    How to run UVCOMMAND_OPTIMALCUBICMAPPING
    4 Posts 2 Posters 982 Views 1 Watching
    This topic was forked from Running Automatic UV for all objects ferdinand
    • A Offline
      ADCMHI
      @m_adam
      Hi!
      I'm trying to apply UVW mapping to child objects of an FBX file imported into Cinema 4D using this script.
      While I can assign UVW coordinates, the automatic cubic UV unwrapping isn't working. Can you advise on what modifications are needed to achieve this?
      from c4d import utils
      def apply_optimal_cubic_uv(obj, doc):
          if obj.GetType() == c4d.Opolygon:
              # UVWタグがなければ作成
              if not obj.GetTag(c4d.Tuvw):
                  uvw_tag = c4d.UVWTag(obj.GetPolygonCount())
                  obj.InsertTag(uvw_tag)
              # オブジェクトを選択
              doc.SetActiveObject(obj, c4d.SELECTION_NEW)
              # 最適化されたキュービックUVマッピングを適用
              settings = c4d.BaseContainer()
              settings[c4d.OPTIMALMAPPING_PRESERVEORIENTATION] = True  # 向きを保持
              settings[c4d.OPTIMALMAPPING_STRETCHTOFIT] = False  # ストレッチフィット
              settings[c4d.OPTIMALMAPPING_TWOD] = False  # 2D最適化
              settings[c4d.OPTIMALMAPPING_AREAFAK] = 0.0
              settings[c4d.OPTIMALMAPPING_RELAXCOUNT] = 0  # リラックス回数
              settings[c4d.OPTIMALMAPPING_SPACING] = 0.02  # スペーシング
              res = utils.SendModelingCommand(
                  command=c4d.UVCOMMAND_OPTIMALCUBICMAPPING,
                  list=[obj],
                  mode=c4d.MODELINGCOMMANDMODE_ALL,
                  bc=settings,
                  doc=doc
              if not res:
                  print("Failed to apply optimal cubic mapping to {}".format(obj.GetName()))
          if not doc:
          doc.StartUndo()
          objects = doc.GetObjects()  # シーン内の全オブジェクトを取得
          for obj in objects:
          doc.EndUndo()
        ferdinand @ADCMHI
        Hello @ADCMHI,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Please do not hijack other threads with your questions. I have forked your question.
        The main problem with your code is that you try to use c4d.utils.SendModelingCommand to invoke UVCOMMAND_OPTIMALCUBICMAPPING. But as the symbol says, that is not a modelling but a UV command, you must use CallUVCommand instead. We also have an example for CallUVCommand on GitHub.
        • A Offline
          ADCMHI
          I'm sorry for posting without understanding the rules.
          Thank you for your response.
          I tried using this script, but it's not working properly. Could someone help me fix it?
                  # UVWタグがなければ作成
                  # オブジェクトを選択
                  res = c4d.modules.bodypaint.CallUVCommand(points,
                  pointCount,
                  polys,
                  polyCount,
                  uvw,
                  polySelection,
                  pointSelection,
                  op=settings,
                  handle.GetMode(),
                  cmdid,
                  settings)
                      #command=c4d.UVCOMMAND_OPTIMALCUBICMAPPING,
                      #list=[obj],
                      #mode=c4d.MODELINGCOMMANDMODE_ALL,
                      #bc=settings,
                      #doc=doc
                  if not res:
              if not doc:
              doc.StartUndo()
              for obj in objects:
              doc.EndUndo()
            ferdinand @ADCMHI
            Hello @ADCMHI,
            your code contains syntax errors, you have index arguments after a keyword argument in your CallUVCommand call and you also refer to module attributes that do not exist in your script, uvw and cmdid. You also did not properly follow the code example I provided.
            Your script could either be a product of some chat bot which is not knowing what is doing (but at least CoPilot/ChatGPT write better Cinema 4D code these days) or the struggles of a beginner. And while we understand that CoPilot is a useful tool (we use it ourselves) and that everyone has to start, we cannot help you with chatbot gibberish or with learning the basics of programming. See our Support Procedures for details.
            I personally operate by the rule: "Newcomers have one free" and therefore fixed here your script for you. Please understand that we cannot help you with further questions that are on such a fundamental level of non-functional code. Please also understand that this is not a commitment of SDK to always provide solutions for newcomers, no matter in which state their code is.
            Result
            Code
            """Demonstrates how to apply the `UVCOMMAND_OPTIMALCUBICMAPPING` to a list of selected objects.
            import mxutils
            from mxutils import CheckIterable, CheckType
            from c4d.modules import bodypaint
            def apply_cube_mapping(targets: list[c4d.PolygonObject], settings: c4d.BaseContainer) -> None:
                """Applies `UVCOMMAND_OPTIMALCUBICMAPPING` to each element in `targets` using the `settings`
                provided.
                # Check the input types.
                CheckType(settings, c4d.BaseContainer)
                CheckIterable(targets, c4d.PolygonObject, list)
                for obj in targets:
                    doc: c4d.documents.BaseDocument = CheckType(obj.GetDocument(), c4d.documents.BaseDocument)
                    # Make sure the object is the only selected object in the scene, as otherwise the UV command
                    # will get confused.
                    doc.SetActiveObject(obj)
                    # EMake sure the document is in UV mode.
                    if doc.GetMode() not in [c4d.Muvpoints, c4d.Muvpolygons]:
                        doc.SetMode(c4d.Muvpolygons)
                    # Acquire the active UVSet, if it doesn't exist, create one by opening the UV editor.
                    handle: bodypaint.TempUVHandle | None = bodypaint.GetActiveUVSet(doc, c4d.GETACTIVEUVSET_ALL)
                    if handle is None:
                        c4d.CallCommand(170103)
                        if c4d.API_VERSION >= 22000:
                            c4d.modules.bodypaint.UpdateMeshUV(False)
                        handle = c4d.modules.bodypaint.GetActiveUVSet(doc, c4d.GETACTIVEUVSET_ALL)
                        if handle is None:
                            raise RuntimeError("There is no Active UVSet")
                    # Retrieve the UVW data for the active UVSet.
                    uvw: list[dict] = handle.GetUVW()
                    if uvw is None:
                        raise RuntimeError(f"Failed to retrieve the uvw data for: {obj}")
                    # Call the uv command.
                    if not c4d.modules.bodypaint.CallUVCommand(
                        handle.GetPoints(), handle.GetPointCount(), handle.GetPolys(), handle.GetPolyCount(),
                        uvw, handle.GetPolySel(), handle.GetUVPointSel(), obj, handle.GetMode(),
                        c4d.UVCOMMAND_OPTIMALCUBICMAPPING, settings):
                        raise RuntimeError("CallUVCommand failed.")
                    # Update the handle with the new UVW data and release it.
                    if not handle.SetUVWFromTextureView(uvw, True, True, True):
                        raise RuntimeError("UVW from Texture View failed to be set.")
                    c4d.modules.bodypaint.FreeActiveUVSet(handle)
                    print(f"Applied UV mapping to: {obj}")
                """Entry point of the script.
                # Your settings.
                # Get all the selected objects in the scene. Your code used here BaseDocument.GetObjects() which
                # does not make too much sense, as it will only return all the top-level objects in the scene.
                selection: list[c4d.BaseObject] = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN)
                if not selection:
                    c4d.gui.MessageDialog("Please select at least one object.")
                apply_cube_mapping(selection, settings)
