    Add icons to treeview
    2023pythonwindows
    6 Posts 3 Posters 1.8k Views 2 Watching
    • N Offline
      Neekoe
      I'm sorry, I saw a lot of information about treeview on the forum, but I still can't understand it. I'm too stupid, and I feel like I've done a lot, but still can't get the answer
      I hope to get a custom icon, similar to the green custom icon in image 2, and the treeview result will let me know what difficulty is
      PLUGINID = 1064765
      ID_OTHER = 1124
      ID_ICON = 1125
      ID_NAME = 1126
      # ///////////////// TreeView界面
      class ProjectPreset(object):
      # 类,它表示一个项目,也就是我们列表中的 Item
          projectptPath = "projectptPath"
          otherData = "OtherData"
          _selected = False
          def __init__(self, projectptPath) :
              self.projectptPath = projectptPath
              self.otherData += projectptPath
          @property
          def IsSelected(self) :
              return self._selected
          def Select(self) :
              self._selected = True
          def Deselect(self) :
              self._selected = False
          def __repr__(self) :
              return str(self)
          def __str__(self) :
              return self.projectptPath
      class ListView(c4d.gui.TreeViewFunctions) :
          def __init__(self) :
              self.listOfProjectPreset = list() # 存储我们需要在此列表中显示的所有对象
              # Add some defaults values
              t1 = ProjectPreset("T1")
              t2 = ProjectPreset("T2")
              t3 = ProjectPreset("T3")
              t4 = ProjectPreset("T4")
              t5 = ProjectPreset("T5")
              self.listOfProjectPreset.extend([t1, t2, t3, t4])
          #TreeView 的整个概念是覆盖一些函数。因此,请务必阅读文档以了解根据您的需要覆盖哪些函数。
          # 因此,我们将为 TreeView 定义一些更通用的选项
          def IsResizeColAllowed(self, root, userdata, lColID) :
          def IsTristate(self, root, userdata) :
              return False
          def GetColumnWidth(self, root, userdata, obj, col, area) :
              return 80  # 所有的初始宽度都相同
          def IsMoveColAllowed(self, root, userdata, lColID) :
              # 允许用户移动所有列。
              # 必须在 AddCustomGui 的容器中设置 TREEVIEW_MOVE_COLUMN。
          def GetFirst(self, root, userdata) :
              # 返回层次结构中的第一个元素,如果没有元素,则返回 None
              rValue = None if not self.listOfProjectPreset else self.listOfProjectPreset[0]
              return rValue
          # 然后我们必须处理 GetDown(对于子对象,因为在我们的例子中它是一个简单的列表,我们返回 None)
          # GetNext 是当前 Object 之后的 Object,GetPred 是当前 Object 之前的 Object。
          # 我们还必须覆盖 GetID 才能唯一标识列表中的对象
          def GetDown(self, root, userdata, obj) :
              # 返回节点的子节点,因为我们只需要一个列表,所以每次都返回 None
              return None
          def GetNext(self, root, userdata, obj) :
              # 返回 arg:'obj' 之后要显示的下一个对象
              rValue = None
              currentObjIndex = self.listOfProjectPreset.index(obj)
              nextIndex = currentObjIndex + 1
              if nextIndex < len(self.listOfProjectPreset) :
                  rValue = self.listOfProjectPreset[nextIndex]
              return rValue
          def GetPred(self, root, userdata, obj) :
              # 返回要在 arg 之前显示的上一个 Object:'obj'
              rValue = None
              predIndex = currentObjIndex - 1
              if 0 <= predIndex < len(self.listOfProjectPreset) :
                  rValue = self.listOfProjectPreset[predIndex]
              return rValue
          def GetId(self, root, userdata, obj) :
              # 返回 TreeView 中元素的唯一 ID
              return hash(obj)
          def Select(self, root, userdata, obj, mode) :
              # 在用户选择元素时调用
              if mode == c4d.SELECTION_NEW:
                  for tex in self.listOfProjectPreset:
                      tex.Deselect()
                  obj.Select()
              elif mode == c4d.SELECTION_ADD:
                  obj.Select()
              elif mode == c4d.SELECTION_SUB:
                  obj.Deselect()
          def IsSelected(self, root, userdata, obj) :
              # 返回: 如果选择了 *obj*,则为 True,否则为 False
              return obj.IsSelected
          def InsertObject(self, root, userdata, obj, dragtype, dragobject, insertmode, bCopy):
              self.listOfProjectPreset.append(dragobject)
          def SetCheck(self, root, userdata, obj, column, checked, msg) :
