    Sample a shader in 3D space
    Cinema 4D SDK
    c++ classic api r21 r20
    3.7k
    • fwilleke80F
      fwilleke80
      this seems to be an old topic, and I have found several search results for this, but none really helped. I'm trying to sample a shader from within ObjectData::GetVirtualObjects().
      It works fine with shaders that are calculated in UV space (e.g. Bitmap Shader, and most of the "Surface" shaders, like Galaxy, Planet, Tiles, Sunburst, etc...), but it does not seem to work with shaders that need a VolumeData (e.g. Surface/Earth, Wood, Marble, etc...). The Noise shader works, regardless of what space I set it to, but as the result does not change when I set it to "World" or "UV", I suspect it's only calculating in UV space.
      I tried making up a mock VolumeData, but it does not work yet. What am I missing? Is this the preferred way of doing it anyway?
      Here is the code:
      	// Prepare InitRenderStruct
      	InitRenderStruct irs;
      	irs.doc = doc;
      	irs.document_colorprofile = DOCUMENT_COLORPROFILE_SRGB;
      	irs.flags = INITRENDERFLAG::TEXTURES;
      	irs.time = doc->GetTime();
      	// Inititalize shader
      	if (shader->InitRender(irs) != INITRENDERRESULT::OK)
      		return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Could not initialize shader!"_s);
      	const Float gridWidthI = Inverse((Float)gridWidth);
      	const Float gridHeightI = Inverse((Float)gridHeight);
      	// Create an array with as many ChannelDatas as we have threads available
      	maxon::BaseArray<ChannelData> channelData;
      	channelData.Resize(GeGetCurrentThreadCount(), maxon::COLLECTION_RESIZE_FLAGS::FIT_TO_SIZE) iferr_return;
      	const Float time = doc->GetTime().Get();
      	// Prepare ChannelDatas, and VolumeDatas for each thread
      	auto shaderInit = [&channelData, &generationParameters, &time] (maxon::ParallelFor::BreakContext& context) -> maxon::Result<void>
      		const Int threadIndex = context.GetLocalThreadIndex();
      		// Create mock ChannelData
      		ChannelData &channelDataRef = channelData[threadIndex];
      		channelDataRef.n = Vector(0.0, 1.0, 0.0);
      		channelDataRef.d = Vector(0.001);
      		channelDataRef.t = time;
      		channelDataRef.texflag = 0;
      		channelDataRef.off = 0.0;
      		channelDataRef.scale = 0.01;
      		// Create mock VolumeData
      		VolumeData *volumeData = VolumeData::Alloc();
      		if (!volumeData)
      			return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Could not allocate VolumeData for shader sampling!"_s);
      		channelDataRef.vd = volumeData;
      		TexData *texData = TexData::Alloc();
      		if (!texData)
      			return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Could not allocate TexData for shader sampling!"_s);
      		texData->m = generationParameters.parentGeneratorMg;
      		texData->im = generationParameters.parentGeneratorMgI;
      		texData->Init();
      		volumeData->tex = texData;
      		volumeData->orign = channelDataRef.n;
      		volumeData->bumpn = channelDataRef.n;
      		volumeData->dispn = channelDataRef.n;
      		volumeData->n = channelDataRef.n;
      		volumeData->time = time;
      		volumeData->delta = channelDataRef.d;
      		return maxon::OK;
      	// Sample the shader
      	auto shaderWorker = [&gridRef, &shader, &channelData, &generationParameters, &thread, gridWidth, gridWidthI, gridHeightI] (Int y, maxon::ParallelFor::BreakContext& context) -> maxon::Result<void>
      		ChannelData &sampleCd = channelData[threadIndex];
      		for (Int x = 0; x < gridWidth; ++x)
      			sampleCd.p = Vector((Float)x * gridWidthI, (Float)y * gridHeightI, 0.0);
      			if (sampleCd.vd)
      				sampleCd.vd->p = Vector(x, y, 0.0);
      			Vector sampledColor = shader->Sample(&sampleCd).GetAverage();
      			do something with sampledColor...
