    The second "call command" cannot be executed
    pythons24
    6 Posts 3 Posters 1.5k Views 2 Watching
      mari
      Hello, I am always indebted to you.
      When rendering is finished, I want to perform rendering again.
      However, I am in trouble because the second command is not executed.
      I want you to tell me. Please.
      from c4d import gui
      import datetime
      import time
      import threading
      PLUGIN_ID = 1058983
      renderQ = 2
      rdCheck = 0
      class MainDialog(c4d.gui.GeDialog):
          def CreateLayout(self):
              self.SetTitle('Main Dialog')
              self.AddButton(1000, 0, name="RenderStart")
              self.AddButton(1001, 0, name="stop")
          def Command(self, Id, bc):
              global renderQ
              global rdCheck
              thread_rendercheck = threading.Thread(target=RenderCheck)
              if Id == 1000:
                  RenderSetting()
                  print('start Render')
                  c4d.CallCommand(12099)
                  thread_rendercheck.start()
              elif Id == 1001:
                  renderQ = 0
                  rdCheck = 0
                  print('stop')
      def RenderSetting():
          now = datetime.datetime.now()
          renderData = doc.GetActiveRenderData()
          filename = 'path/test_'+str(now.microsecond)+'.png'
          renderData[c4d.RDATA_PATH] = filename
          renderData = doc.GetActiveRenderData().GetData()
          print(renderData[c4d.RDATA_PATH])
      def RenderCheck():
          global renderQ
          global rdCheck
          rdCheck = 1
          while renderQ > 0:
              rdCheck = c4d.CheckIsRunning(c4d.CHECKISRUNNING_EXTERNALRENDERING)
              print("...now rendering")
              time.sleep(1)
              if rdCheck == 0:
                  print('end')
                  renderQ -= 1
                  print('render more… '+str(renderQ))
                  if renderQ > 0:
                      RenderSetting()
      class MainDialogCommand(c4d.plugins.CommandData):
          dialog = None
          def Execute(self, doc):
              if self.dialog is None:
                  self.dialog = MainDialog()
              # Opens the dialog
              return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=400, defaulth=32)
          def RestoreLayout(self, sec_ref):
              # Restores the layout
              return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
      # main
          # Registers the plugin
          c4d.plugins.RegisterCommandPlugin(id=PLUGIN_ID,
                                            str="Py-RenderShread_test_kt Dialog",
                                            info=0,
                                            help="RenderTest GUI",
                                            dat=MainDialogCommand(),
                                            icon=None)
        What you are trying to do is not clear. You want to queue several renders?
        If you want to be notified about the render progress you should use RenderDocument where you can define callback that will be called during the render.
        CallCommand must be used inside the mainThread otherwise it will not work. See GeIsMainThread for more information and this page for more information about threading inside cinema 4D
          mari
          Thank you for your comment!
          Yes. I want to queue several renders.
          I also want to operate the screen while rendering.
          Is that so. thank you.
          I have another question.
          Is there an SDK to perform the rendering?
          I want to perform rendering while looking at the rendering result like [Render to Picture Viewer].
            That depend if you want to see the render while it is rendering or just the result. Using the example provided with RenderDocument you can call ShowBitmap once the render is finished.
            But that is what the render queue is offering. (Except it will display the result in a small size preview) You can also use the render queue to push renders and still have a look at them.
            If you want to display the result of the render while it's running, you will need to create your own GeDialog with a UserArea that will display the BMP. The BMP should be a global variable.
              mari
              thank you for your reply.
              If possible, I wanted to see the rendering results during rendering.
              I wanna try!thank you!
                ferdinand @mari
                Hello @mari,
                without any further activity before Wednesday, the 16.03.2022, we will consider this topic as solved and remove the "unsolved" state from this topic.