              # 当用户单击'c4d.LV_CHECKBOX' 列中对象的复选框时调用
              if checked:
                  obj.Select()
                  obj.Deselect()
          def IsChecked(self, root, userdata, obj, column) :
              # 返回: (int) : *obj* 的指定 *column* 中复选框的状态
              if obj.IsSelected:
                  return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                  return c4d.LV_CHECKBOX_ENABLED
          # 然后LV_TREE元素将通过调用 GetName 来检查 Object name
          def GetName(self, root, userdata, obj) :
              # 返回要为 arg:'obj' 显示的名称, 仅对type LV_TREE类型的列调用
              return str(obj) # Or obj.texturePath
          # 最后,LV_USER允许我们执行一些绘图功能,就像您在 GeUserArea 中所做的那样
          # 使用 DrawCell 绘制您想要的任何内容(在我们的例子中是文本)。看看 DrawInfo-Dict
          def DrawCell(self, root, userdata, obj, col, drawinfo, bgColor):
              # 在 TreeView 的单元格中绘制内容 LV_USER
              if col == ID_NAME:
                  print("Drawcell obj: ", str(obj))
                  geUserArea = drawinfo["frame"]
                  ICON_SIZE = drawinfo["height"]
                  TEXT_SPACER = 6
                  bgColor = c4d.COLOR_SB_TEXTHG1 if drawinfo["line"] % 2 else c4d.COLOR_SB_TEXTHG2
                  # 使用自定义图标
                  icon = c4d.bitmaps.BaseBitmap()
                  path = os.path.join(PLUGINPATH, "res", "icon.tif")
                  if not icon.InitWith(path):
                      print("图标加载失败,请检查路径!")
                      return False  # 图标加载失败,退出
                  geUserArea.DrawSetPen(bgColor)
                  geUserArea.DrawBitmap(icon, drawinfo["xpos"], drawinfo["ypos"], ICON_SIZE, ICON_SIZE, 0, 0, icon.GetBw(), icon.GetBh(), c4d.BMP_ALLOWALPHA)
                  # 绘制文本
                  name = str(obj)
                  fontHeight = geUserArea.DrawGetFontHeight()
                  fontWidth = geUserArea.DrawGetTextWidth(name)
                  x = drawinfo["xpos"] + ICON_SIZE + TEXT_SPACER
                  y = drawinfo["ypos"] + (ICON_SIZE - fontHeight) / 2
                  txtColor = c4d.COLOR_SB_TEXT_ACTIVE1 if obj.IsSelected else c4d.COLOR_SB_TEXT
                  geUserArea.DrawSetTextCol(txtColor, bgColor)
                  geUserArea.DrawText(name, x, y)
          # Performing a rename on any item in the Treeview is crashing Cinema reliably.
          def SetName(self, root, userdata, obj, name):
              # 当用户重命名元素时调用`DoubleClick()`必须返回False才能正常工作
              doc.StartUndo()
              doc.AddUndo(c4d.UNDOTYPE_CHANGE_SMALL, obj)
              obj.SetName(name)
              doc.EndUndo()
          # 然后很少有有用的东西,比如当你双击时通过覆盖 DoubleClick
          # 触发一些脚本,以及通过覆盖 DeletePressed 来管理器 Delete 键
          def DoubleClick(self, root, userdata, obj, col, mouseinfo) :
              # 当用户双击 TreeView 中的条目时调用。返回:返回:(bool) :如果双击
              # 已处理,则为 True,如果default作应启动,则为 False。默认作将调用对
              # 象的重命名过程,启用 'SetName()'
              if not isinstance(obj, c4d.BaseList2D):
              obj.SetName(c4d.gui.RenameDialog(obj.GetName()))
              #c4d.gui.MessageDialog("你确定要合并 " + str(obj)+"到当前项目吗?(增加确定和取消按钮)")
              #return True
          def DeletePressed(self, root, userdata) :
              # 收到删除事件时调用
              for tex in reversed(self.listOfProjectPreset) :
                  if tex.IsSelected:
                      self.listOfProjectPreset.remove(tex)
      class DL_MainDialog(c4d.gui.GeDialog):
              ID_TREEVIEW = 6001
              ID_NAME = 6501
              ID_RENDER = 6502
              ID_TREEICON1 = 7001
              _treegui = None # 我们的 CustomGui TreeView
              _listView = ListView() # 我们的 c4d.gui.TreeViewFunctions 实例
              def __init__(self):
                  super().__init__()
                  # treeview 容器预设
                  # self.tv_manager = TV_Manager()
              def CreateLayout(self):
                  self.SetTitle(PLUGINNAME)
                  # 添加菜单
                  self.MenuSubBegin("File")
                  self.MenuAddString(self.ID_MENU1,"What")
                  self.MenuSubEnd()
                  self.MenuSubBegin("Edit")
                  self.MenuAddString(self.ID_MENU2,"What")
                  self.MenuSubEnd()
                  if self.GroupBegin(self.ID_GROUP_NONE1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 1, "项目预设", groupflags=0, initw=0, inith=0):
