    Thinking Particles- How to Set "Settings"
    Cinema 4D SDK
    r23 python
    • I
      ivodow
      In Simulate -> Thinking Particles -> TP Settings... there are a series of UI elements at the top of the General tab controlling global settings for the TP system:
      Max. Particles
      Force this Setting
      Show Objects
      View Type
      How do I set these from python? (I specifically need Max Particles and View Type.) I have been all over the docs and cannot seem to find them.
      Thank you.
      • ManuelM
        you can access them in the BaseContainer of the ParticleSystem.
            # Retrieves the Particles System of the current document
            pSys = doc.GetParticleSystem()
            if pSys is None:
                raise RuntimeError("op is none, please select one object.")
            bc = pSys.GetDataInstance()
            bc[54] = 300
        # Execute main()
        Those are the ids corresponding.
        #define TP_VIEWTYPE			50
        #define TP_VIEWMESH			51
        #define TP_FORCEGLOBAL	                52
        #define TP_ON				53
        #define TP_NUMLIMIT			54
        the ViewType's ID:
        // Particle View Typen
        #define VTYPE_NONE		0
        #define VTYPE_FLAKES	        1
        #define VTYPE_DOTS		2
        #define VTYPE_TICKS		3
        #define VTYPE_DROPS		4
        #define VTYPE_BOX		5
        #define VTYPE_GLOBAL            6
        • I
          ivodow
          Hi Manuel,
          Thank you for your answer, I appreciate it.
          So that in the future I can find these things myself, I tried searching searching your Python docs for TP_VIEWTYPE. No results were returned. I assume those #defines are drawn from a C++ header, so I tried searching for TP_VIEWTYPE here, also with no success.
          Where can I find full searchable API documentation for Cinema 4D? (Like that for Rhino Common)
          • ManuelM
            This are copy/paste directly from our code. They are not available, not documented. That's why i 've provided them.
            You can have a look at that page for having informations about the IDs that page
            • I
              ivodow
              Okay, thank you again.
