    Differences between menu item execution and execution through the script editor
    2024pythonwindows
    4 Posts 2 Posters 1.2k Views
      Hongzz
      Script layout can normally execute the command, but the icon under the menu can not correctly execute the command, why, I am a beginner, please answer the master doubts!d65a5bc6-8f35-4cc7-804a-d55b64f18d35-image.png 7c904fc5-0822-46a2-8763-ed2d4a03f06d-image.png
      Updated by Ilia on 22/05/2024:
      Consolidated consequent messages in a single posting:
      import os
      class ImportDialog(c4d.gui.GeDialog):
          BUTTON_ID_BASE = 1000
          def __init__(self):
              self.files = []  # 初始化为空列表
          def LoadFiles(self):
              startup_path = c4d.storage.GeGetStartupWritePath()
              project_dir = os.path.join(startup_path, 'library', 'scripts', 'spline load', 'projects')
              if not os.path.exists(project_dir):
                  c4d.gui.MessageDialog('项目目录不存在。')
                  return False
              self.files = [os.path.join(project_dir, f) for f in os.listdir(project_dir) if f.endswith('.c4d')]
          def CreateLayout(self):
              self.SetTitle("Import C4D Projects")
              if not self.LoadFiles():
                  return False  # 如果加载文件失败,不创建布局
              for index, file in enumerate(self.files, start=self.BUTTON_ID_BASE):
                  filename = os.path.splitext(os.path.basename(file))[0]
                  self.AddButton(index, c4d.BFH_CENTER, name=filename)
      global_dialog_instance = None
          global global_dialog_instance
          if global_dialog_instance is None:
              global_dialog_instance = ImportDialog()
          global_dialog_instance.Open(c4d.DLG_TYPE_ASYNC, defaultw=400, defaulth=50)
      if __name__=="__main__":
      H 1 Reply Last reply Reply Quote 0
        Hongzz
        This post is deleted!
          Hongzz @Hongzz
          • i_mazlovI Offline
            i_mazlov @Hongzz
            Hello @Hongzz,
            Getting Started
            It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
            About your First Question
            When removing all the path handling fluff from your code, everything works as expected (the layout is created properly, when runs from both "Execute" button and the menu item). Please check the attached script below.
            This actually means that there's something fishy going on with the files on your filesystem or the way you're dealing with them. I'd suggest improve handling edge cases, when the path doesn't exist or when there're no files in the specified path.
            There're a couple more comments on your posting.
            First of all, storing your dialog in the global scope of the script is a "hack" that is a) highly not recommended in general b) exceptionally not recommended for being shipped to the end user. You should consider developing a plugin instead, if you need your dialog to be persistent over multiple openings of your dialog. You can have a look into our github repository for some references, e.g. the CommandDataDialog example.
            Secondly, please consolidate your consequent messages in a single posting as it improves the readabily of the forum (please check the "Support Topic Rules" part of our Support Procedures). For your previous message I've already done this for you.
            Ilia
            The code snippet without unnecessary path handling parts:
            import os
                def __init__(self):
                    self.files = ['myFile1.c4d', 'myFile2.c4d', 'myFile3.c4d']
