    Texture renaming
    16 Posts 4 Posters 3.8k Views 3 Watching
      moko
      Thanks alot it works! but the material iteration posts an error
      mats = doc.GetActiveMaterials()
      doc.StartUndo()
      # Iterate over selected material
      for mat in mats:
          recurse_hierarchy(mat.GetFirstShader())
      doc.Endndo()
      it didnt find doc.Endndo() is there a way to iterate over the materials?
      my second question:
      now the script replaces A with B. Is it possible to "add" like a prefix?
      I have alot of textures and would like to add a "Tex_" as a prefix, so its easier to sort/find them.
      Like "TrainStation.jpg" to "Tex_TrainStation.jpg"
      I found this but it need the name of a object or material:
      https://developers.maxon.net/forum/topic/6085
      Thanks for any suggestions and maybe someone need this aswell
      cheers moko
      • P Offline
        PluginStudent
        doc.Endndo() is nonsense.
        Do you mean EndUndo()?
        • r_giganteR Offline
          r_gigante
          Thanks @PluginStudent for stepping in.
          With regard to the rest of the question, I recommend having a look at how Python treats strings or, on a broader scope, at Python for novices.
          Best, R
            moko
            Thanks it works like expected, now i would like to add a smal GUI but i get stuck, how do i bring the name from the GUI in as prefix.
            from c4d import gui
            import os
            #GUI
            GROUP = 1000
            TEXT = 1001
            NAME = 1010
            class userDialog(gui.GeDialog):
                def CreateLayout(self):
                    self.SetTitle("Add Prefix")
                    self.GroupBegin(GROUP, c4d.BFH_SCALEFIT, 3,5, title = "AAdds a prefix to the texturename")
                    self.GroupBorder(c4d.BORDER_GROUP_IN)
                    self.GroupBorderSpace(20, 5, 20 , 5)
                    self.AddStaticText(TEXT, c4d.BFH_SCALEFIT, name="Prefix")
                    self.AddEditText(NAME, c4d.BFH_RIGHT, 200, 0, 0)
            # Adds a prefix to the texturename
            def changeTexture(shader) :
                prefix = "Tex_"
                # shader ID
                texturePath = shader[c4d.BITMAPSHADER_FILENAME]
                # split aboslute path
                oldTexturename = os.path.split(texturePath)
                # add prefix
                newTexturename = prefix + oldTexturename[1]
                doc = shader.GetDocument()
                doc.AddUndo(c4d.UNDOTYPE_CHANGE, shader)
                # Assign the new value
                shader[c4d.BITMAPSHADER_FILENAME] = os.path.join(oldTexturename[0], newTexturename)
                shader.Message(c4d.MSG_UPDATE)
            # Iterate a hierarchy
            def recurse_hierarchy(shader) :
                while shader:
                    # Check if it's a c4d shader
                    if c4d.BaseShader() :
                    recurse_hierarchy(shader.GetDown())
                    shader = shader.GetNext()
            # Main function
                doc.StartUndo()
                for mat in mats:
                doc.EndUndo()
                dialog = userDialog()
                dialog.Open(c4d.DLG_TYPE_MODAL, defaultw=200, defaulth=50)
            # Execute main()
            thx for help
            mok
            • P Offline
              PluginStudent
              Hey, you have two
              in your code 🤔
                this also probably is not what you want:
                It will always evaluate as True since an object evaluates as True. You probably meant instead:
                # Test if the current node is a bitmap shader.
                if shader.CheckType(c4d.Xbitmap) :
                zipit
                  moko
                  Thank you for both inputs. Im not used to programming and copy and paste the lines. Thanks for the help!
                    r_gigante
                    Hi @moko, nice seeing your progresses.
                    With regard to adding a small GUI to return a specific string I warmly recommend having a look at c4d.gui.InputDialog.
                    Finally a consideration on copy and paste which looks always pretty attractive to reduce time to market: be aware that it's indeed the opposite where in the end you'll obtain a code you can manage no more. Spending time in investigating the basics and getting yourself comfortable with the code is always a rewarding time.
                    Best, R
                      moko
                      Thank you very much, right now i am quite happy how it works. only thing is the dialog box opens for each shader because its in the "changeshader" function wich repeats.
                      I d' like to have one gui-call at the start in the main function, but if i do that theni cant transport the "prefix" argument to the changeTexture(shader) function.
                      about the time investement i agree, but for this script was more an out of desperation approach in how cinema4d lacks in organizing textures, then a new grind in passion. the script helps me with a hack, to organize them on OS side, for team projects like for instance unity.
