    Mirror without duplicate using `MCOMMAND_MIRROR`
    s22python
    12 Posts 3 Posters 2.3k Views 2 Watching
    • K Offline
      kisaf
      Hello guys,
      It's something weird with MCOMMAND_MIRROR in S22.
      This script (thanks to m_adam) duplicates and mirrors the object.
          # Checks if selected object is valid
          if op is None:
              raise ValueError("op is none, please select one object.")
          # Defines some general settings, take care MDATA_MIRROR_VALUE, MDATA_MIRROR_SYSTEM and MDATA_MIRROR_PLANE
          settings = c4d.BaseContainer()
          settings[c4d.MDATA_MIRROR_DUPLICATE] = True
          settings[c4d.MDATA_MIRROR_SELECTIONS] = True
          settings[c4d.MDATA_MIRROR_ONPLANE] = True
          settings[c4d.MDATA_MIRROR_WELD] = True
          settings[c4d.MDATA_MIRROR_TOLERANCE] = 0.01
          # Corresponds to MDATA_MIRROR_VALUE, MDATA_MIRROR_SYSTEM and MDATA_MIRROR_PLANE
          value = 1000.0
          system = 0 # 0 = Object, 1 = World
          plane = 1 # 0 = XY, 1 = ZY, 2 = XZ
          if not 0 <= system < 2:
              raise ValueError("System can only be 0 or 1")
          # Buffer position vector
          pos = c4d.Vector()
          # Calculates Local (Object) coordinates
          if system == 0:
              globalMatrix = op.GetMg()
              if plane == 0:
                  pos = globalMatrix.v3
              elif plane == 1:
                  pos = globalMatrix.v1
              elif plane == 2:
                  pos = globalMatrix.v2
              settings[c4d.MDATA_MIRROR_POINT] = globalMatrix.off + pos * value
              settings[c4d.MDATA_MIRROR_VECTOR] = pos
          # Calculates World coordinates
          elif system == 1:
              if plane == 0:
                  pos = c4d.Vector(0.0, 0.0, 1.0)
              elif plane == 1:
                  pos = c4d.Vector(1.0, 0.0, 0.0)
              elif plane == 2:
                  pos = c4d.Vector(0.0, 1.0, 0.0)
              settings[c4d.MDATA_MIRROR_POINT] = pos * value
          # Send the Modeling Operation
          res = c4d.utils.SendModelingCommand(c4d.MCOMMAND_MIRROR,
                                              [op],
                                              c4d.MODELINGCOMMANDMODE_ALL,
                                              settings,
                                              doc)
      However, if I change
      to
      settings[c4d.MDATA_MIRROR_DUPLICATE] = False
      Script doesn't make anything.
      In R20 it works.
      Is it ok? Is there any way to just mirror the object without duplicate it?
      P.S. Also, if I use Mirror (https://help.maxon.net/index.html#5633) with unchecked Duplicate Points everything works (in S22).
      Cinema 4D S22.118 Windows 10
        this look like a bug, I've opened a bug report
        Manue
        • K Offline
          kisaf
          Hi, I've just tested this script in R23. It doesn't work 😞
          One of my own scripts cannot work without this function.
          Guys, you're really awesome! I love C4D, and hope you can fix it 😄
          May be I can help somehow? I can upload the example scene, if you need it.
            this will be probably fixed for futur updates but i doubt that this will be fixed for previous version.
            The only way to go is to create your own function to mirror the polygon. This can be really long if you want to support uvs, texture, selection tag etc.
            Sorry for the inconvenient.
            K 1 Reply Last reply Reply Quote 0
            • K Offline
              kisaf @Manuel
              @m_magalhaes
              Got it, thanks 🙂
              • K Offline
                kisaf
                Hello guys,
                This bug is still exists in S24. I made a video to show how it worked before (R21) and now (S22, R23, S24).
                For test I used the script from this page. The only difference I made is decreased value from 1000.0 to 0. It's just for convenience.
                This script should mirrors selected object, when settings[c4d.MDATA_MIRROR_DUPLICATE] is False. It works in R21 and doesn't work in any late releases.
                Could you fix it? I'm still using R21 because of this bug 😞
                  our developers are aware of the bug and i can't say when it will be fixed. I understand it's not pleasant for you.
                  • K Offline
                    kisaf
                    Roger that, thanks again.
                    I wasn't sure that the developers were aware. Sorry for annoy you 🙂
                    • F Offline
                      Fritz
                      Hi kisaf,
                      if you switch in the SendModelingCommand from MODELINGCOMMANDMODE_ALL to MODELINGCOMMANDMODE_POLYGONSELECTION it should work until the mirror in object mode is fixed.
                      Regards
                      Fritz
                      K 1 Reply Last reply Reply Quote 1
                      • K Offline
                        kisaf @Fritz
                        @fritz thank you very much, it works!
                          I've missed that one, thanks a lot @Fritz
                            This have been fixe and will be available in a futur update.
