    Can REAL MIN / MAX value be changed on Init?
    2023pythons26sdk
    20 Posts 2 Posters 6.7k Views 2 Watching
      ferdinand @mocoloco
      Hey @mocoloco,
      I think the impact on performance will be really limited.
      I am not quite sure how you mean that, but when my code comments about performance were the cause, you should not be worried. Cinema 4D evaluates the description of nodes quite often. When the description of a node must be evaluated, Cinema 4D will call GetDDescription multiple times, usually at least once per parameter a node has, but often also many times more.
      The minimal node has at least ten parameters as the description base and things like groups also do count. So, when you click on something on a node, this will then result in at least ten, but more likely something like fifteen GetDDescription calls for such minimal node. For substantial nodes, for example materials, you can easily end up with hundreds of calls for every interaction. The idea I line out in the code above, is then to avoid setting for example DESC_MAX for every one of these calls (and trigger all sorts of things by doing so), but only for the one call where the description signals via GetSingleDescID that it this parameter's turn to be modified.
      Even when you do everything wrong and you write data multiple times, nothing would get really slow, as for one plugin the impact will always be negligible. It would only become a problem when every plugin would do that. But when you follow the pattern from above, you should be good to go.
      • mocolocoM Offline
        mocoloco
        Hi @ferdinand,
        Thanks for clarifying, and I indeed noticed by the past when looking for bugs and printing some values in console that indeed GetDDescription are called multiple time. In my case, the change of the slider values will only occurs once.
        The scene loaded contains some UserData that will be used to set sliders MIN/MAX. Once done, they will be no change needed.
        So in my case the GetDDescription call will still multiple but the changed will be skipped once done. But it is good to indeed clarify this point.
        Christophe
        • mocolocoM Offline
          mocoloco
          Hi @ferdinand,
          For an unknown reason, that does not work. I do not get any errors, but anyways, the sliders MIN/MAX values remains identical to the value sets in Resource file.
          I sat up almost the same code, and so I was wondering if there is a way to reach the c4d.DESC_MIN parameters by correctly setting up the descID of the sliders and use instead the description.SetParameters(descID, param, groupID). I just didn't find the right declaration to get is work.
          For a correct understanding, here the Resource .res,
          // The description defintion of the tag Tmmover.
          CONTAINER Tmmover
            NAME Tmmover;
            INCLUDE Texpression;
            // The main "Tag" tab of the tag.
            GROUP ID_TAGPROPERTIES
              GROUP
                     REAL ID_X           { MIN -100.0; MAX 100.0; UNIT DEGREE; STEP 0.005; CUSTOMGUI REALSLIDER; }
                     REAL ID_Y           { MIN -50.0; MAX 50.0; UNIT DEGREE; STEP 0.005; CUSTOMGUI REALSLIDER; }
          Code,
          global Parameters
          Parameters = dict()
          Parameters['Xmin'] = -25.0
          Parameters['Xmax'] = 25.0
          def GetDDescription(self, node, description, flags):
                  global Parameters
                  if not description.LoadDescription(node.GetType()):
                      return False
                  # Change Slider limits accordingly to the UserData loaded into the global dict() named Parameters
                  # Sliders to modify: ID_X, ID_Y
                  ## AXIS X
                  paramID_X: c4d.DescID = c4d.DescID(c4d.DescLevel(c4d.ID_X, c4d.DTYPE_REAL, 0))
                  singleId: c4d.DescID = description.GetSingleDescID()
                      print (f"{singleId = }")
                  # Bail when there is a to be evaluated parameter and our parameter is not part off or equal
                  # to the to be evaluated parameter.
                  if singleId and not paramID_X.IsPartOf(singleId):
                      return True, flags
                  # Get the description data container instance (GetParameter>I<) for the parameter we want to modify
                  desc_X c4d.BaseContainer = description.GetParameterI(paramID_X)
                  if desc_X is None:
                      return True, flags
                  # Write the MAX and MAXSLIDER values based on Parameters values
                  print(f"min { Parameters['Xmin'] } / max {Parameters['Xmax']}" )
                  desc_X[c4d.DESC_MIN] = Parameters["Xmin"]
                  desc_X[c4d.DESC_MINSLIDER] = Parameters["Xmin"]
                  desc_X[c4d.DESC_MAX] = Parameters["Xmax"]
                  desc_X[c4d.DESC_MAXSLIDER] = Parameters["Xmax"]
                  # Not Working, no errors, but something should be wrong here
                  # How to define SetParameter with the new correct values that are set into the Parameter dictionary?
                  # description.SetParameter(singleId, desc_X, paramID_X)
                  return (True, flags | c4d.DESCFLAGS_DESC_LOADED)
          Help would be appreciated as I do not understand why it is not working while your example is...
