    Set Texture by script
    Scheduled Pinned Locked Moved PYTHON Development
    14 Posts 0 Posters 2.5k Views
    • H Offline
      Helper
      On 26/10/2011 at 01:58, xxxxxxxx wrote:
      Is there any chance to change the texture file by script? I import models from a 3D-Scanner. On import there are texture groups but noe texture file is assigned.
      The groups are named "texture_group_0", "texture_group_1" ...
      The texture files are named "texture_0", "texture_1"...
      If I set the texture_0 to texture_group_0 and so on it's ok. But there are many texture_groups. Is there any way to assign them automatically.
      • H Offline
        Helper
        On 26/10/2011 at 07:09, xxxxxxxx wrote:
        Do you mean with "texture groups" a null-object that groups objects with the same texture ?
        There are many possible ways to solve this.
        Let's say all your objects are at top level of the document and that the path to the textures is C:/Textures/3DScanner/.
        #note: you do not have to adapt my coding-style
        #      like the indentation of assignment operators, etc.
        import  os
        import  c4d
        myObjects       = doc.GetObjects()
        pathToTextures  = r"C:\Textures\3DScanner"
        fileExtension   = ".jpg"
        def main() :
          # go through the list and to the stuff with
          # every object in it
          for obj in myObjects:
              # get the name of the object
              name        = obj.GetName()
              # arrange the new name by replacing
              # every `_group` with just nothing ``.
              textureName = name.replace( "_group", "" )
              # concetenate the path to textures with the name
              # of the texture
              # we use `os.path` because it adapts the operating
              # systems way to deal with pathnames
              fullPath    = os.path.join( pathToTextures, textureName )
              # we need the original texturename, so we add the
              # file extension now
              fullPath    = fullPath + fileExtension
              # check if the texture exists
              if not os.path.exists( fullPath ) :
                  # tell that the object could not be associated
                  # with a texture
                  print "Texture could not be found:", fullPath
                  # create a standart material for the texture
                  mat     = c4d.BaseMaterial(c4d.Mmaterial)
                  mat.SetName( textureName )
                  # create a shader for the material
                  sha     = c4d.BaseList2D(c4d.Xbitmap)
                  sha[c4d.BITMAPSHADER_FILENAME]  = fullPath
                  mat.InsertShader( sha )
                  mat[c4d.MATERIAL_COLOR_SHADER]  = sha
                  # update the material
                  mat.Message( c4d.MSG_UPDATE )
                  mat.Update( True, True )
                  # insert the material into the document
                  doc.InsertMaterial( mat )
                  # create a texturetag and insert the material
                  tag     = c4d.BaseTag( c4d.Ttexture )
                  tag[c4d.TEXTURETAG_MATERIAL]    = mat
                  # assign the tag to the object
                  obj.InsertTag(tag)
          # update the Cinema 4D UI
          # tell that the processing was finished
          print "Finished processing."
        Cheers, Niklas
        • H Offline
          Helper
          On 26/10/2011 at 14:20, xxxxxxxx wrote:
          If I read this correctly then you create a new material first.
          Is there also a way to change the texture in an already exsisting material?
          Greets Ronnie
          • H Offline
            Helper
            Greets Ronnie
            Thanks, you understood my problem. The texture groups are existing. I have to assign the files to the existing texture groups.
            • H Offline
              Helper
              On 27/10/2011 at 06:32, xxxxxxxx wrote:
              Use
              doc.SearchMaterial(name)
              to find a material by name.
              • H Offline
                Helper
                On 28/10/2011 at 01:41, xxxxxxxx wrote:
                Thanks to all. I solved the problem. Here is my final script:
                from c4d import gui
                from c4d import storage
                import  os
                myMaterials       = doc.GetMaterials()
                def main() :
                  pathToTextures = c4d.storage.LoadDialog(0,"Texturpfad wählen",2)
                  for mat in myMaterials:
                      name        = mat.GetName()
                      textureName = name
                      textureName = name.replace( "material_", "texture_" )
                      # of the texture
                          # with a texture
                  gui.MessageDialog("Finished processing.")
                if __name__=='__main__':
                But there are two new questions.
                1. If I look into the documentation the function GetMaterials is in the namespace c4d.documents.BaseDocument. But if I use this namespace the command could not be found. Why and from where I can know the namespace doc? I got it from the script above.
                2. In the documentation for the command LoadDialog is written about constants like FILESELECT_DIRECTORY. But it isn't known by the interpreter. Where are they defined and what I have to import that it works?
                • H Offline
                  Helper
                  On 28/10/2011 at 02:43, xxxxxxxx wrote:
                  1. c4d.documents.BaseDocument isn't a namespace, it's a class representing a C4D document. To get the current document as doc:
                  from c4d import documents
                  doc = documents.GetActiveDocument()
                  2. FILESELECT_DIRECTORY and all the constants are defined in the c4d namespace : for example c4d.FILESELECT_DIRECTORY.
                  • H Offline
                    Helper
                    On 28/10/2011 at 04:46, xxxxxxxx wrote:
                    As you see in my sourcecode I have never declared doc but it works. Is it declared implicit? I've found nothing in the documentation about it.
                    • H Offline
                      Helper
                      Yes, everywhere in the code, 'doc' is the current document and 'op' is the current activate object. I'll add this to the docs.
                      • H Offline
                        Helper
                        On 28/10/2011 at 05:18, xxxxxxxx wrote:
                        You don't seem to understand that I have written the code above just for you, and not just because I'm so bored. I don't think many other people would have done this for you.
                        At least some sort of thank you in your second post would have been appropriate rather than to complain it is not exactly the way you need it.
                        • H Offline
                          Helper
                          I think you posted the code in the wrong topic...
                          The topic about finding a material by name is this one : https://developers.maxon.net/forum/topic/6087/6267_texture-change-python
                          • H Offline
                            Helper
                            As you can see I used the most of your script in my solution. The only difference is that I had already materials and would like to edit them and the dynamic selection of the texture path.
                            Many thanks for your script👏 Without it I wasn't able to solve the problem.
                            I'm sorry, if it seems that I'm not thankful to you.😊
                            • H Offline
                              Helper
                              Sorry, I didn't understand your previous post but the code you posted later was quite confusing Confused:
                              https://developers.maxon.net/forum/topic/6085/6265_set-texture-by-script
                              • H Offline
                                Helper
                                On 01/11/2011 at 23:41, xxxxxxxx wrote:
                                I'm sorry. My reply applies to the post from nux95.
