Error: Wrong indentation of namespace member
I use namespaces a lot, and I indent the code within the namespace scope. That also how Xcode auto-formats it.
In one of my projects, this works fine:
In another one, it throws errors that can only be "fixed" by not indenting the code. That really annoys me.
Both projects were created with the R23 Project Tool, and both
projectdefinition.txtlook like this (except for theModuleId, of course):// Supported platforms - can be [Win64;OSX] Platform=Win64;OSX // Type of project - can be [Lib;DLL;App] Type=DLL // API dependencies APIS=core.framework;cinema.framework;mesh_misc.framework;math.framework; // C4D component C4D=true stylecheck.level=3 // must be set after c4d=true stylecheck.aswarnings=false stylecheck.max-linecount=300 // Custom ID ModuleId=de.frankwilleke.dim4nsionsWhy do these projects behave different?
Thanks in advance!Cheers,
Frank -
Hi Frank,
not sure if it is the culprit, but in your working version you have an empty line at the beginning of the namespace scope and in the version where it does not work, you have these not.
Ferdinand -
I also thought about this. But it doesn’t change the errors. Neither do normal or doxy comments.
At the bottom of the second screenshot you can see that the next function also gets the error, and so does everything in the namespace scope.
Are both header files or is the upper one a cpp file?
Also, do the errors com from Intellisense or is it a style check/compilation error?If the LLVM convention is used, the error is correct. LLVM namespace formatting conventions don't use any intentaion. You might be a able to fix this by ignoring this error explicitly.
It also might be caused by a bug in XCode. -
Hi Frank,
we will discuss your thread tomorrow, this was just me "shooting from the hip"
I am also not sure if we are talking about the same thing, so I meant this:
Ferdinand -
I did contact our dev, it seem to be a bug in our source processor.
In any case, you can specify the following in the projectdefinition.txt if you want to use your own indentation:stylecheck.indentation=falseRemember there's a lot of option you can set or not in the projection definition, see our documentation.
Manuel -
Thanks! Yeah, that would’ve been my solution, too. I just wonder why the error occurs in the first place. In the project where the error doesn’t come up, I didn’t set that option, so there has to be a difference somewhere, and I wanted to know why.
Anyway, I’ll just suppress it
thank you.Cheers,
Frank -
The answer from the dev.
We use indentation for namespaces which start with an upper case letter and no indentation for namespaces with a lower case letter.
Namespaces starting with lower case are used for code, and there we don't use indentation to avoid excessive indentation of the code.
Screen space is precious there! Namespaces starting with upper case are used for grouping simple entities such asnamespace FileFormats { MAXON_DECLARATION(FileFormat, Browsable, "net.maxon.fileformat.browsable"); MAXON_DECLARATION(FileFormat, File, "net.maxon.fileformat.file"); MAXON_DECLARATION(FileFormat, MaxonDocumentBinary, "net.maxon.fileformat.maxondocumentbinary"); MAXON_DECLARATION(FileFormat, MaxonDocumentJson, "net.maxon.fileformat.maxondocumentjson"); MAXON_DECLARATION(FileFormat, MaxonDocumentXml, "net.maxon.fileformat.maxondocumentxml"); }And that's your case.
Manuel -
Wow, I never thought of that.
Very good to know, thank you for asking!
Cheers & have a nice weekend,
Frank
