    BitmapButton not work
    2024python
    5 Posts 2 Posters 862 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      I created a Bitmaobutton GUI, but the GUI only works in the right area of the image, and clicking on the left does not work。
      my code:
      custom_gui = self.AddCustomGui(ID, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_SCALEFIT, 0, 0, bc)
      custom_gui.SetImage(bitmap)
      Thanks for any help!
      相信我,可以的!
        ferdinand @chuanzhen
        Hey @chuanzhen,
        Thank you for reaching out to us. Can you please provide an executable code example for your problem, i.e., a little dialog which creates your rig there. Please also provide the bitmap you load there. I have a hunch why this might happen, but I need your code and bitmap to confirm.
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @ferdinand
          --video:
          --code:
          from c4d import gui
          def LoadCustomIcon(input_v):
              bc_customgui = c4d.BaseContainer()
              bc_customgui.SetBool(c4d.BITMAPBUTTON_BUTTON, True)
              # bc_customgui.SetBool(c4d.BITMAPBUTTON_NOBORDERDRAW, False)
              bc_customgui.SetInt32(c4d.BITMAPBUTTON_BORDER, c4d.BORDER_THIN_IN)
              bc_customgui.SetInt32(c4d.BITMAPBUTTON_OUTBORDER, c4d.BORDER_THIN_IN)
              bmp_dict = gui.GetIcon(input_v)
              icon_data = c4d.IconData()
              icon_data.bmp = bmp_dict['bmp']
              icon_data.x, icon_data.y, icon_data.w, icon_data.h = bmp_dict['x'], bmp_dict['y'], bmp_dict['w'], bmp_dict['h']
              bmp = icon_data.GetClonePart()
              return bmp, bc_customgui
          class test_dialog(gui.GeDialog):
              def CreateLayout(self):
                  # Other than edit fields, buttons do not have a builtin bubble help.
                  self.GroupBegin(1000,c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT,2,0)
                  self.AddButton(1001, c4d.BFH_SCALEFIT, name = "Foo")
                  img, bc = LoadCustomIcon(431000053)
                  bc.SetString(c4d.BITMAPBUTTON_TOOLTIP, "<b>xxx")
                  custom_gui = self.AddCustomGui(1002, c4d.CUSTOMGUI_BITMAPBUTTON,"", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, bc)
                  custom_gui.SetImage(img)
                  self.GroupEnd()
              """def Message(self,msg,result):
                  msg_id = msg.GetId()
                  if msg_id == c4d.BFM_GETCURSORINFO:
                      result.SetId(c4d.BFM_GETCURSORINFO)
                      result.SetString(c4d.RESULT_BUBBLEHELP, "Show something")
                  return c4d.gui.GeDialog.Message(self, msg, result)"""
              def Command(self, id, msg):
                  if id == 1002:
                      gui.MessageDialog("Click success!")
          # Execute main()
              dlg = test_dialog()
              dlg.Open(c4d.DLG_TYPE_ASYNC,0 -1,-1,400,400)
          相信我,可以的!
            Hello @chuanzhen,
            In short, I would say you are simply misusing bitmap buttons here. They are not meant to be used with BFH_SCALEFIT. My hunch was that BITMAPBUTTON_FORCE_SIZE will have an impact here and that turned out to be true, but will also align the image to the left in the button (the extrude icon button below is an example for that). In general, you must use BFH_FIT/BFV_FIT for bitmap buttons (sweep icon), as our bitmap buttons are not meant to hold text or be wider than the image that they display. You can add custom spacing between buttons with an extra group (sweep icon button).
