    How to add Strengths of each Pose I set in Pose Morph as Ports into Xpresso?
    9 Posts 7 Posters 2.0k Views 3 Watching
    • P Offline
      PATPAT
      I'm on a character rigging and I try to sort hand poses into Xpresso.
      I didn't find out a DESC of each Pose, then I can't get each Pose Strength as a port in Xpresso by script which means I got to drag them in, it's a disaster.XD
      https://developers.maxon.net/docs/py/2023_2/classic_resource/tag/tcaposemorph.html?highlight=pose morph
      Is there any to way to do it?
      • X Offline
        x_nerve
        Hi:
        @PATPAT
        First of all, the point movement algorithm of attitude deformation label is not complicated.
        I've seen in some tutorials that you can add some data to a port with unconventional operations, but I forgot . So, I use Python nodes.
        The data control label object weight value for the input port, so you need to add a user data of type link to the Python node.
        Python is a dynamic language, and data types cannot be determined before compilation. There is no conditional right or wrong judgment in my code, so please add them by yourself.
            obj = op[c4d.ID_USERDATA,1]
            Tags = obj.GetTags()
            Pose = [tag for tag in Tags if tag.GetRealType() == 1024237]
            #[4000,1101] is the ID of the strength value.
            Pose[0][4000,1101] = Input1
            global Output1
            Output1 = Pose[0][4000,1101]
        • P Offline
          PATPAT
          Oh dear, it's a fascinating method and it works well! Thank you, x_nerve!
            The "problem" here is to retrieve the right ID of each morph.
            on the morph tag, the Data for each slider start at c4d.ID_CA_POSE_ANIMATE_OFFSET (1000). Each morph has a maximum of c4d.ID_CA_POSE_ANIMATE_CNT (100) parameters. The Strength parameter is the second one. (1).
            So, the Strength of the first morph slider have the ID 1101, the second 1201.... 1301 etc
            All those data are stored in the subcontainer c4d.ID_CA_POSE_ANIMATE_DATA (4000)
            You can retrieve the number of morphs with GetMorphCount.
            After that you can manipulate xpresso, we have a couple of examples about that on ou github repository.
            You can build the descID with those information. You can have a look at this thread to understand a bit more how to use descID
            from c4d import gui
            # Main function
                morphTag = op.GetFirstTag()
                if morphTag is None:
                    raise RuntimeError("Failed to retrieve the morpht tag.")
                xpressoTag = morphTag.GetNext()
                if xpressoTag is None:
                    raise RuntimeError("Failed to retrieve the xpressoTag.")
                morphCount = morphTag.GetMorphCount()
                 # Retrieves the node master
                gvNodeMaster = xpressoTag.GetNodeMaster()
                if gvNodeMaster is None:
                    raise RuntimeError("Failed to retrieve the Node Master.")
                # Retrieves the Root node (the Main XGroup) that holds all others nodes
                gvRoot = gvNodeMaster.GetRoot()
                if gvRoot is None:
                    raise RuntimeError("Failed to retrieve the Root Node.")
                # Creates a constant node in the GvRoot
                objectNode = gvNodeMaster.CreateNode(gvRoot, c4d.ID_OPERATOR_OBJECT, x=100, y=100)
                if objectNode is None:
                    raise RuntimeError("Failed to create the const Node.")
                objectNode[c4d.GV_OBJECT_OBJECT_ID] = morphTag
                for i in range(0, morphCount):
                    offsetID = c4d.ID_CA_POSE_ANIMATE_OFFSET + c4d.ID_CA_POSE_ANIMATE_CNT * i + 1
                    morphDescId =  c4d.DescID(c4d.DescLevel(c4d.ID_CA_POSE_ANIMATE_DATA, c4d.DTYPE_SUBCONTAINER, 0), c4d.DescLevel(offsetID, c4d.DTYPE_REAL, 0))
                    objectNode.AddPort(c4d.GV_PORT_INPUT, morphDescId, c4d.GV_PORT_FLAG_IS_VISIBLE, True)
            # Execute main()
            @x_nerve your answer isn't clear. I don't fully understand the purpose here.
              Hello @PATPAT,
              without any further questions or replies, we will consider this thread as solved by Monday the 20th and flag it accordingly.
              • B Offline
                bentraje
                Hi @Manuel
                Can this be adopted to the latest version of Cinema4D?
                I tried the script on R21 and it works as expected. But when I tried it on later versions, it gives me an error of:
                AttributeError: 'c4d.BaseTag' object has no attribute 'GetNodeMaster'. Did you mean: 'GetNodeData'?
                If I do a refactor to GetNodeData, it gives me an error of RuntimeError: Failed to retrieve the Node Master.
                Also, why does the Xpresso API is changing? I thought this feature is already deprecated and supposed to be kept for legacy with the scene nodes eventually replacing it.
                  GetNodeMaster is an attribute of XPressoTag so my guess is that you are calling the function on another tag as hinted by the error (c4d.BaseTag) and not on a xpresso tag.
                  The API did not change in this regard. So if you still have issue please open a new topic and post clear reproduction step with your code.
                  Maxime
                  • B Offline
                    blkmsk
                    Hi @bentraje I just came across this thread and quickly tested the above script in 2024. It still works as expected.
                    Without any further knowledge I would assume that A) you dont have a xpresso tag on your object or B) its not the the second tag on your object.
                    • B Offline
                      bentraje
                      @m_adam @blkmsk
                      Gotcha. It works now. My bad. The ordering of the tag was essential based on the context of the script.
                      I overlooked it.
