    Plugin compiled on macOS Catalina for R23, not working on Big Sur?
    r23macosc++
    22 Posts 3 Posters 15.2k Views 1 Watching
    • fwilleke80F Offline
      fwilleke80
      one of my beta testers reports that since he updated to macOS Big Sur, my plugin does not show up in the Extensions menu anymore. He has answered the usual security question that macOS shows him (as I don't sign my plugins yet), but no success.
      I don't want to update to Big Sur just yet, as I'm pretty sure that will kill Xcode 10, and then I can't build my plugins for R20 anymore. Oh Apple πŸ™„
      Anyway, does anybody know how I can fix that?
      Cheers & thanks,
      Frank
      www.frankwilleke.de
      kbarK 1 Reply Last reply Reply Quote 0
      • kbarK Offline
        kbar @fwilleke80
        @fwilleke80 just a side note: I am building my R20 plugins using code 11.4.1 and they work fine.
          fwilleke80
          Hmmm. Are you signing your plugins?
          I have XCode 11, but not the latest version, because the App Store keeps telling me the update has failed, before it even starts doing anything πŸ˜• maybe that’s the reason.
          EDIT: Hm, I have Xcode 11.6. It'S the 11.7 update that wouldn't download.
          www.frankwilleke.de
            fwilleke80
            Btw, @kbar I had problems compiling my R20 plugins with Xcode 11, I run into a lot of debug breaks that all have to do with GePrint() and GeDebugOut(). With Xcode 10 that happens almost never, and with the good old Xcode 8.2.1, everything runs smooth... but 8.2.1 only runs on my old MacBook.
            www.frankwilleke.de
            • r_giganteR Offline
              r_gigante
              Hi @fwilleke80, I'm using 11.3 and I've no issue on running the plugin BigSur.
              With regard having the code running on your customers' machine I think you need to notarise (is it what you mean by sign my plugins?) the plugins before giving them otherwise the security mechanism found in BigSur might easily have block them.
              • Can you ask your customer what "usual" security questions he answered?
              • Can you ask your customer before unpacking the zip archive, that maybe he has downloaded from an email or a website, to run $ xattr -d "com.apple.quarantine <zip archive to your plugin>"
              Cheers, R
              • kbarK Offline
                kbar @fwilleke80
                @fwilleke80 said in Plugin compiled on macOS Catalina for R23, not working on Big Sur?:
                Yes I sign and notarize all my plugins as part of my build process. It can all be automated via command line.
                • kbarK Offline
                  kbar @r_gigante
                  @r_gigante said in Plugin compiled on macOS Catalina for R23, not working on Big Sur?:
                  Code Signing and Notarizing are two separate things. First you sign your plugins, then you zip them up and send the zip to apple for notarization.
                  r_giganteR 1 Reply Last reply Reply Quote 0
                    r_gigante @kbar
                    Thanks @kbar it's clear to me, I just wanted to know what actually @fwilleke80 was meaning. And for those listening you can sign a plugin during or after the building process.
                    Cheers, R
                      fwilleke80
                      Ah, thanks, I'll ask him to try that!
                      So, to make the plugin run on my beta testers' Macs with Bir Sur without warnings, I not only need to sign the binary, I also need to send the binary to Apple to have it notarised? Every single time I release a beta version to my testers?? 😱
                      Frank
                      www.frankwilleke.de
                        fwilleke80
                        Hm, tester days, he did the Terminal call, and he had the security warning when starting Cinema 4D (that the binary from my product is from an unknown developer, so it won't be loaded). He then opened his System Preferences >> Security & Privacy, and confirmed that the library should be loaded. But no success 😞
                        www.frankwilleke.de
                          r_gigante @fwilleke80
                          Frank
                          This is actually what we do in our building pipeline. My suggestion is to automate the process which, being completely terminal based, should be far from being rocket science.
                          Cheers, R
                            fwilleke80
                            That's what I gotta do then πŸ˜‰
                            Thanks & greetings,
                            Frank
                            www.frankwilleke.de
                            • kbarK Offline
                              kbar @fwilleke80
                              @fwilleke80 it is what I do in my build system, for every build.
                              I automated my build system using Jenkins pipelines. But you can also just write bash scripts and batch files instead, since that is effectively what I do in Jenkins anyway.
                              My code is all pulled from GitHub, project tool runs, all additional 3rd party libraries are built, plugins compiled, signed, zipped up, sent to apple for notarization and then uploaded to AWS S3 and my customers can automatically down the new updates after any new build is marked as published.
                              Took a while to set up but is such a time saver in the end. I can build all my plugins for every version of C4D and have them available for customers with just one click. It’s a full rebuild every single time I press the button.
                              https://Jenkins.io. Then look at pipelines.
                                fwilleke80
                                Thanks, that's a good tip! I'll try that out!
                                By the way, @r_gigante , turns out my tester hat installed 23.008 on Big Sur, while I had compiled the plugin against 23.110... so... it works now. Thanks πŸ™‚
                                Frank
                                www.frankwilleke.de
                                  fwilleke80
                                  One follow-up question:
                                  I have followed the steps described in https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_dev_macos.html#page_maxonapi_dev_macos_notarization_xcodecodesigning. Created a ZIP of my plugin (using Python, but it's still a normal ZIP, with the plugin binary, res folder etc.), signed it with my certificate from apple, and uploaded it using the xcrun altool --notarize-app ...and-so-on... call. Upload successful.
                                  However, the plugin is never notarised, and looking into the notarisation history, it tells me:
                                  2020-11-27 08:44:14 +0000 b1cb2d34-a374-40b4-95d3-64a5d9e4df38 invalid 2 Package Invalid
                                  I saw posts on the web from people who had the same problem. They fixed it by enabling "Hardened Runtime" in their projects. I already did that, as described in the SDK docs, but the problem persists.
                                  Is there any way to find out what's to invalid about the package?
                                  Frank
                                  www.frankwilleke.de
                                    fwilleke80
                                    Oh wait, got it by displaying the notarisation log. The binary had no timestamp.
                                    After googling a bit, I fixed it by adding --timestamp=http://timestamp.apple.com/ts01 to "Other Code Signing Flags", and it was notarised successfully! πŸ™‚
                                    Is --timestamp=http://timestamp.apple.com/ts01 a good choice for this flag? The SDK docs just say "include a secure timestamp with your code-signing signature;", which is not too much information πŸ˜‰
                                    www.frankwilleke.de
                                    r_giganteR 1 Reply Last reply Reply Quote 1
                                    • kbarK Offline
                                      kbar
                                      This post is deleted!
                                        @fwilleke80 Thanks for the follow-up Frank! In all the previous cases I always notarized without specifying the timestamp. I'll again and in case update the guide.
                                        Cheers, r
                                          fwilleke80
                                          How did you do it without a timestamp?
                                          The SDK explicitly says a timestamp is needed:
                                          https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_dev_macos.html#page_maxonapi_dev_macos_notarization_preliminary
                                          But yes, a bit more detailed information would be appreciated πŸ˜‰
                                          www.frankwilleke.de
                                          • kbarK Offline
                                            kbar @fwilleke80
                                            @fwilleke80 I think setting the hardened runtime when you code sign solves the timestamp issue. I don’t set a timestamp.
                                            codesign --force --options runtime --sign 'Developer ID Application: YOURCOMPANYNAME' 'sdk/plugins/yourplugin/yourplugin.xlib'