          Christophe
            ferdinand @mocoloco
            Hello @mocoloco,
            Since I provided an example which does the exact same thing above, I am fairly certain that my code does work ;). Notice that I show in the GIF-screencast both the slider and edit field range changing. Does your code hit the statement print(f"min { Parameters['Xmin'] } / max {Parameters['Xmax']}" ) and what does that print? Have you tried overwriting something like DESC_NAME and DESC_SHORT_NAME to be sure that things are indeed 'not working, no errors'?
            Also: The double global keyword for the module attribute Parameters is a bit weird. One never does require the keyword global in a module scope (outside of function, method, or class definitions). And you only need it in a local scope (e.g., a method) when you want to write to an object that lives in a module scope. So, you do not need global here at all. But that should not break anything in this case (I think), but still a bit odd to do.
            [...] and use instead the description.SetParameters(descID, param, groupID). I just didn't find the right declaration to get is work [..]
            There is no Description.SetParameters, I assume you mean .SetParameter. But doing that would not change much. You must still retrieve the data container with .GetParameter. When you use .GetParameterI as I did, you rid yourself of the necessity of writing the container back, as you retrieve the actual container object and not a copy of it.
            When you are determined on using .SetParameter, you must be able to address the group the parameter is contained in. You cannot do this here directly, since the group you two parameters are in is anonymous (the group inside ID_TAGPROPERTIES). So, you would have to look into DESC_PARENTGROUP in the description data of your parameter to get the ID of the group the parameter is parented to. Then you can define the group DescID as groupDescId = c4d.DescID(idFromFileOrDescriptionData, c4d.DTYPE_GROUP, 0).
            • mocolocoM Offline
              mocoloco
              Hello @ferdinand,
              Thanks for your reply. To answer you to all your question in order,
              Yes, my code hit the statement print(f"min { Parameters['Xmin'] } / max {Parameters['Xmax']}" ) and I'm getting in console the following
              singleId = (1551, 0, 0)
              min -25.0 / max 25.0
              I was a bit afraid about what you confirmed me, that, .SetParameter() wouldn't change anything about writing the values. So there should be something else...
              I'm going to test this part of the code independently with this only assignment and see if it works or not.
              About global, I read the both in Python doc and it wasn't that clear if the global need to be specified inside the method's class or not as Parameters is defined as global, and outside of the class. What I noticed, is if I do not mention the global in GetDDescription() methods I'm getting error in console saying that Parameters is use prior being assigned, which means somehow Python do not see and look for the global var named Parameters. That error never occurred once global is specified in GetDDescription(), but yes, it is weird.
              I'm keeping you in touch about the next tests.
              Christophe
              • mocolocoM Offline
                mocoloco
                @ferdinand,
                I found the problem. For a reason I can't explain, going through the new assignment once on the first call of GetDDescription() isn't enough. I thought that I could do the change once on first plugin TAG load/use, then avoid to going through this change each time GetDDescription() is called. But that's isn't the case. It seems that the change need to be perpetual and need to be parsed and evaluated constantly to be seen and changed in the interface ( honestly I found this weird and not really optimised in terms of coding ).
                So, by getting rid of the flag FIRST_INIT (which wasn't in the code above), the code does work as expected.
                Maybe could you explain me why this repetitive reassignment is needed?
                Thanks a lot for your prompt support and all detailed explanation you are providing, it does help a lot.
                Christophe
                • mocolocoM Offline
                  mocoloco
                  @ferdinand,
                  There is something weird going on. I intend to change several sliders accordingly to Parameters, ID_X and ID_Y.
                  I adapted the code accordingly, but it seems that only DESC_MAXSLIDER and DESC_MINSLIDER are took into account while DESC_MIN and DESC_MAX stick to previous values. Could that be a bug?
                  I let in remarks the code that improve a bit better the result and allows ID_X to be fully set (MIN/MAX as well as MINSLIDER/MAXSLIDER), but the problems remains on ID_Y.
