    Keyframing the source file on an ImageTexture shader
    r25
    3 Posts 3 Posters 670 Views 2 Watching
    • A Offline
      aug
      I have this Octane material with a ImageTexture shader.
      I can programmatically set the source file on the shader.
      I want to be able to Keyframe this source file.
      Here's what I got so far:
      def changeTexture(shader, item, chosen, curTime) :
          doc = shader.GetDocument()
          doc.AddUndo(c4d.UNDOTYPE_CHANGE, shader)
          filepath = f'{item}_{chosen}.png'
          # Assign the new value
          print(f'Applying texture: {filepath}')
          print (shader[c4d.IMAGETEXTURE_FILE])
          shader[c4d.IMAGETEXTURE_FILE] = filepath
          shader.Message(c4d.MSG_UPDATE)
          print(shader[c4d.IMAGETEXTURE_FILE])
          track = shader.FindCTrack(c4d.IMAGETEXTURE_FILE)
          if not track:
              track = c4d.CTrack(shader, c4d.IMAGETEXTURE_FILE)
              shader.InsertTrackSorted(track)
          print(track)
          curve = track.GetCurve()
          result = curve.FindKey(curTime)
          if result is None:
              result = curve.AddKey(curTime)
          print(result)
          track.FillKey(doc, shader, result['key'])
      This runs without bugs. The files do get changed but they're not keyframed. The first time I run this, the file keyframe indicator does show up orange. But not the subsequent times.
        Your code is running fine with our regular bitmap shader and a standard material.
        As you are using Octane i cannot check what is going on. What looks to be the issue is the DescID you are using to find the track or to create it track = shader.FindCTrack(c4d.IMAGETEXTURE_FILE). You can learn a bit more about DescIDs in our c++ manual. DescID allow you to define the Type for a parameter. you are creating the Track without using the right type, which could be the issue.
        Below a code that is working as expected.
        from typing import Optional
        op: Optional[c4d.BaseObject]  # The active object, None if unselected
        def ChangeTexture(shader, item, chosen, curTime) :
            print (shader[c4d.BITMAPSHADER_FILENAME])
            shader[c4d.BITMAPSHADER_FILENAME] = filepath
            print(shader[c4d.BITMAPSHADER_FILENAME])
            track = shader.FindCTrack(c4d.BITMAPSHADER_FILENAME)
            if not track:
                track = c4d.CTrack(shader, c4d.BITMAPSHADER_FILENAME)
            print(track)
            if result is None:
            print(result)
            # Creates a Standard C4D Material
            mat = c4d.Material()
            if mat is None:
                raise RuntimeError("Failed to create a new default material.")
            # Creates a bitmap shader
            sha = c4d.BaseList2D(c4d.Xbitmap)
            if sha is None:
                raise RuntimeError("Failed to create a bitmap shader.")
            # Defines the path of the bitmap shader
            sha[c4d.BITMAPSHADER_FILENAME] = "FileName"
            # Defines the material color shader to new created one.
            mat[c4d.MATERIAL_COLOR_SHADER] = sha
            # Inserts the shader into the material
            mat.InsertShader(sha)
            # Inserts a material in the active doc
            doc.InsertMaterial(mat)
            ChangeTexture(sha, 1, 2, doc.GetTime())
            ChangeTexture(sha, 1, 4, doc.GetTime() + c4d.BaseTime(1))
            # Pushes an update event to Cinema 4D
        def state():
            # Defines the state of the command in a menu. Similar to CommandData.GetState.
            return c4d.CMD_ENABLED
        • mocolocoM Offline
          mocoloco
          A simple addition on CTrack and DescId as I was also faced to this a time ago. You can consult the @ferdinand's explanations and exemples on CTrack to the following post :
          https://developers.maxon.net/forum/topic/14315/solved-how-to-setup-a-ctrack-on-tag-plugin-ui-slider-with-extended-details/8
          Christophe