      		return maxon::OK;
      	// Free the allocated structures
      	auto shaderFinalize = [&channelData] (maxon::ParallelFor::BreakContext& context)
      		for (maxon::BaseArray<ChannelData>::Iterator cdIt = channelData.Begin(); cdIt != channelData.End(); ++cdIt)
      			ChannelData &cd = *cdIt;
      			// TexData::Free(cd.vd->tex):
      			VolumeData::Free(cd.vd);
      	maxon::ParallelFor::Dynamic<maxon::ParallelFor::BreakContext>(0, gridHeight, shaderInit, shaderWorker, shaderFinalize) iferr_return;
      	shader->FreeRender();
      Thanks for any help!
      Frank
      P.S.: By the way, using this on an "Effects -> Spectral" shader crashes Cinema.
      www.frankwilleke.de
      • P
        PluginStudent
        No solution to your question, but there is information in the manuals: Sampling a Shader.
        And also some hints regarding VolumeData here: InitRenderStruct::vd.
        • fwilleke80F
          fwilleke80
          Thanks for your reply!
          Yeah, I guess Render::GetInitialVolumeData(), which is mentioned in your second link, would be exactly what I need here... However, in ObjectData::GetVirtualObjects(), there is no such thing, so I have to make up my own data...
          www.frankwilleke.de
          • ferdinandF
            I am not quite sure if I understand your question correctly and also am unclear on what you would consider "not working" in the context of sampling a volumetric shader.
            However, what stood out to me in your code, is that you only do sample in a slice of the volume, basically treat the shader like a 2D-Shader, which might have side effects as your sampled shaders might simply only return the zero vector in that slice (here comes up the question of what is not working).
            Poking around in the Script Manager, I did not had any problems sampling the Xwood shader, at least the output looks meaningful.
            zipit
                shader = c4d.BaseList2D(c4d.Xwood)
                irs = c4d.modules.render.InitRenderStruct(doc)
                shader.InitRender(irs)
                for i in range(10):
                    n = i / 9.
                    cd = c4d.modules.render.ChannelData()
                    cd.p = c4d.Vector(0, 0, n)
                    print shader.Sample(cd)
                shader.FreeRender()
            Vector(0.187, 0.077, 0.03)
            Vector(0.171, 0.07, 0.028)
            Vector(0.091, 0.038, 0.015)
            Vector(0.163, 0.067, 0.027)
            Vector(0.255, 0.105, 0.041)
            Vector(0.275, 0.113, 0.044)
            Vector(0.314, 0.13, 0.05)
            Vector(0.249, 0.103, 0.04)
            Vector(0.095, 0.039, 0.016)
            Vector(0.318, 0.131, 0.05)
            fwilleke80F 1 Reply Last reply Reply Quote 1
            • fwilleke80F
              fwilleke80 @ferdinand
              Hi & thanks for your reply.
              @zipit said in Sample a shader in 3D space:
              I get only one value, regardless of the sample coordinates.
              z is 0.0 because I'm sampling at positions on a plane. ChannelData::p is, according to the SDK docs, only in UVW space, anyway (that's why I multiply the X and Y grid coordinate with the inverse X and Y size, so my actual sample values are in the range of 0.0 ... 1.0). And sampling those positions works. For 3D shaders, as far as I always understood it, the sampleCd.vd->p is the one that counts, as that is actually a position in 3D space.
              for i in range(10):
                  n = i / 9.
              shader.FreeRender()
              if name=='main':
              Hmm, that looks meaningful in deed. I still wonder why I get nothing out of the Wood shader and others.
              www.frankwilleke.de
              • ferdinandF
                Hm,
                I might be wrong about this, but I always thought that VolumeData.p is a sample position in object space and ChannelData.p is the sample position in uvw space. The latter would lie in the half interval uv(w) coordinates are normally defined in, while the former would lie in an arbitrary interval, depending on the bounding box of the sampled geometry (i.e. 0 <= c <= 1 is not guaranteed to be met for the components of VolumeData.p). So a geometry-agnostic shader should not care about VolumeData.p.