                  Here the whole code of GetDDescription(),
                  global Parameters
                  Parameters = dict()
                  Parameters['Xmin'] = -360.0
                  Parameters['Xmax'] = 360.0
                  Parameters['Ymin'] = -25.0
                  Parameters['Ymax'] = 25.0
                          return False
                      # Change Slider limits accordingly to Parameters values
                      # Sliders to modifiy ID_X, ID_Y
                      ## SLIDER ID_X
                      if len(Parameters) > 0:
                          paramID_X: c4d.DescID = c4d.DescID(c4d.DescLevel(ID_X, c4d.DTYPE_REAL, 0))
                          single_X: c4d.DescID = description.GetSingleDescID()
                          # Bail when there is a to be evaluated parameter and our parameter is not part off or equal to the to be evaluated parameter.
                          if single_X and not paramID_X.IsPartOf(single_X):
                              return True, flags
                          # if singleId[0] == mAXIS_X: print (f"singleID found: {singleId} ")
                          desc_X: c4d.BaseContainer = description.GetParameterI(paramID_X)
                          if desc_X is None:
                              return True, flags
                          # if single_X and paramID_X.IsPartOf(single_X):
                          #     if paramID_A1.IsPartOf(single_X)[0]:
                                  # Write the MAX and MAXSLIDER values based on UserDatas
                          desc_X[c4d.DESC_MIN] = c4d.utils.DegToRad(Parameters["Xmin"])
                          desc_X[c4d.DESC_MINSLIDER] = c4d.utils.DegToRad(Parameters["Xmin"])
                          desc_X[c4d.DESC_MAX] = c4d.utils.DegToRad(Parameters["Xmax"])
                          desc_X[c4d.DESC_MAXSLIDER] = c4d.utils.DegToRad(Parameters["Xmax"])
                          #     if paramID_X.IsPartOf(single_X)[0]:
                          #         print (f"Found X: {paramID_X.IsPartOf(single_X)[0]} ")
                          #         return (True, flags | c4d.DESCFLAGS_DESC_LOADED)
                          ## SLIDER ID_Y
                          paramID_Y: c4d.DescID = c4d.DescID(c4d.DescLevel(mAXIS_Y, c4d.DTYPE_REAL, 0))
                          single_Y: c4d.DescID = description.GetSingleDescID()
                          if single_Y and not paramID_Y.IsPartOf(single_Y):
                              return True, flags
                          desc_Y: c4d.BaseContainer = description.GetParameterI(paramID_Y)
                          if desc_Y is None:
                              return True, flags
                          desc_Y[c4d.DESC_MIN] = c4d.utils.DegToRad(Parameters["Ymin"])
                          desc_Y[c4d.DESC_MINSLIDER] = c4d.utils.DegToRad(Parameters["Ymin"])
                          desc_Y[c4d.DESC_MAX] = c4d.utils.DegToRad(Parameters["Ymax"])
                          desc_Y[c4d.DESC_MAXSLIDER] = c4d.utils.DegToRad(Parameters["Ymax"])
                          # if single_Y and paramID_A2.IsPartOf(single_Y):
                          #     if paramID_Y.IsPartOf(single_Y)[0]:
                          #         print (f"Found Y: {paramID_Y.IsPartOf(single_Y)[0]} ")
                  Does this trick to change REALSLIDER MIN/MAX values intend to be associated to only on change, and not on several UI object?
                  Thanks in advance,
                  Christophe
                  • mocolocoM Offline
                    mocoloco
                    You can add the following code to see the values before and after new assignment. You will see that the values are correctly changed, but the change does not reach the interface for unknown reason.
                    for k,v in desc_Y:
                        print(f"Y New, Key {k} / Val {v}")
                      ferdinand @mocoloco
                      Hey @mocoloco,
                      So, I gave it a spin and the root of your problems is that you defined your parameters as UNIT DEGREE where you and I used METER in the first examples. When you do so, you must define your values in radians, not degree when you write into the raw data.
                      But there are also some weird things going on with DEGREE. First of all, min-max slider values are always set to null\None in the description container, no matter how often you write the values, and the general min/max values seem to be used instead. One could sort of make sense of that, but what is really weird how the first parameter in a group does behave.
