    Plugin compiled on macOS Catalina for R23, not working on Big Sur?
    r23macosc++
    22 Posts 3 Posters 18.1k Views 1 Watching
    • r_giganteR Offline
      r_gigante
      Hi @fwilleke80, I'm using 11.3 and I've no issue on running the plugin BigSur.
      With regard having the code running on your customers' machine I think you need to notarise (is it what you mean by sign my plugins?) the plugins before giving them otherwise the security mechanism found in BigSur might easily have block them.
      He has answered the usual security question that macOS shows him (as I don't sign my plugins yet), but no success.
      • Can you ask your customer what "usual" security questions he answered?
      • Can you ask your customer before unpacking the zip archive, that maybe he has downloaded from an email or a website, to run $ xattr -d "com.apple.quarantine <zip archive to your plugin>"
      Cheers, R
      kbarK 1 Reply Last reply Reply Quote 0
      • kbarK Offline
        kbar @fwilleke80
        @fwilleke80 said in Plugin compiled on macOS Catalina for R23, not working on Big Sur?:
        Hmmm. Are you signing your plugins?
        Yes I sign and notarize all my plugins as part of my build process. It can all be automated via command line.
        • kbarK Offline
          kbar @r_gigante
          @r_gigante said in Plugin compiled on macOS Catalina for R23, not working on Big Sur?:
          Code Signing and Notarizing are two separate things. First you sign your plugins, then you zip them up and send the zip to apple for notarization.
          r_giganteR 1 Reply Last reply Reply Quote 0
            r_gigante @kbar
            Thanks @kbar it's clear to me, I just wanted to know what actually @fwilleke80 was meaning. And for those listening you can sign a plugin during or after the building process.
            Cheers, R
            • fwilleke80F Offline
              fwilleke80
              Ah, thanks, I'll ask him to try that!
              So, to make the plugin run on my beta testers' Macs with Bir Sur without warnings, I not only need to sign the binary, I also need to send the binary to Apple to have it notarised? Every single time I release a beta version to my testers?? 😱
              Frank
              www.frankwilleke.de
                fwilleke80
                Hm, tester days, he did the Terminal call, and he had the security warning when starting Cinema 4D (that the binary from my product is from an unknown developer, so it won't be loaded). He then opened his System Preferences >> Security & Privacy, and confirmed that the library should be loaded. But no success 😞
                www.frankwilleke.de
                  r_gigante @fwilleke80
                  Frank
                  This is actually what we do in our building pipeline. My suggestion is to automate the process which, being completely terminal based, should be far from being rocket science.
                  Cheers, R
                    fwilleke80
                    That's what I gotta do then πŸ˜‰
                    Thanks & greetings,
                    Frank
                    www.frankwilleke.de
                    • kbarK Offline
                      kbar @fwilleke80
                      @fwilleke80 it is what I do in my build system, for every build.
                      I automated my build system using Jenkins pipelines. But you can also just write bash scripts and batch files instead, since that is effectively what I do in Jenkins anyway.
                      My code is all pulled from GitHub, project tool runs, all additional 3rd party libraries are built, plugins compiled, signed, zipped up, sent to apple for notarization and then uploaded to AWS S3 and my customers can automatically down the new updates after any new build is marked as published.
                      Took a while to set up but is such a time saver in the end. I can build all my plugins for every version of C4D and have them available for customers with just one click. It’s a full rebuild every single time I press the button.
                      https://Jenkins.io. Then look at pipelines.
                        fwilleke80
                        Thanks, that's a good tip! I'll try that out!
                        By the way, @r_gigante , turns out my tester hat installed 23.008 on Big Sur, while I had compiled the plugin against 23.110... so... it works now. Thanks πŸ™‚
                        Frank
                        www.frankwilleke.de
                          fwilleke80
                          One follow-up question:
                          I have followed the steps described in https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_dev_macos.html#page_maxonapi_dev_macos_notarization_xcodecodesigning. Created a ZIP of my plugin (using Python, but it's still a normal ZIP, with the plugin binary, res folder etc.), signed it with my certificate from apple, and uploaded it using the xcrun altool --notarize-app ...and-so-on... call. Upload successful.
                          However, the plugin is never notarised, and looking into the notarisation history, it tells me:
                          2020-11-27 08:44:14 +0000 b1cb2d34-a374-40b4-95d3-64a5d9e4df38 invalid 2 Package Invalid
                          I saw posts on the web from people who had the same problem. They fixed it by enabling "Hardened Runtime" in their projects. I already did that, as described in the SDK docs, but the problem persists.
                          Is there any way to find out what's to invalid about the package?
                          Frank
                          www.frankwilleke.de
                            fwilleke80
                            Oh wait, got it by displaying the notarisation log. The binary had no timestamp.
                            After googling a bit, I fixed it by adding --timestamp=http://timestamp.apple.com/ts01 to "Other Code Signing Flags", and it was notarised successfully! πŸ™‚
                            Is --timestamp=http://timestamp.apple.com/ts01 a good choice for this flag? The SDK docs just say "include a secure timestamp with your code-signing signature;", which is not too much information πŸ˜‰
                            www.frankwilleke.de
                            r_giganteR 1 Reply Last reply Reply Quote 1
                            • kbarK Offline
                              kbar
                              This post is deleted!
                                @fwilleke80 Thanks for the follow-up Frank! In all the previous cases I always notarized without specifying the timestamp. I'll again and in case update the guide.
                                Cheers, r
                                  fwilleke80
                                  How did you do it without a timestamp?
                                  The SDK explicitly says a timestamp is needed:
                                  https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_dev_macos.html#page_maxonapi_dev_macos_notarization_preliminary
                                  But yes, a bit more detailed information would be appreciated πŸ˜‰
                                  www.frankwilleke.de
                                  • kbarK Offline
                                    kbar @fwilleke80
                                    @fwilleke80 I think setting the hardened runtime when you code sign solves the timestamp issue. I don’t set a timestamp.
                                    codesign --force --options runtime --sign 'Developer ID Application: YOURCOMPANYNAME' 'sdk/plugins/yourplugin/yourplugin.xlib'
                                      fwilleke80
                                      Ah, ok. I've got that enabled, too. I guess adding a timestamp doesn't hurt.
                                      www.frankwilleke.de
                                        r_gigante @kbar
                                        @kbar said in Plugin compiled on macOS Catalina for R23, not working on Big Sur?:
                                        Thanks a lot Kent, for pointing this out!
                                        The one below is the string I use which, as said by Kent, doesn't need the timestamp because of the hardened runtime.
                                        codesign -f -s "Developer ID Application: <YOUR DEV ID>" --options runtime <binary file>.xlib
                                        Documentation updated accordingly
