    GetAndCheckHierarchyClone + dynamics
    7 Posts 3 Posters 1.6k Views 2 Watching
    • bacaB Offline
      baca
      I'm developing generator plugin over child polygon objects.
      It works good with GetAndCheckHierarchyClone + CurrentStateToObjectCommand which might have regular deformers underneath.
      But it doesn't work with children with applied dynamics to them.
      If it GetDeformCache() + GetCache() - maybe there's an example exist?
      • bacaB Offline
        baca
        I found it's because of OBJECT_INPUT flag. Single OBJECT_GENERATOR flag is allowing children to have dynamics...
        However original objects are observable in the viewport for a fraction of the second every frame update.
        Also Make Editable and Current State to Object applied to the generator contains generated + original objects in the null.
        How to get same experience as built-in generators, where no source objects are visible, and children dynamics is supported?
          Hi @baca, you are right you should remove the OBJECT_INPUT but this imply you need to handle them correctly.
          I'm not able to reproduce the delay you mention here my code
              def GetVirtualObjects(self, op, hierarchyhelp):
                  orig = op.GetDown()
                  if orig is None:
                      return None
                  dirty = False
                  trans = c4d.AliasTrans()
                  if not trans or not trans.Init(op.GetDocument()):
                      return False
                  dic = op.GetAndCheckHierarchyClone(hierarchyhelp, orig, c4d.HIERARCHYCLONEFLAGS_ASPOLY, True, trans)
                  trans.Translate(True)
                  if not dic["dirty"]:
                      return dic["clone"]
                  if not dic["clone"]:
                      return None
                  main = None
                  clone = dic["clone"]
                  if clone.CheckType(c4d.Onull):
                      main = clone
                      main = c4d.BaseObject(c4d.Onull)
                      clone.InsertUnder(main)
                  orig.Touch()
                  return main
          • bacaB Offline
            baca
            Hi @m_adam ,
            Adding Touch() is removing visibility of original object, but dynamics stop to work on children after that
            BTW, your code throw error:
            in GetVirtualObjects
                hierarchy_clone = op.GetAndCheckHierarchyClone(hierarchyhelp, orig, c4d.HIERARCHYCLONEFLAGS_ASPOLY, True, trans)
            TypeError: an integer is required
            Scene file test_generator.c4d
            Generator plugin test_generator.zip
              Hi @baca unfortunately I did not found time to work on your issue, and I doubt you can fix this lag as dynamics are hardcoded to be executed after Gnerator as demonstrated here (Cinema 4D priorities).
              While you could use ObjectData.AddToExecution to have the ObjectData.Execute method called after the dynamics execution, you will still have a lag, because the mesh generation should be done in the GetVirtualObject, so you will always have a 1 Scene Execution Pass difference.
              So I'm afraid I don't have a good solution for you.
                Hello @baca,
                when there are no further questions, we will consider this topic as solved by Wednesday, December the 1st.
                Cheers Ferdinand
                bacaB 1 Reply Last reply Reply Quote 0
                • bacaB Offline
                  baca @ferdinand
                  @ferdinand Thanks, no issues so far.