                      Fig. I - Unit Degree: We set the min-max range and name for both parameters. Setting the name works on both, but the first parameter adopts a clamped range which is a weird mix of its old and new value. The second parameter works fine.
                      Running the same code but using METER as a unit works without any issues.
                      Fig. II - Unit Meter: Here both parameters work flawlessly.
                      There is either a bug in the degree description handling, or you must jump through some hoops and set up the data in a specific way. I will not have the time to test this in more detail before next week. To help yourself, I would suggest defining either via user-data or a resource file a REAL DEGREE parameter and then reading out all its description values, looking for anything special that might be going on.
                      Code:
                      """Implements a tag which drives the position of a host object procedurally or via tracks.
                      import typing
                      class DynamicDescriptionTagData(c4d.plugins.TagData):
                          # The plugin ID.
                          ID_PLUGIN: int = 1060463
                          # What you dubbed "user data", a dictionary holding some description data to be injected at
                          # runtime. I just changed things a bit up and include/identify things over their ID instead
                          # of made-up strings, but nothing would prevent you from having both, it would just be a bit
                          # more complicated to parse such data:
                          # INTERFACE_DATA = [
                          #         "label": "Foo",
                          #         "id": c4d.DescId(...),
                          #         "data": [
                          #             {"label": "Name", "id": c4d.DESC_NAME, "value": "Bar"},
                          INTERFACE_DATA: list[tuple[c4d.DescID, dict[int, typing.Any]]] = [
                              (c4d.DescID(c4d.DescLevel(c4d.ID_OFF_X, c4d.DTYPE_REAL, 0)),
                                  c4d.DESC_NAME: "foo.x",
                                  c4d.DESC_SHORT_NAME: "foo.x",
                                  c4d.DESC_MIN: c4d.utils.DegToRad(-360.),
                                  c4d.DESC_MAX: c4d.utils.DegToRad(360.),
                              (c4d.DescID(c4d.DescLevel(c4d.ID_OFF_Y, c4d.DTYPE_REAL, 0)),
                                  c4d.DESC_NAME: "bar.y",
                                  c4d.DESC_SHORT_NAME: "bar.y",
                                  c4d.DESC_MIN: c4d.utils.DegToRad(-45.),
                                  c4d.DESC_MAX: c4d.utils.DegToRad(45.),
                          DID_PARENT_GROUP: c4d.DescID = c4d.DescID(c4d.DescLevel(c4d.ID_GRP_STUFF, c4d.DTYPE_GROUP, 0))
                          def Init(self, node: c4d.GeListNode) -> bool:
                              """Called to initialize a DynDescription tag instance.
                              Args:
                                  node: The BaseTag instance representing this plugin object.
                              self.InitAttr(node, float, c4d.ID_OFF_X)
                              self.InitAttr(node, float, c4d.ID_OFF_Y)
                              node[c4d.ID_OFF_X] = 0.
                              node[c4d.ID_OFF_Y] = 0.
                          def Execute(self, tag: c4d.BaseTag, doc: c4d.documents.BaseDocument, op: c4d.BaseObject,
                                      bt: c4d.threading.BaseThread, priority: int, flags: int) -> int:
                              """Called when expressions are evaluated to let a tag modify a scene.
                              Does nothing in this example.
                              return c4d.EXECUTIONRESULT_OK
                          def GetDDescription(self, node: c4d.GeListNode, description: c4d.Description,
                                              flags: int) -> typing.Union[bool, tuple[bool, int]]:
                              """Called by Cinema 4D when the description of a node is being evaluated to let the node
                              dynamically modify its own description.
                              # Bail when the description cannot/is not fully loaded.
                                  return False, flags
                              for paramId, dataDictionary in DynamicDescriptionTagData.INTERFACE_DATA:
                                  if (singleId and not paramId.IsPartOf(singleId)):
                                      return True, flags
                                  data: c4d.BaseContainer = description.GetParameterI(paramId)
                                  if data is None:
                                      return True, flags
                                  for key, value in dataDictionary.items():
                                      data[key] = value
                                      print (f"{data[key]} ({key})")
                              return True, flags | c4d.DESCFLAGS_DESC_LOADED
                      def RegisterPlugins() -> None:
                          """Registers the plugins contained in this file.
