c4dpy not working on Windows 10
Hello guys!
I have Cinema 4D R20.059 installed and c4dpy.exe updated to latest R20 release.
A some time ago everything was fine but now c4dpy.exe seems to not working with any command.With R21 it works:
c4dpy is version-specific. Since in Release R20 it was not part of the bundle you should download it from [URL-REMOVED] with the matching R20 version you have.
Sure! I know it perfectly. But in case wrong version Cinema4D.exe c4dpy outputs error messages, but i have nothing.
What's your specific version of Windows 10?
Can you try to clean the Cinema 4D preference folder.
Did you already licensed the 20 cinema 4D application? If not could you try to launch Cinema 4D first license it then relaunch c4dpy.If it does nothing can you launch c4dpy with the g_console=true parameter and copy the output data.
Maxime. -
Hm, after removing folder c:\Program Files\MAXON\Cinema 4D R20\plugins\Redshift
c4dpy works! -
Thanks for the info can you try to launch c4dpy with redshift and with
c4dpy g_disableConsoleOutput=false
and paste the content.Does the CommandLine works with the redshift plugin?
Thanks in advance.
Maxime. -
@m_adam
Sure! Take it in attachement.
c4dpy_output_log.txt -
Did you mean c:\Program Files\MAXON\Cinema 4D R20\Commandline.exe?
Hi, could you run g_disableConsoleOutput=false With Redshift installed so this way c4dpy does not launch correctly.
@mikeudin said in c4dpy not working on Windows 10:
Yes
@m_adam Ok, done. With Redshift installed:
c4dpy_output_log.txtCommandLine.exe log:
commandline_output_log.txt -
Which version of Redshift are you using?
@m_adam v2.6.41
@m_adam After installing v2.6.48 c4dpy works fine.
C:\Users\mikeu>"c:\Program Files\MAXON\Cinema 4D R20\c4dpy.exe" g_disableConsoleOutput=false Application start : 12/04/19 at 11:53:39 Executable : 64 Bit Version / Build : 20.059 / RB272827 Debugger : not available Memory model : release Startup path : file:///c:/Program Files/MAXON/Cinema 4D R20 Application path : file:///c:/Program Files/MAXON/Cinema 4D R20/c4dpy.exe Application executable : file:///c:/Program Files/MAXON/Cinema 4D R20/c4dpy.exe Resource path : file:///c:/Program Files/MAXON/Cinema 4D R20/resource Module path(s) : file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs; file:///c:/Program Files/MAXON/Cinema 4D R20/plugins; file:///C:/Users/mikeu/AppData/Roaming/MAXON/Cinema 4D R20_4FA5020E/plugins; file:///D:/Dropbox/Developer/Plugins/SendPythonCode; file:///D:/Dropbox/Developer/TestingProjects/File Sequence Exporter; file:///D:/Dropbox/Developer/Plugins/Target4D/Dev/1.5 Temporary path : file:///C:/Users/mikeu/AppData/Local/Temp Prefs path : file:///C:/Users/mikeu/AppData/Roaming/MAXON/Cinema 4D R20_4FA5020E Global Prefs path : file:///C:/Users/mikeu/AppData/Roaming/MAXON OS version : Windows 10, 64 Bit, Professional Edition (build 18362) OS languages : {ru-RU,en-US} App languages : {en-US,ru-RU} Startup language : en-US Processor : 4(8)x Intel Core i7-4770 CPU Computer name : DESKTOP-60OMRSJ Thread Count : 8 Cpu Speed (MHz) : 3400.000 Application Type : Modular Command line arguments : "g_disableConsoleOutput=false" Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/asset.module.xdl64 with module(s) net.maxon.asset Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/c4dplugin.xdl64 with module(s) net.maxon.c4dplugin net.maxon.c4d.c4dplugin Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/command.module.xdl64 with module(s) net.maxon.command Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/corenodes.module.xdl64 with module(s) net.maxon.corenodes Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/crashhandler.module.xdl64 with module(s) net.maxon.crashhandler Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/crypt.module.xdl64 with module(s) net.maxon.crypt Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport.module.xdl64 with module(s) net.maxon.drawport Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_functioncache.module.xdl64 with module(s) net.maxon.drawport_functioncache Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_general.module.xdl64 with module(s) net.maxon.drawport_general Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_opengl.module.xdl64 with module(s) net.maxon.drawport_opengl Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_selector.module.xdl64 with module(s) net.maxon.drawport_selector Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/embree.module.xdl64 with module(s) net.maxon.embree Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/geom.module.xdl64 with module(s) net.maxon.geom Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/glclvk_trace.module.xdl64 with module(s) net.maxon.glclvk_trace Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/gui.module.xdl64 with module(s) net.maxon.gui Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/image.module.xdl64 with module(s) net.maxon.image Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/image_openexr.module.xdl64 with module(s) net.maxon.image_openexr Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/image_winmf.module.xdl64 with module(s) net.maxon.image_winmf Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/math.module.xdl64 with module(s) net.maxon.math Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mesh.module.xdl64 with module(s) net.maxon.mesh Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/misc.module.xdl64 with module(s) net.maxon.misc Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mvp.module.xdl64 with module(s) net.maxon.mvp Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/network.module.xdl64 with module(s) net.maxon.network Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nodes.module.xdl64 with module(s) net.maxon.nodes Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nodes_corenodes.module.xdl64 with module(s) net.maxon.nodes_corenodes Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/opencl.module.xdl64 with module(s) net.maxon.opencl Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/opensubdiv.module.xdl64 with module(s) net.maxon.opensubdiv Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/pythonconfig.module.xdl64 with module(s) net.maxon.pythonconfig Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/pythonvm.module.xdl64 with module(s) net.maxon.pythonvm Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/reflection.module.xdl64 with module(s) net.maxon.reflection Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/render.module.xdl64 with module(s) net.maxon.render Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/shaderbase.module.xdl64 with module(s) net.maxon.shaderbase Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/shadernodes.module.xdl64 with module(s) net.maxon.shadernodes Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/tessellation.module.xdl64 with