    How do I return the connected port from the input port?
    sdkpythonr19r20r21
    9 Posts 5 Posters 2.3k Views 4 Watching
    • gheyretG Offline
      gheyret
      Hi ~
      I want to get which port the node's input port connects to. and I try to use gvport.getdestination () in the Python SDK, but I find that the port has to be the output port to return properly, and if the port is the input port, it returns an empty list.
      Does anyone know how to return the connected port from the input port?
      Cheers~
      www.boghma.com
        In C++ you would use GetIncomingSource but it's not implemented in python.
        So the only way is to check for each node in the same Xgroup if any of it's outgoing port is linked to your node.
        really not the best thing but that's the only workaround.
        Manuel.
        • gheyretG Offline
          gheyret
          All right. Thanks for your reply.
          Cheers~
          www.boghma.com
            without feedback, i'll consider this thread as solved.
            • B Offline
              bentraje
              Is this still a limitation or is there now a better workfaround for this?
              DunhouD 1 Reply Last reply Reply Quote 0
              • B bentraje referenced this topic on
                Hi I just implemented GetIncomingSource and GetIncomingDestination, they will be available in the next update of Cinema 4D.
                • DunhouD Offline
                  Dunhou @bentraje
                  Hi @bentraje,
                  For a temp solution. it maybe stupid but can worked right now, it works with renderEngine libs, but you can easily custom with maxon and c4d api.
                  It also has some similar cousin:
                  • GetConnectedPortsAfter
                  • GetConnectedPortsBefore
                  • GetPreNodePorts
                  • GetNextNodePorts
                  • GetAllConnectedPorts
                  Hope it can helps.
                  Cheers~
                  DunHou.
                  Codes:
                  from renderEngine import node_helper as nodeHelper
                      material = doc.GetActiveMaterial()
                      helper = nodeHelper.NodeGraghHelper(material)
                      act_node: maxon.GraphNode = helper.GetActiveNodes()
                      if act_node:
                          for port in helper.GetConnectedPortsAfter(act_node):
                              print(port)
                  The Material and select the Standard BRDF
                  Return
                  standardmaterial@TUGeQqzyIx5ijJlA7el82W>com.redshift3d.redshift4c4d.nodes.core.standardmaterial.outcolor
                  output@P0Ey0yEAFJror7c4Oew95V<com.redshift3d.redshift4c4d.node.output.surface
                  https://boghma.com
                  https://github.com/DunHouGo
                    Hi @Dunhou in thsi case we are speaking about xpresso and not the new node, which already have this features with maxon.GraphModelHelper.GetDirectPredecessors.
                    But thanks a lot, this indeed looks useful !
                    • B Offline
                      bentraje
                      @Dunhou
                      Thanks for the reference but yea I'm unfortunately using the xpresso here instead of the new node editor.
                      Which in all regards, an unfortunate scenario is xpresso is not integrated to the new node editor.
                      @m_adam
                      Gotcha. Thanks. Looking forward to the update.