                          if not c4d.plugins.RegisterTagPlugin(
                                  id=DynamicDescriptionTagData.ID_PLUGIN,
                                  str="DynDescription Tag",
                                  info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE,
                                  g=DynamicDescriptionTagData, description="tdyndescription",
                                  icon=c4d.bitmaps.InitResourceBitmap(c4d.ID_MODELING_MOVE)):
                              print("Warning: Failed to register 'DynDescription' tag plugin.")
                          RegisterPlugins()
                      Resource
                      // The description defintion of the tag Tdyndescription.
                      CONTAINER Tdyndescription
                        NAME Tdyndescription;
                          // A subcontainer, just to keep the example the same.
                          GROUP ID_GRP_STUFF
                            // Your two parameters, we will drive their min, max, and name valumes
                            // dynamically.
                            REAL ID_OFF_X { MIN -90.0; MAX 90.0; UNIT METER; STEP 0.005; CUSTOMGUI REALSLIDER; }
                            REAL ID_OFF_Y { MIN -90.0; MAX 90.0; UNIT METER; STEP 0.005; CUSTOMGUI REALSLIDER; }
                      #ifndef _TDYNDESCRIPTION_H_
                      #define _TDYNDESCRIPTION_H_
                      enum
                        ID_GRP_STUFF = 2000,
                        ID_OFF_X = 1000,
                        ID_OFF_Y,
                      #endif // _TDYNDESCRIPTION_H_
                      STRINGTABLE Tdyndescription
                        Tdyndescription "DynDescription";
                        ID_OFF_X "off.x";
                        ID_OFF_Y "off.y";
                      • mocolocoM Offline
                        mocoloco
                        Hi @ferdinand,
                        Thanks a lot for your time on this and sorry for the wrong unit on the first example I submitted with METERS instead of DEGREES - at the sometime it seems that it raised some kind of bug link to this ^^.
                        Like you wrote, I did convert the value in Radian for all the Parameters and so, but anyway the problem seems linked to the simultaneous use of UNIT DEGREES; CUSTOMGUI REALSLIDER in the resource file.
                        I ran a couple of tests and I noticed the following:
                        • When only using REAL without CUSTOMGUI REALSLIDER; in the resource file, the field behaves as it should and limits changes works as expected
                        • When using CUSTOMGUI REALSLIDER; with UNIT METERS; it does work as well as expected
                        • When using UNIT PERCENT; with MIN -100.0; MAX 100.0 and assigning the values by multiplying the slider value by Parameters[--max], printing and assigning the result to a STATICTEXTit displays the right value in degree or rad depending on the final conversion made prior display.
                        • When assigning UNIT DEGREES; with CUSTOMGUI REALSLIDER, I'm getting weird behaviour like said previously and like you noticed.
                        I haven't had the time to ran test today with INTERFACE_DATA like you suggested. I will try to do that tomorrow and I will keep you in touch about this.
                        Christophe
                          ferdinand @mocoloco
                          Hey @mocoloco,
                          No need to be sorry. For UNIT PERCENT you will have to write values as decimal values, i.e., 100% is 1.0.
                          The root problem is the weird behavior of MINSLIDERS and MAXSLIDERS not being written when messing with the description when the unit is percent. The best way to check for possible "tricks", would be to inspect a valid existing description for a REAL, UNIT DEGREE parameter to see what is what.
                          And as stated in my last posting, I unfortunately will not have the time to debug this this week, but I will give it a spin next week.
                          • mocolocoM Offline
                            mocoloco
                            Hi @ferdinand,
                            I was quite sure indeed that UNIT PERCENT will work, but I give a try to see. What I do not understand is, when I'm printing all the values existing in desc_X or desc_Y, they looks good, the value is correct, but not took completely into account on the drawing side for CUSTOMGUI REALSLIDER.
                            Like I said, if I remove the CUSTOMGUI REALSLIDER; option in the resource file and using REAL as a standard input field, whatever the UNIT I'm using, everything behaves correctly. MIN/MAX values are correctly assigned even though there is multiple REAL that need to be change. That let me lead like you to a bug linked to CUSTOMGUI REALSLIDER when only using UNIT DEGREE.
                            No problem to have a look on this next week. I can deal with that for the moment using PERCENT, as is produce slightly the same result. It is just not really convenient to guess a percentage for an angle, but that's OK.