module(s) net.maxon.tessellation Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/cadexchangeconfig.xdl64 with module(s) net.maxon.c4d.cadexchangeconfig Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/houdiniconfig.xdl64 with module(s) net.maxon.c4d.houdiniconfig Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/addons.xdl64 with module(s) net.maxon.c4d.addons Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/advanced render.xdl64 with module(s) net.maxon.c4d.advancedrender Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/alembic.xdl64 with module(s) net.maxon.c4d.alembic Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/archigrass.xdl64 with module(s) net.maxon.c4d.archigrass Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/bitmapfilter.xdl64 with module(s) net.maxon.c4d.bitmapfilter Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/bpexchange.xdl64 with module(s) net.maxon.c4d.bpexchange Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/browser.xdl64 with module(s) net.maxon.c4d.browser Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/ca.xdl64 with module(s) net.maxon.c4d.ca Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/ca2.xdl64 with module(s) net.maxon.c4d.ca2 Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/cadexchange.xdl64 with module(s) net.maxon.c4d.cadexchange Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/clothilde.xdl64 with module(s) net.maxon.c4d.clothilde Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/collada14.xdl64 with module(s) net.maxon.c4d.collada14 Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/collada15.xdl64 with module(s) net.maxon.c4d.collada15 Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/colorchoosergui.xdl64 with module(s) net.maxon.c4d.colorchoosergui Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/compositing.xdl64 with module(s) net.maxon.c4d.compositing Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/dwg.xdl64 with module(s) net.maxon.c4d.dwg Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/dwgobjects.xdl64 with module(s) net.maxon.c4d.dwgobjects Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/dynamics.xdl64 with module(s) net.maxon.c4d.dynamics Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/exchanges.xdl64 with module(s) net.maxon.c4d.exchanges Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/expressiontag.xdl64 with module(s) net.maxon.c4d.expressiontag Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/fbx.xdl64 with module(s) net.maxon.c4d.fbx Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/gpurenderer.xdl64 with module(s) net.maxon.c4d.gpurenderer Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/hair.xdl64 with module(s) net.maxon.c4d.hair Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/i_skp.xdl64 with module(s) net.maxon.c4d.i_skp Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/iges.xdl64 with module(s) net.maxon.c4d.iges Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/io_obj.xdl64 with module(s) net.maxon.c4d.io_obj Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/licenseserver.xdl64 with module(s) net.maxon.c4d.licenseserver Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/metrics.xdl64 with module(s) net.maxon.c4d.metrics Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mkmodeler.xdl64 with module(s) net.maxon.c4d.mkmodeler Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mocca.xdl64 with module(s) net.maxon.c4d.mocca Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/model.xdl64 with module(s) net.maxon.c4d.model Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mograph.xdl64 with module(s) net.maxon.c4d.mograph Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/motioncam.xdl64 with module(s) net.maxon.c4d.motioncam Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/motiontracker.xdl64 with module(s) net.maxon.c4d.motiontracker Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nbp.xdl64 with module(s) net.maxon.c4d.nbp Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/newman.xdl64 with module(s) net.maxon.c4d.newman Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nodeeditor.xdl64 with module(s) net.maxon.c4d.nodeeditor Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/objects.xdl64 with module(s) net.maxon.c4d.objects Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/onlinehelp.xdl64 with module(s) net.maxon.c4d.onlinehelp Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/onlineupdater.xdl64 with module(s) net.maxon.c4d.onlineupdater Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/python.xdl64 with module(s) net.maxon.c4d.python Loading file:///c:/Program Files/MAXON/Cinema 4D R20/plugins/Redshift/redshift4c4d.xdl64 with module(s) com.redshift3d.redshift4c4d Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/relaxuv.xdl64 with module(s) net.maxon.c4d.relaxuv Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sculpt.xdl64 with module(s) net.maxon.c4d.sculpt Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sculptbrushes.xdl64 with module(s) net.maxon.c4d.sculptbrushes Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/shader.xdl64 with module(s) net.maxon.c4d.shader Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sketch.xdl64 with module(s) net.maxon.c4d.sketch Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sky.xdl64 with module(s) net.maxon.c4d.sky Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sla.xdl64 with module(s) net.maxon.c4d.sla Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/spacemouse.xdl64 with module(s) net.maxon.c4d.spacemouse Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/substance.xdl64 with module(s) net.maxon.c4d.substance Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/teamrender.xdl64 with module(s) net.maxon.c4d.teamrender Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/texturemanager.xdl64 with module(s) net.maxon.c4d.texturemanager Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/thinking particles.xdl64 with module(s) net.maxon.c4d.thinkingparticles Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/tpoperators.xdl64 with module(s) net.maxon.c4d.tpoperators Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/volumes.xdl64 with module(s) net.maxon.c4d.volumes Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/walkthrough.xdl64 with module(s) net.maxon.c4d.walkthrough Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/xpressocore.xdl64 with module(s) net.maxon.c4d.xpressocore Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/xtensions.xdl64 with module(s) net.maxon.c4d.xtensions >Loaded... QCmds 0.22 by Johannes Kollender (http://www.kollender.com) Binding Remote Code Executor Server to localhost:2900 ... File Sequence Exporter 1.1 initialized. Target4D 1.5.0 initialized successfully 0@0<5B@ Welcome to the world of C4D and Python 2.7.14 (default, May 3 2018, 18:05:57) [MSC v.1500 64 bit (AMD64)] (c) 2019 >>>