                Also note that I did deliberately only sample on the z-axis in my example and still get a varying output. If your premise would be true, I should get the same vector for all ten calls.
                zipit
                • M
                  Hi sorry for not answering you earlier, I just wanted to inform you I reached the development team about it especially since you use multi-threading, and sampling a shader with Multiple thread is different (for example in my case your code does not work even on a 2D gradient).
                  I have a property but which doesn't support all shaders (especially Layer shader).
                  So I will keep you in touch when I have more news.
                  • M
                    Sorry for the delay, this took me a bit more time than expected.
                    I would say @zipit is completely right here, but since you are using multi threads you have to attach a FakeVolumeData for each thread since some shader really needs and output their result according to this VolumeData.
                    Here a complete example.
                    // class that hold per thread sampling data
                    class ShaderSampler
                    	BaseContainer _rdc;
                    	BaseObject* _camera = nullptr;
                    	ChannelData _channelData;
                    	::Ray _ray;
                    	VolumeData* _volumeData = nullptr;
                    	ShaderSampler(){};
                    	~ShaderSampler()
                    		if (_camera)
                    			BaseObject::Free(_camera);
                    		if (_volumeData)
                    			VolumeData::Free(_volumeData);
                    	void SetSamplingContext(const Vector& uv, const Vector& delta)
                    		VolumeData& volumeData = *_volumeData;
                    		const Vector d = Vector(delta.x, delta.y, delta.z);
                    		_channelData.d = d;
                    		volumeData.delta = d;
                    		const Vector p = Vector(uv.x, uv.y, uv.z);
                    		_channelData.p = p;
                    		volumeData.uvw = p;
                    		volumeData.p = p;
                    		volumeData.pp[0] = p;
                    		volumeData.pp[1] = p;
                    		volumeData.pp[2] = p;
                    		_ray.p = p;
                    		_ray.pp[0] = p;
                    		_ray.pp[1] = p;
                    		_ray.pp[2] = p;
                    static maxon::Result<void> SampleMaterialBis(BaseDocument* doc)
                    	iferr_scope;
                    	//Get the BaseShader linked in the color shader of the first  material
                    	BaseShader* shader;
                    	MAXON_SCOPE
                    		// Get the first material and check its a Cinema 4D default material
                    		BaseMaterial* firstMat = doc->GetFirstMaterial();
                    		CheckState(firstMat != nullptr, "Failed to get the first material");
                    		CheckState(firstMat->IsInstanceOf(Mmaterial), "material is not a default c4d material");
                    		// look for the material BaseContainer and the BaseList2D associated to the color param
                    		BaseContainer* matBC = firstMat->GetDataInstance();
                    		CheckState(matBC != nullptr, "Failed to get the BaseContainer");
                    		BaseList2D* matColorBL = matBC->GetLink(MATERIAL_COLOR_SHADER, doc);
                    		CheckState(matColorBL != nullptr, "Failed to get the Color Shader");
                    		// cast to BaseShader
                    		shader = (BaseShader*)matColorBL;
                    	// Allocate and init the InitRenderStruct
                    	// This is important to init with valid FakeVolumeData since some shaders needs them.