                            Many thanks,
                            Christophe
                              ferdinand @mocoloco
                              Hey @mocoloco,
                              I had time to revisit this today with less time pressure than I had before. I made some mistakes in my prior answer:
                              • MINSLIDER and MAXSLIDER are being written even when the unit is DEGREE
                              • Being the first item or not in a group is irrelevant for the problem, the determining factor is if the new range is larger or smaller than the old one.
                              • When one overwrites an edit and slider range with a range that is larger than the old one, and the unit is degree:
                                • Both the edit and slider range remain the old value for the user when interacting with the GUI,
                                • But the position of the slider know on the slider bar reflects the new value, with the side effect that the user cannot drag the knob all the way, as the range is still clamped to the old values.
                                • And the description data that are stored reflect the new value.
                                • For any other unit other than DEGREE this does not happen.
                              You can see here the effect for the same plugin I used in my prior posting, where both parameters are initialized as [-90°, 90°]. The first one is then changed to [-45°, 45°] and the second one to [-180°, 180°]. The first parameter works fine, while the second one exhibits the effects described above with both the value and slider clamp range being unchanged while the slider position reflects the new value.
                              Fig. I: When the unit is DEGREE, increasing the value and slider range will fail. Also shown here, I compare the description of our modified bar.y parameter with a user data parameter of the same date type, unit, and range. The values are identical.
                              I also talked with one of our GUI developers and he does not see any problems with the code we use either. This is very likely a bug, since the data in the description is the same (bar.y and data.x in the example screen cast above and the print out below), but treated differently, when and only when the unit is DEGREE. I have filed an issue for that in our bug tracker.
                              I currently also do not see any good workaround for this for you. You will have to wait for a fix or the dev untangling the core issue and telling us how you can work around this. I have for now classified the issue as low priority, which means it might take some time before we get to it.
                              The script to print out the description of the active tag I used in the example:
                              import typing
                              DESC_MAP: dict[int: str] = {
                                  c4d.DESC_NAME: "DESC_NAME",
                                  c4d.DESC_SHORT_NAME: "DESC_SHORT_NAME",
                                  c4d.DESC_VERSION: "DESC_VERSION",
                                  c4d.DESC_CHILDREN: "DESC_CHILDREN",
                                  c4d.DESC_MIN: "DESC_MIN",
                                  c4d.DESC_MAX: "DESC_MAX",
                                  c4d.DESC_MINEX: "DESC_MINEX",
                                  c4d.DESC_MAXEX: "DESC_MAXEX",
                                  c4d.DESC_STEP: "DESC_STEP",
                                  c4d.DESC_ANIMATE: "DESC_ANIMATE",
                                  c4d.DESC_ANIMATE_MIX: "DESC_ANIMATE_MIX",
                                  c4d.DESC_ASKOBJECT: "DESC_ASKOBJECT",
                                  c4d.DESC_UNIT: "DESC_UNIT",
                                  c4d.DESC_PARENTGROUP: "DESC_PARENTGROUP",
                                  c4d.DESC_CYCLE: "DESC_CYCLE",
                                  c4d.DESC_HIDE: "DESC_HIDE",
                                  c4d.DESC_DEFAULT: "DESC_DEFAULT",
                                  c4d.DESC_ACCEPT: "DESC_ACCEPT",
                                  c4d.DESC_SEPARATORLINE: "DESC_SEPARATORLINE",
                                  c4d.DESC_REFUSE: "DESC_REFUSE",
                                  c4d.DESC_PARENTID: "DESC_PARENTID",
                                  c4d.DESC_CUSTOMGUI: "DESC_CUSTOMGUI",
                                  c4d.DESC_COLUMNS: "DESC_COLUMNS",