            Result
            Code
            """Demonstrates how to add bitmap buttons to a dialog with different layout options.
            class TestDialog(c4d.gui.GeDialog):
                ID_GRP_MAIN: int = 1000
                ID_GROUP_SUB: int = 1001
                ID_BTN_1: int = 2000
                ID_BTN_2: int = 2001
                ID_BTN_3: int = 2002
                ID_BTN_4: int = 2003
                ID_ICON_1: int = 431000053
                ID_ICON_2: int = 5116
                ID_ICON_3: int = 5117
                ID_ICON_4: int = 5118
                def AddBitmapButton(self, gid: int, iid: int, flags: int,
                                    forceSize: int = 0) -> c4d.gui.BitmapButtonCustomGui:
                    """Adds a bitmap button to the dialog with the given gadget ID, icon ID, flags, and optional
                    forced size.
                    bmp: c4d.bitmaps.BaseBitmap = c4d.bitmaps.InitResourceBitmap(iid)
                    if bmp is None:
                        raise ValueError(f"Failed to load the icon with the ID {iid}.")
                    bc: c4d.BaseContainer = c4d.BaseContainer()
                    bc.SetBool(c4d.BITMAPBUTTON_BUTTON, True)
                    bc.SetInt32(c4d.BITMAPBUTTON_BACKCOLOR, c4d.COLOR_BGEDIT)
                    if forceSize:
                        bc.SetInt32(c4d.BITMAPBUTTON_FORCE_SIZE, forceSize)
                    gui: c4d.gui.BitmapButtonCustomGui = self.AddCustomGui(
                        gid, c4d.CUSTOMGUI_BITMAPBUTTON, "", flags, 0, 0, bc)
                    if not isinstance(gui, c4d.gui.BitmapButtonCustomGui):
                        raise ValueError("Failed to add the custom GUI.")
                    gui.SetImage(bmp)
                def CreateLayout(self) -> bool:
                    """Creates the layout of the dialog.
                    self.SetTitle("Test Dialog")
                    # Open an explicit outer group for the main layout. This group scales horizontally and
                    # vertically and has 4 columns.
                    self.GroupBegin(self.ID_GRP_MAIN, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, cols=4)
                    # Add a bitmap button just like you did with BFH_SCALEFIT. This results in the "broken" left
                    # whitespace as a non-clickable area.
                    self.AddBitmapButton(self.ID_BTN_1, self.ID_ICON_1, c4d.BFH_SCALEFIT)
                    # Do the same but force the size of the button to 32x32 pixels, this will work, but the
                    # image will be left aligned.
                    self.AddBitmapButton(self.ID_BTN_2, self.ID_ICON_2, c4d.BFH_SCALEFIT, forceSize=32)
                    # This is how bitmap buttons are actually meant to be used, with BFH_FIT and BFV_FIT. Bitmap
                    # buttons are not meant to have white space to their left or right.
                    self.AddBitmapButton(self.ID_BTN_3, self.ID_ICON_3, c4d.BFH_FIT)
                    # When you want whitespace to the left and right of the button, you can use a group with
                    # BFH_SCALEFIT and add the button with BFH_SCALE | BFH_CENTER. This will add whitespace to
                    # the left and right of the button.
                    self.GroupBegin(self.ID_GROUP_SUB, c4d.BFH_SCALEFIT, initw=100)
                    self.AddBitmapButton(self.ID_BTN_4, self.ID_ICON_4, c4d.BFH_SCALE | c4d.BFH_CENTER)
                    self.GroupEnd()
                    # An even easier way to add whitespace to the left and right of a button is to use the
                    # GroupSpace method to set the spacing between elements in a group. But with that you cannot
                    # control a single element individually.
                    # self.GroupSpace(10, 2)
                    self.GroupEnd()
                def Command(self, cid: int, msg: int) -> bool:
                    """Handles the command messages.
                    if cid in (self.ID_BTN_1, self.ID_BTN_2, self.ID_BTN_3, self.ID_BTN_4):
                        c4d.gui.MessageDialog(f"Button {cid} clicked.")
            dlg: TestDialog = TestDialog()
            # Execute main()
                dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=200, defaulth=200)
            chuanzhenC 1 Reply Last reply Reply Quote 1
              @ferdinand Thanks👍
              相信我,可以的!