                    	VolumeData* volumeData = VolumeData::Alloc();
                    	BaseObject* camera = BaseObject::Alloc(Ocamera);
                    	CheckState(volumeData != nullptr, "Failed to initialize volume data");
                    	CheckState(camera != nullptr, "Failed to initialize camera");
                    	MAXON_SCOPE
                    		BaseContainer renderData;
                    		const Int threadIndex = maxon::JobRef::GetCurrentWorkerThreadIndex();
                    		renderData.SetInt32(RDATA_VDFAKE_CURRENTTHREAD, threadIndex);
                    		renderData.SetInt32(RDATA_VDFAKE_THREADCOUNT, (Int32)GeGetCurrentThreadCount());
                    		const Bool attached = C4DOS.Sh->AttachVolumeDataFake(volumeData, camera, renderData, nullptr);
                    		CheckState(attached == true, "Failed to attach volume data");
                    		irs.vd = volumeData;
                    		irs.docpath = doc->GetDocumentPath();
                    		irs.thread = GeGetCurrentThread();
                    		COLORSPACETRANSFORMATION transform = COLORSPACETRANSFORMATION::NONE;
                    		// check if linear workflow is enabled
                    		if (irs.linear_workflow)
                    			transform = COLORSPACETRANSFORMATION::LINEAR_TO_SRGB;
                    		const INITRENDERRESULT initResult = shader->InitRender(irs);
                    		CheckState(initResult == INITRENDERRESULT::OK, "Shader init failed");
                    	// Allocate a list of ShaderSampler to store VolumeData and ChannelData per thread
                    	maxon::BaseArray<ShaderSampler*> samplers;
                    	MAXON_SCOPE
                    		for (Int32 i = 0; i < GeGetCurrentThreadCount(); i++)
                    			ShaderSampler* sampler = NewObjClear(ShaderSampler);
                    			sampler->_rdc.SetInt32(RDATA_VDFAKE_CURRENTTHREAD, threadIndex);
                    			sampler->_rdc.SetInt32(RDATA_VDFAKE_THREADCOUNT, GeGetCurrentThreadCount());
                    			sampler->_camera = BaseObject::Alloc(Ocamera);
                    			CheckState(sampler->_camera != nullptr, "Failed to initialize camera");
                    			sampler->_volumeData = VolumeData::Alloc();
                    			CheckState(sampler->_volumeData != nullptr, "Failed to initialize volume data");
                    			const Bool attached = C4DOS.Sh->AttachVolumeDataFake(sampler->_volumeData, sampler->_camera, sampler->_rdc, nullptr);
                    			samplers.Append(sampler) iferr_return;
                    	// Worker lambda to build the grid
                    	Int gridSize = 64;
                    	// Create a BaseArray of matrices and colors (to store the results of our sampling, and visualize them in an instanceObject)
                    	maxon::BaseArray<Matrix>	matrices;
                    	maxon::BaseArray<maxon::Color64> colors;
                    	// * 3 because we store the data for x,y,z axis in one big array
                    	matrices.Resize(gridSize * gridSize * gridSize) iferr_return;
                    	colors.Resize(gridSize * gridSize * gridSize) iferr_return;
                    	auto worker = [&samplers, &shader, &matrices, &colors, &gridSize](UInt y)
                    		// Retrieve the current sampler data for the current thread
                    		ShaderSampler* sampler = samplers[threadIndex];
                    		if (sampler == nullptr)
                    			return;
                    		for (Int32 z = 0; z < gridSize; ++z)
                    			for (Int32 x = 0; x < gridSize; ++x)
                    				// Map 3D array to a 1D array
                    				Int32 arrayId = (z * gridSize * gridSize) + (y * gridSize) + x;
                    				matrices[arrayId] = MatrixMove(Vector(x, y, z));
                    				// Define where we want to sample
                    				Vector uvw = Vector(
                    					double(x) / double(gridSize),
                    					double(y) / double(gridSize),
                    					double(z) / double(gridSize)
                    				Vector delta = Vector(0.01, 0.01, 0.01);
                    				sampler->SetSamplingContext(uvw, delta);
                    				// sample
                    				const Vector sampledValue = shader->Sample(&sampler->_channelData);
                    				// Store the color result of the sampling operation
                    				colors[arrayId] = maxon::Color64(sampledValue.x, sampledValue.y, sampledValue.z);
                    	// Execute worker
                    	maxon::ParallelFor::Dynamic(0, gridSize, worker, GeGetCurrentThreadCount());
                    	// Free samplers
                    	MAXON_SCOPE
                    			ShaderSampler* sampler = samplers[i];
                    			if (sampler != nullptr)
                    				DeleteObj(sampler);
                    				samplers[i] = nullptr;
                    		// call the FreeRender to release allocated memory used for sampling
                    	VolumeData::Free(volumeData);
                    	BaseObject::Free(camera);
                    	// Create a Multi-Instance object with the matrix and the color information to visualize them
                    	InstanceObject* const instance = InstanceObject::Alloc();
                    	CheckState(instance != nullptr, "Failed to allocate an Instance Object");
                    	MAXON_SCOPE
                    		doc->InsertObject(instance, nullptr, nullptr);
                    		// Set to multi instance + to Points mode
                    		if (!instance->SetParameter(INSTANCEOBJECT_RENDERINSTANCE_MODE, INSTANCEOBJECT_RENDERINSTANCE_MODE_MULTIINSTANCE, DESCFLAGS_SET::NONE))
                    			return maxon::UnexpectedError(MAXON_SOURCE_LOCATION);
                    		if (!instance->SetParameter(INSTANCEOBJECT_DRAW_MODE, INSTANCEOBJECT_DRAW_MODE_POINTS, DESCFLAGS_SET::NONE))
                    		// Set data in the instance object
                    		instance->SetInstanceMatrices(matrices) iferr_return;
                    		instance->SetInstanceColors(colors) iferr_return;
                    	EventAdd(EVENT::NONE);
                    	return maxon::OK;
                    • fwilleke80F
                      fwilleke80
                      Thank you very much! I'll try that out ASAP!