                      Best
                      Moko
                      from c4d import gui
                      import os
                      #GUI
                      GROUP = 1000
                      TEXT = 1001
                      PREFIX = 1002
                      BTN_OK = 1010
                      BTN_CANCEL = 1020
                              self.GroupBegin(GROUP, c4d.BFH_SCALEFIT, 3,5, title = "Adds a prefix to the texturename")
                              self.AddEditText(PREFIX, c4d.BFH_SCALEFIT)
                              self.AddButton(BTN_OK, c4d.BFH_SCALE, name="Ok")
                              self.AddButton(BTN_CANCEL, c4d.BFH_SCALE, name="Cancel")
                              self.GroupEnd()
                          def InitValues(self):
                              #initiate the gadgets with values
                              self.SetString(PREFIX, "Tex_")
                          def Command(self, id, msg):
                              #handle user input
                              if id==BTN_CANCEL:
                                self.Close()
                              elif id==BTN_OK:
                                self.TexturPrefix = self.GetString(PREFIX)
                                self.Close()
                          prefix = dialog.TexturPrefix
                          print (prefix)
                          # shader ID
                          # add prefix
                          while shader:
                      # Main function
                          doc.StartUndo()
                          for mat in mats:
                          doc.EndUndo()
                      # Execute main()
                        moko
                        Now it works as intended. You can select the materials for which you want to change the prefix of the texturename. The actual name of the texture is not changed. You need to do this with a renaming-tool at the OS level.
                        thanks to everyone
                        from c4d import gui
                        import os
                        #GUI
                        GROUP = 1000
                        TEXT = 1001
                        PREFIX = 1002
                        BTN_OK = 1010
                        BTN_CANCEL = 1020
                        prefix = "placeholder"
                                self.GroupEnd()
                                #handle user input
                                if id==BTN_CANCEL:
                                  self.Close()
                                elif id==BTN_OK:
                                  self.Close()
                            print (prefix)
                            # shader ID
                            # add prefix
                            while shader:
                        # Main function
                            global prefix
                            doc.StartUndo()
                            for mat in mats:
                            doc.EndUndo()
                        # Execute main()
                        ferdinandF 1 Reply Last reply Reply Quote 1
                          ferdinand @moko
                          @moko said in Texture renaming:
                          You can do this with os.rename() or with open if you want to save a copy. You probably also do not need your own GeDialog since yours does exactly what c4d.gui.RenameDialog does.
                          zipit
                            moko @ferdinand
                            @zipit Thank you! That was exactly i was looking for 🙂
                            here the new Version:
                            I throw out the undo function because i dont know if it can adress the os part. Is this possible to have an undo on os.rename?
                            from c4d import gui
                            import os, sys
                            prefix="placeholder"
                            def changeTexture(shader):
                                # shader ID
                                # add prefix to
                                print (newTexturename)
                                newTexturePath = os.path.join(oldTexturename[0], newTexturename)
                                print (newTexturePath)
                                # rename texture
                                try :
                                    os.rename(texturePath, newTexturePath)
                                    print("Source path renamed to destination path successfully.")
                                except OSError as error:
                                    print(error)
                                shader[c4d.BITMAPSHADER_FILENAME] = newTexturePath
                                while shader:
                            # Main function
                                global prefix
                                prefix = c4d.gui.RenameDialog("Prefix_")
                                print (prefix)
                                for mat in mats:
                            # Execute main()
                            moko
                              ferdinand @moko
                              No, there is no Undo for os.rename. You could hook into the Undo APIs provided by Windows and MacOS, but that would be probably overly complicated and also very unsafe.
                              The easiest way to implement this, would be to create a dictionary of old_file_path and new_file_path key-value pairs and write to it every time you rename something. With that you could unwind renaming operations.
                              There are however multiple problems with this.
                              1. If I am not mistaken, your script has no safe-guard against the user renaming a texture multiple times and therefor rendering previous references invalid. This is a problem on its own, but it would also defeat the mentioned naive implementation of an Undo stack with a dictionary.
                              2. This would also require a persistently running piece of code, where you could store that dictionary. The script manager script and all its states just vanish once it has been executed. You would have at least provide a asynchronous dialog that can stay open until the user decides that he/she is done with the renaming (and undoing). Or a full blown plugin if you do not want to have a dialog dangling around. You could technically store your Undo data somewhere else, like for example in the scene or in the running Python instance, but this would fall into the domain of "hacks".
                              3. Also implementing a proper undo stack for renaming operations is not as trivial as it might seem, because you would also have to keep track of all modifications made to the tracked files, including these that are not made by you, and properly react to them, if you do not want the Undo feature causing potentially critical conflicts.
                              So all in all not really worth the hassle.
                              zipit
                                moko @ferdinand
                                @zipit
                                hm yes this sounds too complicated overall, particularly point 3 there could so much happen on the os side.
                                A gui with more options like renaming the hole texturename or a replace option of certain words could be the way forward. Instead of undo it would be easy then to rename the texture with he old name etc.
                                for now im happy how this works and let this solved.
                                Much Thanks!
                                moko
