    Debugger says: You MUST NOT NEVER EVER use a modal dialog in a timer
    r20r21c++maxon apiclassic apimacos
    24 Posts 3 Posters 18.5k Views 2 Watching
      I just notice that the message actually does sound like a joke... "You MUST NOT NEVER EVER" is a double negative, so it is in fact encouraging the use of model dialogs in a timer 😄
      Lol, jeah, I noticed that too, also the capslock part gives it probably an unintended comedic connotation.
        hello,
        Sorry for the delay i had to ask the devs.
        The old Events, like the CoreMessage are executed furing certain OS input events and periodically during the timer.
        So that's why that message is triggered inside a timer and you got the Message.
        "Is it so bad ? "
        Timer Events for all subscribers are blocked.
        Further Event (nested) are blocked.
        It could be bad if you are sending messages and are waiting for an answers.
        To avoid that you can enqueue a job to the main thread.
        ExecuteOnMainThread doesn't help here because it directly execute the lambda if you are already in the main thread.
        • fwilleke80F Offline
          fwilleke80
          Thank you, Manuel!
            fwilleke80
            Hmm, any hints on how one might do this?
            I looked at the Jobs Manual in the SDK, but didn't quite get it.
            I guess it would work somehow like this:
            struct Credentials
            	String username;
            	String password;
            // Ask the user for credentials, so we can acquire a new access token
            class GetCredentialsJob : public maxon::JobInterfaceTemplate<GetCredentialsJob, Credentials>
            	GetCredentialsJob() { };
            	// function operator with the actual workload
            	maxon::Result<void> operator ()()
            		Credentials credentials;
            		GetUserCredentials(credentials.username, credentials.password);
            		// store result
            		return SetResult(credentials); // ERROR: Rvalue reference to type 'Credentials' cannot bind to lvalue of type 'Credentials'
            auto job = GetCredentialsJob::Create();
            job.Enqueue(maxon::JobQueueInterface::GetMainThreadQueue()); // ERROR: No member named 'Enqueue' in ...
            // Wait for job to finish, then somehow get the results and do something
            if (job.Wait()) // ERROR: No member named 'Wait' in ...
            	Credentials credentials = job.GetResult(); // ERROR: No member named 'GetResult' in ...
            This seems like an awful lot of code, just to open a simple dialog and get two strings from it. And since it throws a number of errors, it's not even finished yet.
              hello,
              you can pass a lambda function directly as suggest other enqueue method definitions
              That should be a bit less code.
              maxon::JobRef::Enqueue(
              	[]() -> maxon::Result<void>
              			String res = "temporary";
              		if (!RenameDialog(&res))
              			return maxon::UnknownError(MAXON_SOURCE_LOCATION);
              		ApplicationOutput("you new password is @", res);
              		return maxon::OK;
              	, maxon::JobQueueRef::GetMainThreadQueue()) iferr_return;
              You can send a message on your lambda that will update your plugins (i don't know how you are handling your licences).
                fwilleke80
                Ah, great! Yes, that looks a lot more compact, thank you!
                  fwilleke80
                  Hmm, referring to your code example, I am doing it like this now:
                  String username, password;
                  Bool dialogResult;
                  maxon::JobRef ref = maxon::JobRef::Enqueue(
                  			[&username, &password, &dialogResult] () -> Bool
                  				dialogResult = GetUserCredentials(username, password);
                  				return dialogResult;
                  			}, maxon::JobQueueRef::GetMainThreadQueue()) iferr_return;
                  // Wait until dialog is closed
                  ref.Wait();
                  // If user clicked "OK"
                  if (dialogResult)
                  	// do stuff
                  It does not help, sorry.
                  1. Cinema freezes and never wakes up again. The dialog does not appear.
                  2. If I don't do the ref.Wait(), Cinema does not freeze, but it also does not wait for the user to close the dialog.
                  3. How do I even return the result of GetUserCredentials() ? The lambda has Bool as return type, but JobRef::GetResult() only returns a maxon::Result<void>. Therefore, I'm returning the value via a reference now.
                  4. Worst of all, the warning You MUST NOT NEVER EVER use a modal dialog in a timer. Please run a job on the main thread (see job.h). still appears!!
                  Is there anything else I can try?
