    Get information about renderer plugin via Python
    2024python2023
    6 Posts 3 Posters 1.4k Views 2 Watching
      hSchoenberger
      Hi
      Is there any way to get some information about renderer plugins?
      I want to get the version of the Octane plugin.
      Background:
      All I have found was a script snipplet to get some information from a data block inside the C4D document.
      bc = doc[ID_OCTANE_LIVEPLUGIN]
      print ("Octane version=",bc[c4d.SET_OCTANE_VERSION])
      But this might not be the version that is currently used, it can be the version that was used to create/save the scene.
      So how I can loop through all plugins loaded and get some information from the plugins like the version?
      ferdinandF DunhouD 2 Replies Last reply Reply Quote 0
      • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
        ferdinand @hSchoenberger
        Hello @hSchoenberger,
        Thank you for reaching out to us. Unfortunately, your question is off topic for the forum you have posted in. Please check the Forum Overview for an overview of the scope of the different forums.
        As a result, your posting has been moved into General Talk.
        Regarding your Posting
        All questions about third parties APIs are off topic, you would have to ask OTOY if they somewhere store information about the version of Octane. There is no (publicly available) standardized interface with which plugins or specifically renderer plugins would store their version.
        H 1 Reply Last reply Reply Quote 0
        • DunhouD Online
          Dunhou @hSchoenberger
          Hey @hSchoenberger ,
          You can take a look at Renderer library, it has a method to get the version of support render engine.
          Cheers~
          DunHou
          from Renderer import Octane
              print(Octane.GetVersion())
          # Will return 13000200 for 2023.1.2.R2
          https://boghma.com
          https://github.com/DunHouGo
          H 1 Reply Last reply Reply Quote 1
            hSchoenberger @ferdinand
            @ferdinand said in Get information about renderer plugin via Python:
            Sorry, but this is a C4D SDK question!
            It is NOT about the Octane SDK.
            "How can I list all installed renderer plugins in C4D with their version?"
            Plugins have to provide informations for RegisterVideoPostPlugin().
            Like the name and a disklevel (which might or might not set to the same as the plugin version),
            I though I can access this information.
            Ok, I assumed that C4D works just like e.g. the plugin manager in Maya.
            Which is able to list the version of each plugin.
            And as I have found some script for a probbaly old C4D versions, I assumed there is still a way to do that with the latest version.
            plugins = c4d.plugins.GetFirstPlugin()
                while plugins:
                    print("Name:", plugins.GetName())
                    print("ID:", plugins.GetID())
                    if plugins.GetPluginType() == c4d.PLUGINTYPE_SCENESAVER or plugins.GetPluginType() == c4d.PLUGINTYPE_SCENELOADER:
                        print("Version:", plugins.GetFileVersion())
                        print("Version:", plugins.GetVersion())
                    print("\n")
                    plugins = plugins.GetNext()
              hSchoenberger @Dunhou
              @Dunhou
              I am sorry, but your module uses the exact same code as I have already posted as NOT working (for all cases).
              You are reading the information from the document, not the installed plugin.
                Although you have put your sentence into quotes, that was not what you asked, your questions were:
                And I answered that: There is no public interface with which you could get the version of a plugin. And when plugins provide version information on their own, you must ask their vendors about that. You can access the flags a plugin has been registered with BasePlugin.GetInfo, the disk-level is in-accessible for you.
                You can detect installed render engines by looping over all video post data plugins and check if they have PLUGINFLAG_VIDEOPOST_ISRENDERER set (this assumes that the to be detected render engine sets this flag on registration - which is usually unavoidable as you otherwise cannot hook in the render system of Cinema 4D, but there might be 'rogue' render engines out there which side step things).
                    plugin: c4d.plugins.BasePlugin
                    for plugin in  c4d.plugins.FilterPluginList(c4d.PLUGINTYPE_VIDEOPOST, True):
                        if (plugin.GetInfo() & c4d.PLUGINFLAG_VIDEOPOST_ISRENDERER):
                            print (plugin.GetName())
                # Example output for a vanilla installation.
                Physical
                Redshift
                Viewport Renderer
