    id PluginMessage () when the scene loaded
    pythonsdk
    12 Posts 4 Posters 2.8k Views 3 Watching
    • A Offline
      ac3 @C4DS
      @C4DS, Hi!
      it is very sad. I don't really want to rewrite the plugin from Python to C++ 😢
      • A Offline
        ac3
        @C4DS said in id PluginMessage () when the scene loaded:
        I don't think this will work for a Python plugin, but with C++ you can provide a SceneHook and use message MSG_DOCUMENTINFO_TYPE_LOAD
        Maybe there is another way to start the plugin automatically? Mb is not PluginMessage ()
          you can see in this thread that it's not possible with python.
          But maybe you can use another workflow. You can have another plugin asking for a directory, load every document on that directory, call your script that will work on the document, and close the document.
          You can only write the SceneHookData with c++ and that SceneHookData will call your python command so you don't need to rewrite it.
          A 2 Replies Last reply Reply Quote 0
          • A Offline
            ac3 @Manuel
            @m_magalhaes, Hi!
            Thanks for the answer, I will try this and answer later.
            • A Offline
              ac3 @Manuel
              Hi!
              Do you have examples of a plugin written with SceneHookData? I am more proficient in python than c ++ 😢
              • A Offline
                ac3
                @m_magalhaes, Hi, can you answer me? plz
                  if my memory does not betray me, MSG_DOCUMENTINFO is being broadcasted to all nodes in the scene. So if you want to stay in Python, you could simply hijack a node type. One promising candidate could be PreferenceData, although I cannot guarantee that Cinema will also send document notifications to these nodes, since they are not part of a scene.
                  zipit
                  1 Reply Last reply Reply Quote -1
                    Sorry for the delay.
                    we have this example.
                    The most important is ou c++ documentation
                    you can see an example in the BaseDocument Manual
                    class pc12835_scenehook : public SceneHookData
                    	static NodeData* Alloc() { return NewObjClear(pc12835_scenehook); }
                    	Bool Message(GeListNode* node, Int32 type, void* data) override
                    		if (type == MSG_DOCUMENTINFO)
                    			DocumentInfoData* const msg = static_cast<DocumentInfoData*>(data);
                    			if (msg == nullptr)
                    				return false;
                    			// switch message sub-type
                    			switch (msg->type)
                    				case MSG_DOCUMENTINFO_TYPE_LOAD:
                    					ApplicationOutput("document is loaded"_s);
                    					break;
                    				case MSG_DOCUMENTINFO_TYPE_UNDO:
                    				case MSG_DOCUMENTINFO_TYPE_REDO:
                    					ApplicationOutput("undo or redo done"_s);
                    					break;
                    			return true;
                    		return SceneHookData::Message(node, type, data);
                    As @zipit said, the message is broadcast to all NodeData so using a PreferenceData.
                    We have an example on github but you don't need all that code.
                    After trying it myself, i couldn't make it work. It seems that the Message function is never called.
                    • A Offline
                      ac3 @Manuel
                      @m_magalhaes Hi, where in this code does the script start to run and call the python code? Or did I misunderstand something?
                        sorry I was focused on calling a command and not a script.
                        Even if it's pretty simple, it's not as simple as i expected to run a python script, sorry about that.
                        Be careful that you need to create the script and relaunch c4d to be able to find it by its name.
                        The idea is to retrieve the ID of the script and use callCommand to execute it. (as you can do with any commandData IDs)
                        you can retrieve the ScriptList with GetScriptHead witch return a GeListHead
                        So you can retrieve the first with GetFirst and compare the name.
                        If you find one, you can simply return it's IDs using GetDynamicScriptID and return it.
                        You now just have to use CallCommand with this ID. (be aware that this CallCommand will create an undo step in the undo stack)
                        So your script will be executed when a new document is loaded.
                        #include "maxon/apibase.h"
                        #include "maxon/errorbase.h"
                        #include "maxon/errortypes.h"
                        #include "maxon/file_utilities.h"
                        #include "maxon/application.h"
                        #include "c4d_general.h"
                        #include "c4d_commanddata.h"
                        #include "c4d_baseplugin.h"
                        #include "c4d_scenehookdata.h"
                        #include "c4d_baselist.h"
                        static Int32 GetScriptID(const maxon::String& scriptName)
                        	iferr_scope;
                        	// check all script
                        	// Retrieves the script head
                        	BaseList2D* scriptHead = static_cast<BaseList2D*>(GetScriptHead(0)->GetFirst());
                        	// for all script
                        	for (BaseList2D* script = scriptHead; script != nullptr; script = script->GetNext())
                        		// retrieves the name of the script
                        		maxon::String name = script->GetName();
                        		// if the name match the argument, return the id of the script
                        		if (name.IsEqual(scriptName))
                        			return GetDynamicScriptID(script);
                        	// return NOTOK if no script founded.
                        	return NOTOK;
                        			if (msg == nullptr)
                        				return false;
                        			switch (msg->type)
                        					// define my script name
                        					maxon::String scriptName = "myscript"_s;
                        					// search the ID of the scrip
                        					const Int32 scriptID = GetScriptID(scriptName);
                        					// if the script have been founded, execute it.
                        					if (scriptID != NOTOK)
                        						CallCommand(scriptID);
                        					break;
                        					break;
                        			return true;
                        Of course you need to register your sceneHookData with RegisterSceneHookPlugin