                      Frank
                      www.frankwilleke.de
                      • fwilleke80F
                        fwilleke80
                        Almost perfect, thanks. It kinda only works half ok, I noticed.
                        The thing is, all shaders are always sampled in UV space. I tried adding the 3D position data for sampling, too, by setting volumeData.p to the global position of the point to sample, in SetSamplingContext(). but it is being ignored. For example, if the Shader is a Noise shader, I can set it to whatever space I want, the result is always the same.
                        With my old code, that worked. It just couldn't sample certain shaders (Layer Shader, Earth Shader, etc). Now, those shaders work, but sampling seems restricted to UV space. How can I sample those shaders in Texture Space, Object Space, and World Space (Camera, Screen, and the others can be neglected)?
                        Thanks in advance,
                        Frank
                        www.frankwilleke.de
                        • fwilleke80F
                          fwilleke80
                          Any news on this? πŸ˜‰
                          Frank
                          www.frankwilleke.de
                          • M
                            Hi he completely get out of my mind sorry, I will work on your topic in the upcoming days.
                            However I'm not sure if this is possible since you will probably need to instantiate some VolumeData which is not possible, but I will have a look.
                            • fwilleke80F
                              fwilleke80
                              No worries. I forgot about it, too, until I noticed the issue again recently.
                              I have sent an email to sdk_support(at)maxon(dot)net with some example code and more detailled info.
                              Let's continue the discussion there πŸ™‚
                              Frank
                              www.frankwilleke.de
                              • M
                                Hi again sorry for the long delay, pretty busy.
                                I looked at the noise code and it assume a cd->vd->tex to be defined unfortually allocating a dummy TexData is not working properly, I will need to reach development team to see if this is possible at all.
                                • Paul EverettP
                                  Paul Everett
                                  1. you can sample a channel. it works perfectly for things like the layer shader.
                                  2. if you really have to sample a shader specifically, what I do is make a clone of the shader per each context.
                                  i.e. you have 16 cores, you make 16 clones, and insert them on the material and initing them, (being sure to clean up after)
                                  Layer shader will then work as expected, off the bat, as long as you use the thread index to reference from your list of shader clones.
                                  clones.shader_list[context.GetLocalThreadIndex()]
                                  you also have to make sure you project your coordinate according to the texture tag. it wont do that for you.
                                  p is always assumed to be a UV coordinate projected, as per the tex tag. you send p as a world coordinate with vd and if the shader needs that, that is where it would look. think of it from the perspective of a shader. where will it get a world position from? if you write a shader, and you need a world position for a hit, you look in vd for that. if vd is null, or the info has not been filled, how would it know where p is?
                                  I found in most cases sampling a channel from a material rather than a specific shader, works best, and is less problematic.
                                  best
                                  Paul
                                  • fwilleke80F
                                    fwilleke80
                                    Thanks, Paul! I'll try that out πŸ™‚
                                    Frank
                                    www.frankwilleke.de
                                    • fwilleke80F fwilleke80 referenced this topic on
