    SnapTool for R2023?
    32 Posts 6 Posters 30.3k Views 2 Watching
      moebius
      Hi Ferdinand!
      Thanks a lot!
      unfortunately it does not show up in the extentions.
      but, hell jey, a permanent solution would be great. An overhaul of the snap tool in C4D! 🙂
        Hi just to let you know that Ferdinand is in vacation, he will look into your topic once you are back.
          moebius
          nice comunity 🙂
          • C Offline
            ceen
            Implementation of that tool would be nice indeed!
            M 1 Reply Last reply Reply Quote 1
              moebius @ceen
              @ceen Does it work for you in R2025?
              This Tool and TransformTool would be so great! Here an overview of this old plugin
                ferdinand @moebius
                Hey @moebius,
                So, for me and for Maxime this just loads fine. I suspect you are hotlinking the wrong folder. Just unpack the zip into a folder and then hotlink that folder. E.g., MyUser\Downloads\cinema_4d_cpp_sdk_2025_0_0. When it is still not working, the only thing I could think of is that you are operating on some company device where the the admin really went buck wild with WDAC (Windows Defender Application Control) and disallowed the loading of any unsigned DLLs. Because I did not sign these DLLs.
                But that is very unlikely I would say. It is more likely that you are linking the wrong folder.
                  moebius
                  Hi!
                  no, does not work.
                  sorry for asking: did you compile it in "debug mode", not "release mode"? This was the issue with the compile a couple years ago
                    A debug build should load as much as a release build (the latter is just a quite bit faster). I quite frankly do not remember if if put this to release before I compiled, as in my daily work I usually compile debug builds. I will recompile it one more time tomorrow.
                    I still think you are not correctly linking the folder. Can you show us what you do?
                      moebius @ferdinand
                      thanks for your patience!
                      btw, I did try on the office PC and my home PC.
                      This is the office:
                        Hm, that all looks correct and you also have no other plugins which could cause a collision, that is quite odd. I have recompiled the plugin. The plugin is still working on my machine.
                        Cinema_4D_CPP_SDK_2025_0_0.zip
                        This is again RC and unsigned.
                          moebius
                          hej, now it works!
                          now even in the "plugins" folder under C:/.../MAXON/Maxon Cinema 4D ...