                                  c4d.DESC_LAYOUTGROUP: "DESC_LAYOUTGROUP",
                                  c4d.DESC_REMOVEABLE: "DESC_REMOVEABLE",
                                  c4d.DESC_GUIOPEN: "DESC_GUIOPEN",
                                  c4d.DESC_EDITABLE: "DESC_EDITABLE",
                                  c4d.DESC_MINSLIDER: "DESC_MINSLIDER",
                                  c4d.DESC_MAXSLIDER: "DESC_MAXSLIDER",
                                  c4d.DESC_GROUPSCALEV: "DESC_GROUPSCALEV",
                                  c4d.DESC_SCALEH: "DESC_SCALEH",
                                  c4d.DESC_LAYOUTVERSION: "DESC_LAYOUTVERSION",
                                  c4d.DESC_ALIGNLEFT: "DESC_ALIGNLEFT",
                                  c4d.DESC_FITH: "DESC_FITH",
                                  c4d.DESC_NEWLINE: "DESC_NEWLINE",
                                  c4d.DESC_TITLEBAR: "DESC_TITLEBAR",
                                  c4d.DESC_CYCLEICONS: "DESC_CYCLEICONS",
                                  c4d.DESC_CYCLESYMBOLS: "DESC_CYCLESYMBOLS",
                                  c4d.DESC_PARENT_COLLAPSE: "DESC_PARENT_COLLAPSE",
                                  c4d.DESC_FORBID_INLINE_FOLDING: "DESC_FORBID_INLINE_FOLDING",
                                  c4d.DESC_FORBID_SCALING: "DESC_FORBID_SCALING",
                                  c4d.DESC_UNIT_METER: "DESC_UNIT_METER",
                                  c4d.DESC_ANGULAR_XYZ: "DESC_ANGULAR_XYZ",
                                  c4d.DESC_INPORT: "DESC_INPORT",
                                  c4d.DESC_OUTPORT: "DESC_OUTPORT",
                                  c4d.DESC_STATICPORT: "DESC_STATICPORT",
                                  c4d.DESC_NEEDCONNECTION: "DESC_NEEDCONNECTION",
                                  c4d.DESC_MULTIPLE: "DESC_MULTIPLE",
                                  c4d.DESC_PORTONLY: "DESC_PORTONLY",
                                  c4d.DESC_CREATEPORT: "DESC_CREATEPORT",
                                  c4d.DESC_PORTSMIN: "DESC_PORTSMIN",
                                  c4d.DESC_PORTSMAX: "DESC_PORTSMAX",
                                  c4d.DESC_NOTMOVABLE: "DESC_NOTMOVABLE",
                                  c4d.DESC_EDITPORT: "DESC_EDITPORT",
                                  c4d.DESC_ITERATOR: "DESC_ITERATOR",
                                  c4d.DESC_PARENTMSG: "DESC_PARENTMSG",
                                  c4d.DESC_MATEDNOTEXT: "DESC_MATEDNOTEXT",
                                  c4d.DESC_COLUMNSMATED: "DESC_COLUMNSMATED",
                                  c4d.DESC_SHADERLINKFLAG: "DESC_SHADERLINKFLAG",
                                  c4d.DESC_NOGUISWITCH: "DESC_NOGUISWITCH",
                                  c4d.DESC_COLORALWAYSLINEAR: "DESC_COLORALWAYSLINEAR",
                                  c4d.DESC_HIDE_WHEN_INLINE: "DESC_HIDE_WHEN_INLINE",
                                  c4d.DESC_MATERIALEDITOR_LEFTSIDE: "DESC_MATERIALEDITOR_LEFTSIDE",
                                  c4d.DESC_CHANGED: "DESC_CHANGED",
                                  c4d.DESC_HIDEINFIELDS: "DESC_HIDEINFIELDS",
                                  c4d.DESC_SHOWINFIELDS: "DESC_SHOWINFIELDS",
                                  c4d.DESC_FIELDCOLORCHANNEL: "DESC_FIELDCOLORCHANNEL",
                                  c4d.DESC_FIELDDIRECTIONCHANNEL: "DESC_FIELDDIRECTIONCHANNEL",
                                  c4d.DESC_FIELDVALUECHANNEL: "DESC_FIELDVALUECHANNEL",
                                  c4d.DESC_FIELDROTATIONCHANNEL: "DESC_FIELDROTATIONCHANNEL",
                                  c4d.DESC_NODEPORT: "DESC_NODEPORT",
                                  c4d.DESC_REPLACECOMPLEXUI: "DESC_REPLACECOMPLEXUI",
                                  c4d.DESC_REPLACE_HIDE: "DESC_REPLACE_HIDE",
                                  c4d.DESC_RESOURCEPATH: "DESC_RESOURCEPATH",
                                  c4d.DESC_RESOURCELINE: "DESC_RESOURCELINE",
                                  c4d.DESC_TEMPDESCID: "DESC_TEMPDESCID",
                                  c4d.DESC_IDENT: "DESC_IDENT",
                                  c4d.DESC_IDENT_ORIGIN: "DESC_IDENT_ORIGIN",
                                  c4d.DESC_DISABLELAYOUTSWITCH: "DESC_DISABLELAYOUTSWITCH",
                                  c4d.DESC_UNIMPORTANTFORDEFAULTS: "DESC_UNIMPORTANTFORDEFAULTS",
                              op: c4d.BaseObject # The active object.
