    Running Automatic UV for all objects
    pythonwindows
    3 Posts 3 Posters 1.8k Views 3 Watching
    • B Offline
      BineeMan
      Hello everyone!
      I'm making a Python script that applies Automatic UV algorithm for each object in the scene. This algorithm is used for making UVs for lightmaps for hundreds of objects for game engines. It means that I have two UVWs on each object: one for a texture and one for a lightmap.
      The problem is that I don't know how to run "Automatic UV" algorithm with "Packed" mode for the object, I haven't found how to do this in the documentation.
          objects = doc.GetObjects() #getting all objects
          for obj in objects:
              tags = obj.GetTags() #getting all tags
              lightmapTagIndex = 0
              i = 0
              for tag in tags: #finding tag with "Lightmap" name to avoid modifying UV tag for texture
                  if str(tag.GetName()) == "Lightmap":
                      lightmapTagIndex = i
                      break
                  i += 1
              doc.SetActiveObject(obj, c4d.SELECTION_NEW) #selecting our object
              doc.SetActiveTag(tags[lightmapTagIndex], c4d.SELECTION_NEW) #selecting Lightmap tag
              #Pseudo Code: obj.RunAutimaticUV(mode.Packed)
      if __name__=='__main__':
      I'm referencing to this Cinema4D's function:
      Thank you for your help.
      DunhouD 1 Reply Last reply Reply Quote 1
      • DunhouD Offline
        Dunhou @BineeMan
        @BineeMan here is my unwrap script, but I didn't find how to change to cubic or angle mode, there seems not a symbol in the .h file.
        MCOMMAND_AUTOMATICUV = 1053624
        def unwrap(node: c4d.BaseObject):
            doc = node.GetDocument()
            if isinstance(node, c4d.PolygonObject) and node.GetTag(c4d.Tuvw) is not None:
                pass
            elif isinstance(node, c4d.PolygonObject) and node.GetTag(c4d.Tuvw) is None:
                doc.AddUndo(c4d.UNDOTYPE_CHANGE, node)
                settings = c4d.BaseContainer()
                settings[c4d.MDATA_AUTOMATICUV_TAGINDEX] = 0
                settings[c4d.MDATA_AUTOMATICUV_FORCESEAMS] = False
                settings[c4d.MDATA_AUTOMATICUV_OVERLAPMIRRORED] = False
                settings[c4d.MDATA_AUTOMATICUV_OVERLAPIDENTICAL] = False
                settings[c4d.MDATA_AUTOMATICUV_SPACING] = 0.01
                settings[c4d.MDATA_AUTOMATICUV_USENORMALS] = True
                settings[c4d.MDATA_AUTOMATICUV_SPACINGASPECT] = 1.0
                c4d.utils.SendModelingCommand(command = MCOMMAND_AUTOMATICUV,
                                            list=[node],
                                            mode=c4d.MODELINGCOMMANDMODE_POLYGONSELECTION,
                                            bc=settings,
                                            doc=doc)
        def do_it():
            for node in doc.GetActiveObjects(0):
                unwrap(node)
            do_it()
        https://boghma.com
        https://github.com/DunHouGo
        • M Offline
          m_adam
          Hi @BineeMan sorry for the late reply I was pretty busy Friday and thanks @Dunhou for demonstrating how Packed Auto UV work.
          For Cubic and Angle you need to use c4d.modules.bodypaint.CallUVComman as demonstrated in the call_uv_command_ example.
          So for the Angle automatic UV you need to use the command ID c4d.UVCOMMAND_OPTIMALMAPPING with the next parameters:
          • c4d.OPTIMALMAPPING_PRESERVEORIENTATION # Preserve Orientation
          • c4d.OPTIMALMAPPING_STRETCHTOFIT # Stretch to Fit
          • c4d.OPTIMALMAPPING_DISTORTION # Maximu, Distortion
          • c4d.OPTIMALMAPPING_RELAXCOUNT # Relaxation Steps
          • c4d.OPTIMALMAPPING_SPACING # Spacing
          And for the Cubic automatic UV you need to use the command ID c4d.UVCOMMAND_OPTIMALCUBICMAPPING with the next parameters:
          • c4d.OPTIMALMAPPING_TWOD # 2D
          • c4d.OPTIMALMAPPING_AREAFAK # Maximum Area Factor
          • ferdinandF ferdinand forked this topic on
