    Discussion on the feasibility of exporting FBX through zscript
    Scheduled Pinned Locked Moved ZBrush SDK
    c++windows2024
    6 Posts 2 Posters 2.8k Views 1 Watching
    • Q Offline
      qq475519905
      I will implement a script to save the current scene to an FBX. Can this be done in zscript? If anyone knew, I would be extremely grateful!
        ferdinand @qq475519905
        Hello @qq475519905,
        ZScript does not have the capability to export scenes to FBX format directly. ZScript is primarily used for automating tasks within ZBrush and does not have extensive file I/O capabilities beyond what is needed for ZBrush-specific tasks.
        When you want to write a custom FBX exporter, you would have to use the GoZ ZBrush API, this would allow you to use C++ or pretty much every other language (you have tagged this as C++). Writing an FBX exporter is however no trivial task.
        Q 1 Reply Last reply Reply Quote 0
        • Q Offline
          qq475519905
          hello, I have created a simple script using zscript, but every time I export it, a 'FBX Export Options' window pops up. Do you want to allow direct export without a settings window? I would be very grateful if you could provide some tips!
          • Q Offline
            qq475519905
            This post is deleted!
            • Q Offline
              qq475519905 @ferdinand
              @ferdinand Hello, I have created a simple export script using zscript, but every time I export it, a "FBX Export Options" window pops up. Do you want to allow direct export without setting up a window? I would greatly appreciate it if you could provide some suggestions!
                Hey @qq475519905,
                sorry for the delay. As I said in the beginning, you can implement your own serializer using GoZ. But there is no dedicated exporter API in ZScript. I assume you are using some RoutineCall to achieve what you are doing. You cannot escape any GUI associated with such call.