                              doc: c4d.documents.BaseDocument # The active document.
                                  tag: c4d.BaseTag = doc.GetActiveTag()
                                  if tag is None:
                                  c4d.CallCommand(13957)
                                  line: str = "{} = {}"
                                  for data, _, _ in tag.GetDescription(c4d.DESCFLAGS_DESC_NONE):
                                      print ("\n" + ("-" * 100) + "\n")
                                      for did, label in DESC_MAP.items():
                                          value: typing.Any = data[did]
                                          if value is None:
                                              continue
                                          if isinstance(value, c4d.BaseContainer):
                                              print(line.format(label, ""))
                                              for k, v in value:
                                                  print(f"\t{k}: {v}")
                                              print(line.format(label, value))
                              Output:
                              DESC_NAME = foo.x
                              DESC_ANIMATE_MIX = foo.x
                              DESC_VERSION = 3
                              DESC_MIN = -0.7853981633974483
                              DESC_MAX = 0.7853981633974483
                              DESC_MINEX = 0
                              DESC_MAXEX = 0
                              DESC_STEP = 8.726646259971648e-05
                              DESC_ANIMATE = 1
                              DESC_UNIT = 1717856114
                              DESC_CUSTOMGUI = 1000489
                              DESC_MINSLIDER = -0.7853981633974483
                              DESC_MAXSLIDER = 0.7853981633974483
                              DESC_IDENT = ID_OFF_X
                              DESC_NAME = bar.y
                              DESC_ANIMATE_MIX = bar.y
                              DESC_VERSION = 3
                              DESC_MIN = -3.141592653589793
                              DESC_MAX = 3.141592653589793
                              DESC_MINEX = 0
                              DESC_MAXEX = 0
                              DESC_ANIMATE = 1
                              DESC_MINSLIDER = -3.141592653589793
                              DESC_MAXSLIDER = 3.141592653589793
                              DESC_IDENT = ID_OFF_Y
                              DESC_NAME = User Data
                              DESC_ANIMATE_MIX = User Data
                              DESC_DEFAULT = 1
                              DESC_IDENT = ID_USERDATA
                              DESC_NAME = data.x
                              DESC_ANIMATE_MIX = data.x
                              DESC_VERSION = 3
                              DESC_MINEX = 0
                              DESC_MAXEX = 0
                              DESC_ANIMATE = 1
                              DESC_PARENTGROUP = (700, 5, 0)
                              DESC_REMOVEABLE = 1
                              DESC_EDITABLE = 1
                              • mocolocoM Offline
                                mocoloco
                                Good morning @ferdinand,
                                Thanks a lot for taking time going though this. That's exactly what I noticed last week. Changed are took into account but they are not reflected on the GUI. The only workaround that seems possible at this moment is to set MIN/MAX sliders values beyond the possible values that could be set on UserData. Doing so GUI should behave correctly.
                                Could you please let this thread unsolved for the moment, the time we get a fix on this?
                                Have a great day,
                                  ferdinand @mocoloco
                                  @mocoloco said in Can REAL MIN / MAX value be changed on Init?:
                                  Typically, we track to be fixed issues with the to fix tag which I have also added to your thread here. With that we know where to look once we fixed the issue to announce the fix. What would be the advantage of letting this topic unsolved for you? Youl will also get notified when there is a new reply in a solved topic, e.g., us announcing that we fixed something.
                                  • mocolocoM Offline
                                    mocoloco
                                    Oh, I didn't know about the to fix tag. Keeping unsolved was much more for the community 😉
                                    I the meantime I setup the resource file as discussed, and indeed, having higher values prior setting them solve the GUI problem / which is a good fix for me.
                                    Thanks a lot,
                                    Christophe
                                    • maxonM maxon moved this topic from Cinema 4D SDK on
                                    • mocolocoM Offline
                                      mocoloco
                                      Hi there,
                                      Was the issue fixed on R2023 or R2024?
                                      Christophe
