    New - Interested in .py script to auto create new takes within an existing project
    pythonr25
    7 Posts 5 Posters 1.1k Views 3 Watching
    • T Offline
      thecomishy
      Hello, new. 🙂
      I am interested in generating new takes within an existing project using the python API / SDK. I am at a loss for which library / calls to make to accomplish this. If anyone can point me to an example script that works with the same library that you can use to trigger auto takes, please share. Thank you very much in advance.
      Edit: I notice in the script log that "New Take" and "Auto Take" record.
          c4d.CallCommand(300000116) # Script Log...
          c4d.CallCommand(431000056) # New Take
          c4d.CallCommand(431000081) # Auto Take
      So conceivably I can use this (not terribly excited about it, again new). But then I would be interested in the Layers within that auto generated Take of which the script log does not record (specifically am interested in toggling the "Solo" button via code in the Layers section within the newly created Take). This does not record so I was hoping there was a call to interact with that section.
      • T Offline
        thecomishy
        Edit 2:
        https://developers.maxon.net/docs/py/2023_2/modules/c4d.modules/takesystem/TakeData/index.html
        I can use the takesystem module to interact with take data and create new takes. My next step is to insert a Layer into the Take Category via code. Does anyone know the calls to add a Category to a Take?
        • mikeudinM Offline
          mikeudin
          Check Github examples here
          https://github.com/PluginCafe/cinema4d_py_sdk_extended/tree/master/scripts/04_3d_concepts/scene_elements/take_system
          https://mikeudin.net
            Hi and welcome to the forum,
            In futur thread, please use our system to mark your thread as a question and mark it as solved once you are done. Please read our forum guideline to have more information on that feature.
            Ferdinand answered a few threads about the take system lately. This one will help you to find the information you need.
            You need to know how to create a new take and add overwrite to them so you can change some parameter value for those takes. You will have to understand what a DescID is and how to use it. You can check our c++ manual where you will find information about them.
            Of course, let us know if something is not clear, and ask questions.
            T 1 Reply Last reply Reply Quote 0
            • T Offline
              thecomishy @Manuel
              Hi @m_magalhaes
              Thanks for the reply! I ran into those exact posts looking for the answer as well.
              I am still struggling with how to get the proper usage out of FindOrAddOverrideParam with the c4d.DescID argument. I am basically digging for the coordinates of the property (I believe) to the SOLO layer via the take, which is what I want to perform in my script. Anyways, here's some of the code so far, it compiles but I don't think I'm passing my arguments correctly. Will report back.
              root = doc.GetLayerObjectRoot()
              #work with takes
              take_data = doc.GetTakeData()
              main_take = take_data.GetMainTake()
              # Its first child which is the first "actual" take.
              base_take = main_take.GetDown()
              if base_take is None:
                  msg = "Please insert at least one base take to clone."
                  raise RuntimeError(msg)
              new_take = take_data.AddTake("", None, base_take)
              new_take.SetName("Bob is your uncle.")
              take_data.SetCurrentTake(new_take)
              print(take_data.GetCurrentTake())
              # lets turn some layers on while looping thru
              LayersList = root.GetChildren()
              for layer in LayersList:
                   print(layer.GetName())
                   if layer.GetName() == "Star 5":
                         newValue = c4d.ID_LAYER_SOLO
                         descId = c4d.DescID(c4d.DescLevel(c4d.ID_LAYER_SOLO, c4d.DTYPE_LONG, 0))
                         print(descId)
                         # this makes no sense in a loop of the layers.
                         # regardless I want to use this function to
                         # turn on the layer solo "parameter" so it becomes
                         # applied to my take
                         overrideNode = new_take.FindOrAddOverrideParam(take_data, layer, descId, newValue)
              • T Offline
                thecomishy @thecomishy
                Update 2: The above code is working! Excellent!
                  Hello @thecomishy,
                  without any further questions and other postings, we will consider this topic as solved and flag it as such by Friday, 17/06/2022.