                  Thanks & greetings,
                  Frank
                    why you don't put the "todo stuff" inside your lambda ?
                    here, my function pc12545 is called by a command Data.
                    class pc12545_nodalDialog : public GeModalDialog
                    	Bool CreateLayout(void) override
                    		AddEditText(1000, BFH_LEFT, SizePix(150));
                    		AddButton(1001, BFH_LEFT, 50, 20, "OK"_s);
                    		return true;
                    	Bool InitValues(void) override
                    		SetString(1000, "temporary"_s);
                    		return true;
                    	Bool AskClose(void) override
                    		return false;
                    	Bool Command(Int32 id, const BaseContainer& msg) override
                    		if (id == 1001)
                    			GetString(1000, _password);
                    			if (_password.IsPopulated())
                    				Close(true);
                    			else
                    				MessageDialog("Please Enter A password"_s);
                    		return true;
                    	maxon::Result<maxon::String> GetPass() const
                    			return _password;
                    private:
                    	maxon::String _password = ""_s;
                    static maxon::Result<void> pc12545(BaseDocument* doc)
                    	iferr_scope;
                    		 iferr_scope;
                    			pc12545_nodalDialog credentialsDialog;
                    			credentialsDialog.Open(-1, -1, 200, 200, true);
                    			if (credentialsDialog.GetResult())
                    				const	maxon::String returnedString = credentialsDialog.GetPass() iferr_return;
                    				ApplicationOutput("you new password is @", returnedString);
                    			else
                    				ApplicationOutput("your password haven't been modified");
                                            // ... do something with the password.CoreMessage maybe.
                    			return maxon::OK;
                    	return maxon::OK;
                      fwilleke80
                      This post is deleted!
                        fwilleke80
                        Hmm, I can do the "to do" stuff inside the lambda, of course. But what would that change? The problem is, still, that the code is being called from MessageData::CoreMessage() (inside a CommandData, like in your example, was never a problem), and therefore opening the dialog causes the warning to appear, no matter what code comes after opening it.
                        And the other problem still persists, too: If I don't Wait() after enqueueing the lambda, the dialog doesn't even appear. And if I Wait(), Cinema freezes.
                        Maybe it's simply not possible to do anything with modal dialogs in code that's called from MessageData::CoreMessage, regardless of any threading stunts we could do?
                          using wait or getresult is really strange i agree, but you don't need them.
                          I've added a MessageData and use a timer to trigger the CoreMessage. There i enqueue de job that is executed immediately,
                          The following code is not executed because g_inTimer is false. (the job is executed from main thread).
                          	if (g_inTimer)
                          		DiagnosticOutput("You MUST NOT NEVER EVER use a modal dialog in a timer. Please run a job on the main thread (see job.h).");
                          the MessageData i've added :
                          class TimerMessage_pc12545 : public MessageData
                          	virtual Int32 GetTimer(void);
                          	virtual Bool CoreMessage(Int32 id, const BaseContainer &bc);
                          Int32 TimerMessage_pc12545::GetTimer()
                          	return 10000;
                          Bool TimerMessage_pc12545::CoreMessage(Int32 id, const BaseContainer &bc)
                          	if (id == MSG_TIMER)
                          		iferr_scope_handler
                          			return false;
                          				iferr_scope;
                          				else
                          				return maxon::OK;
                          	return true;
                            fwilleke80
                            Hm, thanks. Well, in my case, I don't even use the MessageData's timer. I am simply reacting to a CoreMessage that is sent from another part of the plugin. And it seems, in that case g_inTimer is true. Is there a way to make it false?
                            My code looks basically similar to yours, I'm just listening to another message, not MSG_TIMER.
                              fwilleke80
                              Addition: I've also tried returning 0 from MessageData::GetTimer(), it changes nothing.
                                fwilleke80
                                And 2nd addition: How do you proceed when you actually need the credentials from the dialog in the code after the lambda? I can't move the whole plugin with all its components to a separate enqueued job, just because of the problem with modal dialogs.
                                I need to show the user the dialog, and get their input. I need things to wait until the user has closed the dialog, then I need the credentials and do stuff with it that is not part of the same lambda.
                                  I don't think the message i react to is important.
                                  You can call whatever function you need inside the lambda. You can pass that function some parameters. This will be executed from the mainThread.
                                  Once it's done, the lambda will send a CoreMessage and your plugins could react to that.
                                  it's just like "hey job, do this for me and tell me once it's done"
                                  Sorry i don't see where's the issu here, or at least i can't reproduce it.
                                  Maybe you could send us some more information by email to keep it secret (as it's related to password etc) or code.
                                    fwilleke80
                                    Sending another CoreMessage... interesting... I will try that, too. Thank you!
                                      did you tried out ?
                                        I'll set this thread as solved without feedback from your side.
                                          fwilleke80
                                          I did try it out, and did not experience any change in behavior. I guess it's rooted somewhere entirely else.
                                            arff, that's really strange, I'll send you a simple example and see if the error still happen on your system.
