    Set RenderData framerate causing C4D to crash
    python2025
    4 Posts 3 Posters 22.6k Views 1 Watching
    • chuanzhenC Online
      chuanzhen
      use bellow code will causing C4D to crash
          rd = c4d.documents.RenderData()
          rd[c4d.RDATA_FRAMERATE] = 2.0
      safe setting code:
          data = rd.GetDataInstance()
          data[c4d.c4d.RDATA_FRAMERATE] = 2.0
      bug?
      相信我,可以的!
      • i_mazlovI Offline
        i_mazlov @chuanzhen
        Hi @chuanzhen,
        The issue is not reproducible on my machine with C4D: 2025.2.1 (Build 2025_2_1_10be3ac9d371_1759753353) Win
        Ilia
        chuanzhenC 1 Reply Last reply Reply Quote 0
        • chuanzhenC Online
          chuanzhen @i_mazlov
          @i_mazlov there is video, 2025.2.1,win11
          相信我,可以的!
            Hi I was able to reproduce the issue and fix it for the next version.
            The bug is that setting RDATA_FRAMERATE require the RenderData to be part of a document in case the "Use Project Frame Rate" is enabled on the render settings. If this is enabled and this is enabled by default the value you enter will be disregarded. "Use Project Frame Rate" is a new setting added in 2025.2.
            I will ping you once the fix is available.
            • M m_adam moved this topic from Cinema 4D SDK on
