Setting Strength Values of the Pose Morph Target?
Apart from dragging the parameter to the console, how do I set the strength values of "Pose Morph Target" in Animated Mode using Python?
You can see an illustration of the problem here:
https://www.dropbox.com/s/dcc34oyaxp81p9q/c4d271_setting_value_of_pose_morph_target.jpg?dl=0Here is my WIP code:
def main(): tag = doc.GetActiveTag() morph = tag.GetMorph(1) node = morph.GetFirst() # I'm stuck at GetParam and SetParam node.GetParam(index) # No matter what index I put, it returns none. node.SetParam # I can't use the code because I lack the DESCID from the GetParam
Regards,
Ben -
GetParam()
andSetParam()
have nothing to do with strength; they are used to set arbitrary overwritten object parameters. See CAMorphNode Manual.The
DescID
of the morph's "Strength" value is obtained withGetMorphID()
, see CAPoseMorphTag Manual. -
you should have a look at the manuals @PluginStudent linked you.
you can do it in several ways
import c4d from c4d import gui # Welcome to the world of Python # Main function def main(): tag = doc.GetActiveTag() # Using descid ginven by the function for i in xrange( tag.GetMorphCount()): descID = tag.GetMorphID(i) tag[descID] = .5 # Using get/set parameter for i in xrange( tag.GetMorphCount()): descID = tag.GetMorphID(i) currentValue = tag.GetParameter(descID, c4d.DESCFLAGS_GET_NONE) print descID, currentValue tag.SetParameter(descID, currentValue + 0.6, c4d.DESCFLAGS_GET_NONE ) # Using calculate id for i in xrange( tag.GetMorphCount()): sliderID = 1001 + i * 100 tag[4000,sliderID] = .1 c4d.EventAdd() # Execute main() if __name__=='__main__': main()
Manuel -
@PluginStudent @m_magalhaes
Thanks for the reference link and sample code. It works as expected.
Thanks also for the giving different methods in setting the strength.
Provides more flexibility. -
I i_mazlov referenced this topic on
