    "Current Take" doesn't override layer processes that made by scripting
    3 Posts 2 Posters 679 Views 2 Watching
    • delizadeD Offline
      delizade
      I change layer properties via script and I need current take override those layer processes. But when I changed a property via scripting current take can't see any changins and does not override any data.
      How can I do that?
        hi and welcome to our forum,
        For your next threads, please help us keeping things organised and clean. I know it's not your priority but it really simplify our work here.
        • Q&A New Functionality.
        • How to Post Questions especially the tagging part.
        I've added the tags and marked this thread as a question so when you considered it as solved, please change the state 🙂
        About your question the take system is not automatic for scripts.
        You can have a look at our example in python
        Using Autotake
        Other example about takes
        How to create layers
        Based on those example i came with this test that is working as expected. Using AutoTake. You have to pass to the function two object that will be compared.
        So before doing the change, make a clone of your object.
        But you can also write parameter directly on the take itself. (see above links)
            rootLayers = doc.GetLayerObjectRoot()
            if rootLayers is None:
                raise RuntimeError("Failed to retrieve the Root Layer.")
            layer = rootLayers.GetDown()
            if layer is None:
                raise ValueError("layer is None")
            layerClone = layer.GetClone(c4d.COPYFLAGS_0)
            # Changes the radius of the sphere in scene
            layer[c4d.ID_LAYER_VIEW] = False
            # Gets the TakeData from the active document (holds all information about Takes)
            takeData = doc.GetTakeData()
            if takeData is None:
                raise RuntimeError("Failed to retrieve the take data.")
            # Checks if there is some TakeData and the current mode is set to auto Take
            if takeData and takeData.GetTakeMode() == c4d.TAKE_MODE_AUTO:
                # Retrieves the active Take
                currentTake = takeData.GetCurrentTake()
                # If there is an active Take, automatically generate a Take based on the difference between op and undoObject
                if currentTake:
                    currentTake.AutoTake(takeData, layer, layerClone)
                # Pushes an update event to Cinema 4D
        If you have any question, feel free to ask.
        • delizadeD Offline
          delizade
          thank you for your help.
