that isn't currently selected, it will select it for you (so your tool can work with this selection), and will deselect it once your tool finishes
              PLUGINFLAG_TOOL_TWEAK_NO_HIGHLIGHT - same as above but without highlighting the temporarily selected element
              PLUGINFLAG_TOOL_DRAW_MULTIPLANE - some legacy flag that is (or at least should be) deprecated
              Ilia
              PLUGIN_ID = 1234321 # Be sure to use a unique ID obtained from www.plugincafe.com
              class MyTool(c4d.plugins.ToolData):
              	def __init__(self):
              		self.selectionRadius = 10
              		self.highlightedPolygon: int = -1
              	def GetState(self, doc):
              		if doc.GetMode() != c4d.Medges:
              			return False
              		return c4d.CMD_ENABLED
              	def MouseInput(self, doc, data, bd, win, msg):
              		# Only handle left click
              		if msg[c4d.BFM_INPUT_CHANNEL] != c4d.BFM_INPUT_MOUSELEFT:
              		# Get active object
              		op = doc.GetActiveObject()
              		if not op: return True
              		if self.highlightedPolygon < 0:
              		# Initialize helping Neighbor struct
              		nbr = c4d.utils.Neighbor()
              		nbr.Init(op)
              		polyInfo = nbr.GetPolyInfo(self.highlightedPolygon)  # get polygon information
              		bs = c4d.BaseSelect()
              		opPolygon: c4d.CPolygon = op.GetPolygon(self.highlightedPolygon)
              		# Iterate over sides
              		for side in range(4):
              			# Skip last edge if polygon is a triangle
              			if side == 2 and opPolygon.c == opPolygon.d:
              				continue
              			# Select edge
              			edgeIdx = polyInfo['edge'][side]
              			bs.Select(edgeIdx)
              		# Apply selection
              		op.SetSelectedEdges(nbr, bs, c4d.EDGESELECTIONTYPE_SELECTION)
              	def Draw(self, doc, data, bd, bh, bt, flags):
              		selectionColor = c4d.GetViewColor(c4d.VIEWCOLOR_SELECTION_PREVIEW)
              		if flags & c4d.TOOLDRAWFLAGS_HIGHLIGHT:  # if the DrawPass is the Highlight one
              			if self.highlightedPolygon >= 0:
              				# Get active object
              				bd.SetMatrix_Matrix(op, op.GetMg())  # draw in global coordinates
              				# Get points and polygon from the object
              				opPoints: list[c4d.Vector] = op.GetAllPoints()
              				points = [opPoints[idx] for idx in (opPolygon.a, opPolygon.b, opPolygon.c, opPolygon.d)]
              				colors = [selectionColor for _ in points]
              				if len(points) == 3 or len(points) == 4:
              					bd.DrawPolygon(points, colors)  # draw the polygon highlight
              					# Draw the outline
              					bd.SetPen(c4d.Vector(0, 1, 0))
              					for point1Idx in range(-1, len(points) - 1):
              						point1, point2 = points[point1Idx], points[point1Idx + 1]
              						bd.DrawLine(point1, point2, c4d.NOCLIP_D)
              		return c4d.TOOLDRAW_HIGHLIGHTS
              	def GetCursorInfo(self, doc, data, bd, x, y, bc):
              		self.highlightedPolygon = -1
              		# If the cursor has left a user area, simply return True
              		if bc.GetId() == c4d.BFM_CURSORINFO_REMOVE or doc.GetMode() != c4d.Medges:
              		# Get active object
              		# Calculates the width and height of the screen
              		bd: c4d.BaseDraw = doc.GetActiveBaseDraw()
              		frame = bd.GetFrame()
              		l, r, t, b = frame["cl"], frame["cr"], frame["ct"], frame["cb"]
              		width, height = r - l + 1, b - t + 1
              		# Initialize viewport select
              		vpSelect = c4d.utils.ViewportSelect()
              		vpSelect.Init(width, height, bd, [op], c4d.Medges, True, c4d.VIEWPORTSELECTFLAGS_IGNORE_HIDDEN_SEL)
              		c4d.SpecialEventAdd(c4d.EVMSG_UPDATEHIGHLIGHT)  # pushing highlighting event to cinema
              		# Looking for the nearest polygon and saving it's index in self.highlightedPolygon
              		polyInfo = vpSelect.GetNearestPolygon(op, int(x), int(y), self.selectionRadius)
              		if not polyInfo or 'i' not in polyInfo:
              		polygonIdx = polyInfo['i']
              		if (polygonIdx < 0 or polygonIdx >= op.GetPolygonCount()):
              		self.highlightedPolygon = polygonIdx
              	c4d.plugins.RegisterToolPlugin(id=PLUGIN_ID, str="MyTool", info=0, icon=None, help="", dat=MyTool())