                      self.GroupBorder(c4d.BORDER_ACTIVE_1)
                      self.GroupBorderSpace(6,6,6,6)
                      customdata = c4d.BaseContainer()
                      customdata.SetBool(c4d.TREEVIEW_BORDER,c4d.BORDER_ROUND)
                      customdata.SetBool(c4d.TREEVIEW_HAS_HEADER, True)
                      customdata.SetBool(c4d.TREEVIEW_HIDE_LINES, True)
                      customdata.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True)
                      customdata.SetBool(c4d.TREEVIEW_RESIZE_HEADER, True)
                      customdata.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True)
                      customdata.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True)
                      customdata.SetBool(c4d.TREEVIEW_OUTSIDE_DROP, True)
                      customdata.SetBool(c4d.TREEVIEW_NO_MULTISELECT, True)
                      customdata.SetBool(c4d.TREEVIEW_NO_OPEN_CTRLCLK, False)
                      self._treegui = self.AddCustomGui(self.ID_TREEVIEW,c4d.CUSTOMGUI_TREEVIEW,"",c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT,0,0,customdata)
                      self.AddButton(self.ID_TREEBUTTON1, c4d.BFH_CENTER | c4d.BFH_SCALEFIT | c4d.BFV_SCALE, 100, 20, name="展开所有")
                      # self.AddMultiLineEditText(1541, c4d.BFH_SCALEFIT | c4d.BFV_SCALE, 0, 40)
                      # self.AddEditText(1842, c4d.BFH_SCALEFIT, 0, 25)
                      # self.Hierarchy(self,tv,headlist = ["Name","test"])
                      # 添加列标题(这里添加了三列)
                      if not self._treegui:
                          print ("[ERROR]: 不能生成TreeView")
                          return False
                      self.GroupEnd()
              def InitValues(self) :
                  icon.InitWith(path)
                  # Initialize the column layout for the TreeView.
                  layout = c4d.BaseContainer()
                  layout.SetLong(self.ID_TREEICON1, c4d.LV_DROPDOWN)
                  layout.SetLong(self.ID_NAME, c4d.LV_TREE )
                  layout.SetLong(self.ID_RENDER, c4d.LV_CHECKBOX)
                  self._treegui.SetLayout(3, layout)
                  # 设置头部标题
                  self._treegui.SetHeaderText(self.ID_TREEICON1, "Icon")
                  self._treegui.SetHeaderText(self.ID_NAME, "Name")
                  self._treegui.SetHeaderText(self.ID_RENDER, "使用渲染器")
                  self._treegui.Refresh()
                  # # 设置根节点
                  self._treegui.SetRoot(self._treegui, self._listView, None)
      • N Offline
        Neekoe
        The problem has been resolved, and the reason why the icon does not appear is that I used layout in 'def InitValues (self):' SetLong(self.ID_NAME, c4d.LV_TREE ), The correct one should be layout SetInt32(ID_NAME, c4d.LV_USERTREE)
        • N Offline
          Neekoe
          Thank you again to MAXON's friends for providing forum materials
          • DunhouD Offline
            Dunhou
            Hi Neekoe,
            Those look like a very old code snippet in boghma community website (closed and turn to discord).
            If you want to use TreeView more easily and less codes, please check the new easy_tree in our boghma lib, which I used in my Octane Lister plugin.
            btw, in boghma library, we have two examples toshow how to use easey_tree.
            Have fun.
            Cheers~
            DunHou
            https://boghma.com
            https://github.com/DunHouGo
            N 1 Reply Last reply Reply Quote 0
            • N Offline
              Neekoe @Dunhou
              @Dunhou said in Add icons to treeview:
              boghma
              I did refer to the teaching of Jack, a member of Boghma, which involved some methods and pre written libraries for calling. However, I would prefer to start from scratch because it is not as simple as the add button. The code snippets use parts of the function from Git and Boghma respectively. I can copy the parts that I have already learned. Thank you to the members of Boghma
                Thanks @Neekoe to have shared your solution and thanks @Dunhou for helping.
                When you pass LV_TREE the Draw method is not called to have it called you need to pass either LV_USERTREE or LV_USER.
