    Real Time or Live "Edge to Spline" Object?
    r21python
    4 Posts 3 Posters 527 Views 1 Watching
    • B Offline
      bentraje
      Is there a way to create a real-time or live "edge to spline" object?
      Scenario:
      1. You have Object A
      2. Execute "Edge to Spline" command. It produces a Spline object
      3. Modify Object A (through skinning, typical deformers, PSR) etc
      4. The spline object stays the same as #1. I don't want that. I want it to stay with the latest modification of Object A #3.
      You can see an equivalent of what I am after here in Maya:
      https://www.dropbox.com/s/sjkszesp2sm27xf/c4d247_live_edge_to_spline_command.mp4?dl=0
      Regards,
      Ben
      • P Offline
        PluginStudent
        Spline generator objects are ObjectData plugins implementing GetContour().
        I guess it could be possible to make that function read the properties of a child object. But there is no spline generator in Cinema that does that, so I don't know if that will work.
        Another idea would be a Python Tag that continuously accesses your mesh, performs MCOMMAND_EDGE_TO_SPLINE and writes the result into an existing Spline object.
          its free and open source 🙂
          • B Offline
            bentraje
            @PluginStudent and @m_adam
            The plugin from @noseman works.
            It works for now in my use case, but correct me if I'm wrong it cannot have a priority parameter because it is a generator (?).
            Regards,
            Ben
