    CENTER AN OBJECT IN THE VIEW AND MAXIMIZE ITS SIZE
    3 Posts 3 Posters 1.1k Views 2 Watching
    • P Offline
      pyr
      I got a setup with a stationary camera. i need to keep the object centered in my view and maximize its size but i can't change the rotation / position of my camera.
      what i have so far is the following:
      i calculate the center of the objekt and change the offset accordingly to center the object. now if i want to zoom in my offset calculations are wrong again.
      fovProblem.c4d
      edit:
      can someone please move the thread into the right subforum?
        Manuel @pyr
        Did you had a look at this thread the problem was almost the same (but to create render).
        @ferdinand also answer to this question on Core 4D (that was a bit harder to find)
        Let us know if those resource helped you or not.
          Hello @pyr,
          without any further questions or replies, we will consider this topic as solved by Monday and flag it accordingly.
